Member postings for brian jones 11
Here is a list of all the postings brian jones 11 has made in our forums. Click on a thread name to jump to the thread.
Thread: cutting spur gears on a mill
22/08/2021 14:38:46
All my years in CAD and I never appreciated or noticed the difference between flipping and rotating 180
Gobsmacked - how many hidden errors did that create?
Still my by bridges are still standing but Hammersmith is in trouble but I have a cunning plan
22/08/2021 13:38:49
OMG the Monsignor is RIGHT
10^3 apologies, I have flipped my gear blank wrongly????????. I will have to investigate
You do indeed have to angle the tap anti clockwise 11.4 deg for a 10 tpi (5.711deg ha)
GOT IT
My gear flipping created a mirror image which reverses LH to RH
Wow thats an easy mistake to make
Edited By brian jones 11 on 22/08/2021 13:45:03
22/08/2021 12:18:31
Well this topic has certainly addled a few FES pates, like stirring up the suds sumplaugh
So to demystify the limits of plausible conjecture and give a platform to the deniably involved
What else on lockdown Sunday morning from the desk within my Anderson Shelter
I hope you can see the double helix (truncated Whitworth form BTW). I skewed 6 deg for fun and made from 2 identical blanks chived at the same time
For the follically scarified, note that the yellow gear has been flipped over 180 to make the red
also if you skew one gear wrt the other fractionally then you can mitigate backlash
Now with the appliance of science I shall endeavour to make an animated version showing meshing and also the reviled tap attacking gear blanks
My biggest challenge will be to post mpg or gif on this board, I havent seen any other Disneys on here
Anyone know how its done - maybe Dropbox?, Ive never done a Youtube upload yet (do you have to sell your soul?)
Sorry JP missed your eminent description above, most interesting
As you point out, this OP is not about using hobbing gear and all the expensive industrial attachments involved, way off topic
The point being that a hobbing method ties the spindle mechanically to the mandrel in much the same way as screw cutting on a lathe (excluding the tedious divider plate method)
This is examining whether FREE HOBBING has a place for the hobbyist NPI.  Its clearly demonstrated in making simple worm gears so this is just an extension of the topic. As seen above there are a lot of armchair misconceptions.
One point to note is that theoretical errors can creep in
eg
a) say you want to make a ruler with a 1" block.  Use it to scribe 12 marks then do you have 1ft - well clearly it depends on the accuracy of the block.  Hope you can see the implication of cumulative errors
b) Instead use the basic tech drawing trick use the block to make 12 ticks then project that onto a 1ft line and you have your accurate ruler with 12 inches
So the tap method is using method a)  and the dividing plate (or hob) is using method b)
Now thats the theory but what happens in practice
Edited By brian jones 11 on 22/08/2021 12:44:19
Edited By brian jones 11 on 22/08/2021 12:46:01
21/08/2021 13:38:48
Posted by John P on 21/08/2021 13:13:22:
Couple of videos for herringbone fans.
Don't blink for the second one.
https://www.youtube.com/watch?v=DFEN9_t150c
https://www.youtube.com/watch?v=9h7nn1v6D-E
see what you can do with a big enough tap
https://www.youtube.com/watch?v=mtV8Zu5EtUE
21/08/2021 13:27:05
Now I thought you could do something like that
The Anderton boat lift used 'herringbone' gears. Big ones. They were cast and then run in pairs in a sand bath to bed them in to my knowledge.
https://www.alamy.com/anderton-boat-lift-is-a-two-caisson-lift-lock-near-the-village-of-anderton-cheshire-in-north-west-england-image236836670.html
that should keep the back seat modellers quiet for a while
BTW have you all spotted the deliberate design error
21/08/2021 13:15:57
Pay attention at the back
Or maybe you don't mean herringbone but just have two straight gears with some angular offset to take up the backlash.
21/08/2021 13:13:51
I am making up gear blanks using hard wax. I will set up a jig so i can rotate the tap by hand and closely observe what is happening
I will also look at some 3d dynamic modelling s/w i used many years ago (my brian hurts already)
Well it beats lock down dunnit
21/08/2021 12:12:22
Posted by John Haine on 21/08/2021 11:21:01:
By herringbone, do you mean helical? Why would that eliminate backlash?
Sometimes I want to give up
https://en.wikipedia.org/wiki/Herringbone_gear
21/08/2021 07:35:01
Well isnt the worm gear an endless rack?
Get creative, how about a spiral rack
Spur gear with round contour at edges, eg more tooth contact in the mesh
I am envisaging herringbone gear set , ie two spurs, one reversed against the other - no backlash
Waiting on mtl to start my modelling
After all who would ever dream up a pair of oval gears
https://www.radartutorial.eu/17.bauteile/bt08.en.html
21/08/2021 06:57:11
Rack and pinion or worm gear, both have been shown to work to an extent.
20/08/2021 17:09:25
so its not so far off the involute as expected then, hmm I must get on and make some
you see I have a large qty of plug taps 1" to 2"W and xl metric MS washers from M30 - M80 all 4mm thick
though I may have trouble with the steel used? Perhaps might need to anneal one, might be work hardened from being punched out of strip.
I have ordered som mtl to make a simple mandrel jig to be held in my lathe QCTP. In theory I can raised the tooll holder so as to get a straight cut across the witdth
I think I can see one reason why it will fail and that is that when starting the cut your tap tpi will spread across the OD of the blank but as you go deeper the tpi have to spread over the inner ID of the thread so less space for the original cut? which is why teeth numbers turn out less than expected?
Edited By brian jones 11 on 20/08/2021 17:18:34
20/08/2021 15:44:58
Yes indeed I fully recognise its a crude method hence "rogue method" but there maybe some mileage for simple apps
After all there is a whole science you could spend years on perfecting the perfect tooth cos users wanted efficiency and also quiet operation and long life
none of the above would be satisfied by my dirty method
As you can imagine it would vibrate under load
Something tells me this isnt the thread form I am going to get, it doesnt feel right, I am assuming a tpi tap of 16
Perhaps its why members have reported that they didnt get the number of teeth they expected? Hmmmmsarcastic 2
Edited By brian jones 11 on 20/08/2021 15:52:22
Edited By brian jones 11 on 20/08/2021 16:56:55
20/08/2021 13:27:22
Remember the original proposition
" Primitive but very quick and only suitable for light load low speed apps and probably noisy "
Some mentioned mechano gears - well Im not pompous - it worked for a million kids
I asked if anyone else had actually tried this method rather than generate a whole sheaf of plausible conjecture
19/08/2021 17:42:10
Posted by JasonB on 19/08/2021 16:28:21:
I feel like giving up sometimes, why not just got to the web address for Huco that is in Speelworks posted image, then go to products and then gears which give you this. Do you need more help getting to a specific type of gear?
Personally I find the ones from Belting online very reasonable, MOD are cheaper than DP.
Its not helpful to throw a hissy fit, I did this already
this is the link from the pic above
http://www.maedler.co.uk/
try it yourself, for me it just leads to a dead end back to germany
being given a dead link is very frustrating and wastes a lot of time
you found your link by doing a separate search for Huco
19/08/2021 16:37:38
Well I shall try out this free hobbing method
I agree the gears will only mesh with others produced by the same tap
but it will be interesting to see how two such gears perform together and if they would suffice for light duty
dont you think
and BTW I belong to the school of thinking first and asking around before making chips, unlike the suck it and see brigade.
quote
It doesn't take that long to cut spur gears by conventional methods, provide one gets on with it rather than pontificating on forums
as per AJ with his superior minded 4 axis CNC machine
Obviously forgotten how long it does take to cut spur gear - the point of my original post = as they used to say "read the question carefully first, dont give an answer you would like to be asked."
I was just thinking out of the box
19/08/2021 16:07:14
Posted by speelwerk on 19/08/2021 12:52:46:
Posted by brian jones 11 on 19/08/2021 12:37:45:
followed up on Madler website, very comprehensive, BUT I cannot see how to buy anything, no on line shopping cart or any hint of a sales facility
I am lost here pls advise
You select Branche Offices at the top of the page, find the UK distributor and contact them. Niko.
Great Britain
Huco Engineering Ltd.
5-7 Merchant Drive
GB-SG13 7BL Hertford
Tel.: +44 (0) 1992 50 19 00
Fax: +44 (0) 1992 50 98 90
[email protected]
I did this already but it just takes me back to the inert Madler website
try the link yourself
19/08/2021 12:37:45
19/08/2021 12:05:43
I have seen vids of using diving head for use with a milling form tool for cutting a spur gear say 3" dia, 1/4" thick with say 80 teeth
OMG what a painfully slow process as you mill each one
Yes there are powered head linked to spindle to cut these also - v expensive attachment
Now I was looking at some large bsw plugs taps i have and wondered if these might work
Then I saw a vid on making worm gears using this method, where the blank is mounted freely rotating on a mandrel. The rotating tap held in a lathe chuck and the blank is brought crossways to meet the tap. The action of the tap screws the blank around as it cuts and you end up with a worm gear which can be operated by a bolt
https://www.youtube.com/watch?v=XIzlg_uObwQ
Now I can see the FES going nuclear on thiscool
Yet I have not found a vid on using this technique for a spur gear
Consider a 3/4" bsw x 10 tap on a 3" x 1/4" thick blank gives ca 100 teeth
So the tap is mounted in the spindle and the blank on a horizontal mandrel
First pass will get the thread depth, then the bed will be slid across on the x axis to get a flat bottom for the tooth form (I think)
put them in a gearbox with heavy oil and used nylons or sawdust
Anyone ever tried this
Seems too good to be true
Thread: small toothed belts
19/08/2021 10:40:18
Thnx JB as you can see I was looking in the wrong place with the wrong keywords - its in the aesthetic world of CNC and timing belts etc. but prices I saw for large driven cogs were silly money for a hobbyist £50
Industrial suppliers will also have unaffordable prices.
so a new door has opened for me and I have acquired an electric window assy for a tenner - well its a start and I agree that going to stepper motors really is overkill for this duty.
19/08/2021 10:05:38
Posted by Manofkent on 18/08/2021 21:58:28:
If it is a cnc belt have a look at cnc4you webpages. There is a lot of info, they sell belts and pulleys.
thats more like it, they sell the SS belt and the sprocket (small 1" dia)
presumably one would need to make a larger driven wheel say 75mm dia oneself
hmm another chalenge
would one calculate the pcd and drill a set of teeth with a 5mm drill (or less probably) in an ally blank
probably be noisy
I will have to check torque requirements
Bed speed I think a max of 3" per min down to say 0.3/min (must recheck) so 10 tpi gives 30 rpm max on the lead screw.
