David Roberts 22 | 30/11/2020 20:22:38 |
14 forum posts | Hello everybody my name is David Roberts I'm new to this forum I'm building steam locomotive 0-4-0 5 inch gauge. I've had to start over getting a workshop together so far I've purchased a small metal turning lathe, a drill press bench mounted but decent quality and a twin wheel grinder I'm getting the lathe fairly well equipped with tooling. I'm hoping to build a railway at home 5 inch gauge ground level using 16mm aluminium rail and this is where the HELP comes in could you guide me to books or literature of any kind on the subject I could do with knowing what's the widest gap I could leave between the ends of rails at fish plates for expansion without the gap causing problems with trains going over it. Any help delaying ground-level rail aluminium the construction of points curves gradients all of this would be most helpful. |
SillyOldDuffer | 01/12/2020 10:54:22 |
10668 forum posts 2415 photos | Welcome to the forum David. Far from expert on 5" gauge railways but I'll have a go at answering the question in hope one of the experts will correct any mistakes!
There's an online calculator here. It suggests a 100metre length of Aluminium will expand by 66mm over a 30°C range. If the line is installed on a hot day midsummer with a small gap then the gaps will grow to a maximum in winter, when the railway is unlikely to be is use. What's riskier is laying the line in winter and calculating the gap based on predicted temperatures. Global warming appears to be responsible for what should be once per century extreme weather events: of the 19 top temperatures recorded in the UK, 8 have occurred this century. Highest shade temperature recorded ever recorded in the UK was 38.7°C in July 2019, compared with the average - about 17°C. Do you design for 17°C or 38.7°C? Garden railway, I wouldn't overthink it. Be interesting to see what a club track layer says! Dave Edited By SillyOldDuffer on 01/12/2020 10:56:47 |
David Roberts 22 | 01/12/2020 12:07:11 |
14 forum posts | Hello thank you for coming back to me I have always been under the impression that I would need expansion joints with gaps This is getting very interesting and curious to see if I get more replies especially from clubs with experience of 16mm aluminium rail. |
Steambuff | 01/12/2020 12:32:21 |
![]() 544 forum posts 8 photos | Hi, Take a look on the PNP Railways web site ... Look at their Video on fitting fish-plates, they recommend 3mm for their aluminium rail. Dave |
David Roberts 22 | 01/12/2020 12:59:21 |
14 forum posts | Thank you very much Dave I jest view the video very interesting and makes sense to me if I can learn how to set the gaps correctly during the cold winter there will be a gap full width during the summer the track would be used more often and there should be little or no Gap. |
SillyOldDuffer | 01/12/2020 13:06:29 |
10668 forum posts 2415 photos | Posted by David Roberts 22 on 01/12/2020 12:07:11:
... I don't think your post's been moderated because that leaves an 'Edited by' footnote showing who did it. Maybe finger trouble, specially if you're on a small format device like a phone. My laptop's touchpad mouse gets me sometimes - I accidentally select text with my sleeve and then overwrite it without noticing. Carry on! Might never happen again. Dave
David Roberts 22 | 01/12/2020 15:41:41 |
14 forum posts | Hello thanks again for coming back to me by the looks of things I messed up my own thread which don't surprise me I'm not very good the computer bit that's missing goes like this. I'm looking forward to getting the workshop together so I can finish the locomotive but I only started it 36 years ago when it first appeared in the magazine engineering in miniature. |
John Slater 1 | 01/12/2020 20:17:49 |
3 forum posts | Hello David I suggest you will find the details you are after in a series of articles titled "Making Tracks" by Denis Monk that were published in Model Engineer beginning in volume 161 for 1988 and concluding in 1990. Best wishes John |
duncan webster | 01/12/2020 20:26:49 |
5307 forum posts 83 photos | Posted by SillyOldDuffer on 01/12/2020 10:54:22:
There's an online calculator here. It suggests a 100metre length of Aluminium will expand by 66mm over a 30°C range. If the line is installed on a hot day midsummer with a small gap then the gaps will grow to a maximum in winter, when the railway is unlikely to be is use. What's riskier is laying the line in winter and calculating the gap based on predicted temperatures. Global warming appears to be responsible for what should be once per century extreme weather events: of the 19 top temperatures recorded in the UK, 8 have occurred this century. Highest shade temperature recorded ever recorded in the UK was 38.7°C in July 2019, compared with the average - about 17°C. Do you design for 17°C or 38.7°C? Garden railway, I wouldn't overthink it. Be interesting to see what a club track layer says! Dave Edited By SillyOldDuffer on 01/12/2020 10:56:47 If the rails are in full sun they get quite a bit hotter than air temperature, we've measured 55C on a really hot windless day. If the gaps are too small the rails buckle, been there done that. If you're ever going to have track circuiting then spacers between the rail ends are a good idea, otherwise the gaps can close up over time Edited By duncan webster on 01/12/2020 20:27:12 |
David Roberts 22 | 02/12/2020 11:16:15 |
14 forum posts | Hello John |
David Roberts 22 | 02/12/2020 11:28:45 |
14 forum posts | Hello Duncan Webster |
David Roberts 22 | 04/12/2020 12:29:07 |
14 forum posts | Hello everybody |
