Here is a list of all the postings Jack Cole has made in our forums. Click on a thread name to jump to the thread.
Thread: Mild steel rigidity |
27/05/2023 09:40:03 |
Many thanks for all your replies. It's told me what I suspected, namely that a steel top is not suitable without support. I was having great difficulty find this information elsewhere. I'll use a wooden base. |
24/05/2023 22:22:27 |
Emgee and Ady1, thanks very much, that's given me a much clearer idea.
24/05/2023 19:12:35 |
I wonder if someone can advise a total novice on what would be the optimum thickness of a 1200mm x 600mm mild steel sheet. When I say optimum thickness I'm talking about using it as a worktop and storage shelf. It would be supported on all four sides only. So what I really need to know what sort of thickness would be rigid enough not to bow, without being impractically heavy? As i said before, I've no experience with sheet metal, so I've no idea. |
Thread: Randa b nose thread |
25/04/2023 12:45:08 |
Cheers Nick. You're quite correct. The reason I thought it didn't have a register is that mine has a tiny faceplate attached to it, which I cannot remove at present. The lathe is totally stripped down atm, so the spindle is out of the headstock, so I'll not be able to try and remove the faceplate until it's back together. Many thanks for the pics, it's all becoming much clearer. |
24/04/2023 21:48:00 |
Posted by old mart on 24/04/2023 15:12:00:
We have a faceplate at the museum, somewhere between 5 and 7 inches diameter with a similar thread in it. I will have a look at it on Wednesday, it was in some donations and might possible be what you are after, it has no use here.
That would be brilliant. Obviously a financial donation to the museum will be forthcoming if it's the faceplate I'm looking for. The picture Nick has supplied looks identical to all the ones Ive seen in pictures of Randa A & B models, so hopefully that's what you have. Many thanks
24/04/2023 21:41:26 |
Posted by Mike Poole on 24/04/2023 13:19:12:
I think the thread fit is not so important if the chuck fitment is a register. Some early lathes did not have the register surfaces so the thread was more important. If the mounting has register surfaces then my feeling is that the thread should not compete with the register and should just allow the register to locate the chuck and the thread hold it against the register faces. Mike Hi Mike looking at pictures of Randa a and b lathes, I don't think it is a register fit The plate only seems to be on as far as the end of the thread. Could be wrong, but that's the impression I get.
23/04/2023 22:52:09 |
Brilliant Nick, thank you very much. I did suspect 1" UNF might do the trick, as it's 12TPI, but I wasn't sure of the pitch. Once again, thanks very much. |
23/04/2023 22:01:08 |
Thanks for that Gets more complex by the minute. |
23/04/2023 21:10:20 |
Thanks for that. Why I'm asking is I need a faceplate. I do have a suitable candidate but it needs tapping. So now that idea is out, does anyone know if a Drummond or a Myford ML8 inboard faceplate, which are both 1'' 12 TPI would do the trick?
23/04/2023 19:17:21 |
Can anyone enlighten me as to what thread the headstck spindle thread is on a Rana B? It's listed (and measures) one inch, and has 12 threads per inch. Being a UK pre war design, one would imagine it's BSF, but that seems to be 10 TPI UNF is 12 TPI at one inch, but I can't imaging a pre war UK manufacturer using a US thread. Any help would be much appriceated. |
