Here is a list of all the postings Luker has made in our forums. Click on a thread name to jump to the thread.
Thread: Ballaarat construction series |
12/02/2022 12:41:32 |
The young lad building the Ballaarat let me know I was a little vague in my description of making the taper reamer for the drain cocks, so I put together the following… |
Thread: Re-casting LG2/Colphos 90 into plate form |
10/02/2022 04:38:10 |
Hi Wal, is this a commercial (paid-for) job? There is another option that may be worth considering. |
09/02/2022 16:40:40 |
Hi Wal, They shouldn't have a problem casting that, and you won't get any loss of machinability or corrosion resistance (in fact the machinability will be better). If the surface area is large compared to the volume you unlikely to get draw holes, as is the case with your plate. Plates are easy to cast when compared to large volume - small surface area components like cylinders or bars. This is of course assuming the foundry is even remotely competent. Cost is of course another matter. Hope this helps... |
Thread: The RSME spring live steam meet |
08/02/2022 15:17:35 |
Posted by Bazyle on 08/02/2022 13:47:04:
Posted by Luker on 12/01/2022 12:00:06:
Tri-pod is on order Shouldn't they be making one? They too busy building loco's V8Eng: You missing out if you don't read the credits, sometimes I slip in something naughty... |
08/02/2022 07:31:36 |
Another RSME short video of a schools class that ran this last Sunday... |
06/02/2022 05:24:38 |
I found this little local media piece on the Ballaarat the other night. That little loco means a lot to the community which is great! |
Thread: Backyard Foundry - oil burning furnace - moulding and casting a spider |
05/02/2022 18:37:13 |
Hi Graham, my pleasure. Please let us know how it goes (pictures are always nice!). Here’s another video I took the day before of me moulding, with the sprue on the parting line to improve the quality of the outer surface, and increase the head in the mould. My neighbour was interested to see me moulding and casting and asked if he could watch me mould a pattern. I explained what I was doing and we had a good old chat. The video is long (20min) and is probably only of interest to guys that have moulded cored-split patterns in green sand. The casting is copper chimney caps for my current build. |
05/02/2022 14:35:35 |
Posted by the artfull-codger on 05/02/2022 14:25:18:
Hi Luker,I need to cast bronze barstock but the last time I tried it [a few yrs ago] vertically it was great on the outside but after turning it it was full of porosity,inside so I cast some horizontally with sprue & feeder & they came out ok but a mess on molding them, this of course was before & knew about your inoculant which I've just used[big thanks] perhaps I'll try again vertically.,saves time .
Hi Graham, the trick to stop that is the dusting with coal dust. The inoculant won't prevent porosity or piping from happening. If the top freezes first you likely to get porosity or piping in the bar. The idea is the coal keeps the top surface hotter for longer and the draw is from the top surface not the middle. I cast all my bars vertically. |
05/02/2022 13:12:26 |
Hi Fellow foundrymen... I took some time off my day job to get some casting done this week and am putting together a few videos. Dave’s original post was inspiring! I thought I would start with a short video on melting fines for bar stock… |
Thread: Pioneer designed by ND Willoughby |
01/02/2022 17:48:22 |
One of our younger members put together the following video of Pioneer... Think it turned out a great video! |
Thread: Stainless steel boilers |
28/01/2022 11:31:53 |
Hi Dave, I agree! I would not call myself knowledgeable, but I have experimented and run a few analytical scenarios for stainless purely for the cost benefit over copper (and of course built and tested them). The series I submitted (2 parts if I remember correctly) was specifically to show how I go about manufacturing my boilers and the materials I use (as well as welding procedures and suggestions for the boiler data book for the inspector). I also suggested a few simple tests for stainless welding as well as things to look out for (again specifically for the boiler inspectors). Hopefully this would be a good starting point and shorten some of the development time. Incidentally the Australian boiler codes are reasonably good but do not cater for the smaller boilers (last time I checked.) |
28/01/2022 10:21:37 |
Posted by JasonB on 28/01/2022 10:16:54:
Fizzy's thread a few years ago shows you don't need to be coded if you get the welds tested which was quite a cheap process You also don't have to get the boiler tested by a club, may independant boiler inspectors able to do it and that is the way a lot of traction engine builders choose to go. Edited By JasonB on 28/01/2022 10:19:36 Jason you too quick! |
28/01/2022 09:56:49 |
Posted by Martin Connelly on 28/01/2022 09:10:57:
The designation of sch40 or sch40s depends on which ANSI standard is being applied. ANSI B36.10 does not use the s after 40 but ANSI B36.19 does. since at 2" there is no dimensional difference it does not matter if you put the s in or not. # The issues of stress corrosion and stress cracking possibly apply more to a model boiler than to industrial applications. An industrial application may only have a few pressure or heat cycles a year, a model sized boiler may have more in one day than an industrial application. The smaller boiler may also locally heat up and cool down faster and since stainless has lower thermal conductivity than copper and less ductility this cycling could be more damaging. Martin C Corrosion cracking should not be confused with low cycle fatigue. Corrosion cracking is an accumulative failure type spurred on by the surface tensile stresses, temperature and initiation element concentrations. I’m afraid I don’t agree that model boilers are more susceptible. If anything they are less so due to the limited use. Low cycle fatigue due to thermal cycling is another matter and will only accelerate corrosion cracking if the design does not cater for it. With respect to ductility, this is again a design issue and any design needs to take this into account. The oldest stainless boiler in current use at our club is 27years (SS316L, and that’s a class 2 boiler). Stainless is much cheaper than copper, and in my humble opinion easier for the younger generation to fabricate who would likely have had more experience with TIG than brazing. Mark: SH10 will be fine for a 30Psi boiler! |
28/01/2022 06:00:59 |
Duplex stainless is preferred but if that is unavailable SS316L is fine for our little boilers (class 1 and below, but need to check regional requirements). All 4 of the stainless boilers I’ve designed and built have been very successful. If you use a backing plate then back purging is not necessary so a little planning will pay off. The design for stainless is slightly different to steel and copper; the design needs to take into account the corrosion cracking issues especially with austenitic stainless. I personally wouldn’t use MIG; some of the tests I did showed the normal MIG gas caused the welds to become sensitized (stark difference to TIG). MMA inclusions are a big problem in SS. The Wahya series had a high level FEA pic showing the calculations to deal with material issues. I’ve submitted an article some time back on stainless boiler manufacture and some of the things to look out for, not sure if it is in the pipeline for print. The part on the Ballaarat boiler will have a little more info… |
Thread: The future of casting kits |
19/01/2022 17:47:17 |
Sadly I think the argument for sand casting is a little moot if the required skills are not available (at a commercial level). It would be interesting to find the break even in cost between 3D printed patterns for investment casting vs CNC. I have a feeling the more demand there is for a kit the more they would lean towards investment casting. Incidentally the skills required for investment casting is different to sand casting. With the stiff mould and pouring into a heated shell the riser design is much easier, in fact in my experience the investment foundry-man is unlikely to have ever calculated casting modulus etc. and they generally feed from the cup. |
18/01/2022 15:17:35 |
I’m honestly surprised sand casting kits are still available. At the very least modern casting kits should go the investment casting route. With modern 3D printed patterns produced from very reasonably priced printers there is no reason for an investment foundry to not add a few parts to a tree. Today most engineers would tend towards CNC or investment for components in the size range of model engineering, especially lower quantity items. Personally I like the challenge of getting the calculations right for the risers and messing around with the chemistry of the melt. I can’t remember the last time I got hard spots or blow holes. Casting has been part of the hobby since the beginning, as an additional skill to be honed. Not sure it makes sense commercially though, especially if the suppliers can’t get the castings right. Maybe in the future G-codes will be sold instead of plans and little home CNC units used to finish models while watching 3D movies. Can't wait... |
17/01/2022 06:53:21 |
Another RSME short video... |
16/01/2022 16:54:10 |
Hi Graham, the name plates look great! Surface looks spotless and they polished and painted beautifully. Thanks for the pictures. |
12/01/2022 12:00:06 |
The young lads at RSME put together the following video for the 2021 RSME spring live steam meet. Full article in 4678. I think the lads did a good job on production and story line! Tri-pod is on order |
10/01/2022 17:13:25 |
Hi Graham, that's great news! Thanks for the feedback. I'm always glad when someone can take something I've written about and reproduce the results, then I know I'm sharing knowledge and not just boasting Yep my furnace design, including the burner, is in ME4626. I gave the ratios of what will work based on my calculations, but my actual sizes are also given. Please let me know how you get along! PS have you got some pics of the name plates? |
