Here is a list of all the postings Andy Chancer has made in our forums. Click on a thread name to jump to the thread.
Thread: Milling on a mini lathe |
20/09/2023 00:45:23 |
Posted by Roderick Jenkins on 19/09/2023 22:50:17:
Posted by Nigel Graham 2 on 19/09/2023 21:44:03:
For a guide, I don't think you will find a book dedicated to "Milling InThe Lathe"... Well, actually: Milling Operations in the Lathe Rod Thank you,I have found one for the price of a pint on eBay,it should be with me by weekend |
20/09/2023 00:44:10 |
Posted by not done it yet on 19/09/2023 22:35:29:
I mildly disagree with the above post. Lots of very good pieces have been made just using a lathe. Milling machines were either rather too expensive or not really available as one looks back to the middle of the last century snd earlier that (respectively) - but most lathes were of myford size or larger. The limitations are as above - rigidity, space, power. Machining very steadily is required for best results. I suspect many items were machined on a faceplate, or mounted on the cross slide, rather than in a vertical slide , back then. Edited By not done it yet on 19/09/2023 22:37:51 Thanks,I’m not churning bits out on piece work so I can take it steady,if it can be done.As I say it will only be very basic sort of things for now til I get sorted.
19/09/2023 22:06:16 |
Many thanks for taking the time to write that,it’s really appreciated. My plan is to eventually get a milling machine,but for now whilst it’s the wrong side of Xmas I thought if I could just get by.However if I’m into spending hundreds just to get the lathe to do the work,I may aswell just put that to a used mill.I’m just starting out so just about to start a wobbler engine or similar to begin and pickup the basics. |
19/09/2023 19:10:13 |
Apologies if this is a bit of a daft question but I’ve looked and can’t really find a comprehensive guide on what items I need to do this-or is it just not worth it? im after real experiences of doing this,I’m aware there’s limitations but need to be able to achieve some sort of milling attachment.So I’d like to know what I need to buy to be able to do it on my warco super mini lathe.All attachments and tools needed. any help or advice is always appreciated. |
Thread: The centre of a well known supermarket |
01/09/2023 18:46:58 |
Pipe cutters and pipe benders at £5.99 each in middle of lidl this week,thought they’d be useful. Cutter does 3-35mm,pipe bender 6-8-10 |
Thread: Disorder at steam rallies |
17/08/2022 22:54:44 |
Pickering was advertised to be on until about a month before the date,it was cancelled,I don’t know why.... |
17/08/2022 22:33:00 |
Posted by Pete Rimmer on 17/08/2022 22:23:11:
Posted by mick H on 17/08/2022 09:49:27:
He also mentioned Pickering. Mick Ronnie Pickering? Who?
Thread: Access to digital issues |
23/07/2022 08:08:14 |
Excellent,thanks for the replies. |
22/07/2022 22:39:19 |
Forgive me if this is a daft question,I’m absolutely brand new to reading online mags or books and a bit unsure as to how this works.Am I right in thinking if I subscribe to digital only,this will also give access to any back issues online to read also?? That’s how I’ve interpreted this thread? I’m having a bit of bother getting to where I normally get my copy from and wouldn’t mind not having magazines everywhere these days...even though I love to read them rather than a screen! regards,Andy |
Thread: 2 inch Traction Engine, which one ? |
18/07/2022 22:19:39 |
Just out of interest,how much would something like those cost to self build these days?? Something I’d love to make one day! |
Thread: Oils/grease for mini lathe |
14/07/2022 14:43:45 |
Thanks for the great replies. Good points raised in regards to trying the machine out first,that I shall do.Ive used Lathe’s before but not for a good few years now,and they were already set up to be honest.I have some books from the engineering series that says about making tools that are useful and good practice to begin with so I shall set about them I think.Thanks again all. |
13/07/2022 22:04:18 |
Really? I had actually done a search too and couldn’t see anything other than “which lathe?” Etc I always google and use search first but couldn’t actually find a definitive answer really.I think the search terms are sometimes too generic in term perhaps.. Hope I’ve not committed a cardinal sin on here lol! |
13/07/2022 20:53:39 |
Finally managed to find a reasonably priced and looked after mini lathe not too far from me,it’s a warco super mini lathe.I plan to do a partial strip,clean adjust and re grease/oil so it’s right enough from the first use.What types of grease and or oils do I need and for where please? Also been looking at getting geared up tooling wise,it came with a set of carbide tipped tools but unsure as to what does what at the minute,but I do know I need some centre drills,appears to be a billion different types on eBay/amazon etc so could someone help in regards to a good starter set for me to have a practice /set up play with? any help or advice is always appreciated. regards,Andy |
Thread: Sad consequence of rising costs |
26/06/2022 23:11:57 |
It’s horrendous and it’s only getting worse.I know friends who’ve attended shows for cars etc and said the numbers are reduced massively both by attending and showing.Very sad indeed. |
Thread: Files,hacksaws etc |
12/06/2022 14:04:52 |
I see a lot of people say about using files to fettle up.Genuine model engineering beginners question here....why don’t many people use grinders or dremel type power tools instead? I understand that grinders remove a lot of material very quickly but asking as I often see and read about filing material when to me there’s quicker ways of doing the job.Like hacksaws too,seems like hard work to me haha.Maybe I’m getting lazy? |
Thread: The Workshop Progress thread 2022 |
19/05/2022 12:29:46 |
Nice job there. Edited By Andy Chancer on 19/05/2022 12:30:20 |
Thread: Time to Say Goodbye |
17/05/2022 12:26:02 |
Youve pretty much summed up what I was saying,something isn’t delivered it will get cancelled.Using covid/post pandemic whatever the latest buzz word is today just isn’t an acceptable reason anymore.I hope the affected subscribers have their issues dealt with quickly. |
Thread: Drill bit storage |
14/05/2022 07:39:26 |
Some good replies with ideas,thank you. |
Thread: Code of Conduct |
12/05/2022 21:50:04 |
Posted by SillyOldDuffer on 12/05/2022 17:56:06:
Posted by Andy Chancer on 12/05/2022 16:24:32:
... Im of the age where as young lads in our first jobs we saw the last of the "fun" stuff where the HSE now would be closing the place down,and where there would be several gross misconduct dismissals for "bullying" in the workplace... ... Good news Andy, several forum members are keen to spend the weekend giving you an old fashioned 1950's workplace bullying! Everything from compressed air up the backside to battery acid in your tea and a really fun joke with a Megger in the bogs. We're all looking forward to it - we don't often get volunteers! Dave haha I’m half a century away from that time,my first days in the workplace was early 2000s,not quite the extremities you describe,but loads of oil in air tools,long stands for things at the stores,and even people being took up on overhead cranes was regular.As was setting things on fire and watching people panic,I seem to remember a lot of “character building” shall we say aswell.As said things that would lose people their career now.Nothing personal just cheap laughs.
12/05/2022 16:32:07 |
I am currently sorting through the disgrace of a plastic tub that contains my drillbits,yes all of them.Dozens of them.So,with that in mind,i would like something to keep these neat and tidy,and organised.I have seen tins etc that only hold one size of each drill up to a certain size ie 2,2.5,3 etc etc I have a few spares of each that ive acquired over the years so was wondering if theres any better solution to a plastic tub or an old holburn bacca tin? Any good ideas out there? any help or advice is always appreciated. |
