Gear wheels
Chipmaster lathe
Milly S31/07/2023 16:08:23
42 forum posts
9 photos
Hi I’m after 2 gear wheels for Chipmaster
24tooth & 66tooth tried to put these on
wanted adds with no luck
maybe someone can advise please
cheers
steve
Nigel Graham 231/07/2023 16:20:35
3293 forum posts
112 photos
Are these change-wheels or internal ones? For the former, try a second-hand dealer like Home & Workshop Machinery.
Alternatively, if you know the pressure-angle, a transmission-parts stockist like HPC, Bearing Boys, etc. . These firms sell stock gears that need their pilot bores and perhaps other details machining to suit the application; though now of course some might only stock metric-size wheels. Also most gears now are of 20º PA: they will mesh with 14º 30' wheels but not properly, in time harming both.
Howard Lewis31/07/2023 17:45:24
7227 forum posts
21 photos
It is posible that gears for other Colchester vlathes would fit.
If you can quote the DP (Assumed to be DP being a British machine) and other dimensions, Thicknessm bire etc ) it might be possible to find ones for another machine that could fit, or be modified by machining, (Thinning, opening up/ boring and bushing ) to suit your machine.
What is some one else's surplus material might be your raw material for the gears that you require!
DC31k31/07/2023 18:20:27
1186 forum posts
11 photos
Posted by Howard Lewis on 31/07/2023 17:45:24:
His previous question on the same subject was on 25/07/23 (https://www.model-engineer.co.uk/forums/postings.asp?th=187461). The details you ask for are in that thread, posted 26/07/23.
Milly S31/07/2023 19:22:53
42 forum posts
9 photos
Hi Howard my Chipmaster is the continental
ive only had it a few weeks trying to collect
everything that goes with it the gears that came
with 1 of them had a broken tooth
with advice I received from forum members
i decided to repair it myself by welding
& filing it turned out perfect
im collecting a set of change gears
as I’ve started single point screw
cutting mainly to replace parts for
my sons garage
thanks
steve
