Member postings for Paul Rogers 7
Here is a list of all the postings Paul Rogers 7 has made in our forums. Click on a thread name to jump to the thread.
Thread: Repair on cast base.
25/05/2020 19:56:29
Thanks for the help. I will put jb weld on top of my shopping list.
Thanks Paul.
25/05/2020 18:52:53
Hi.help please.i have done light damage on the cast base on my stuart Turner. S50.its not load bearing. Just a chip.i have heard metal puttey can be used then filed then painted. Is this right.if so what's the best one to get.
Thanks Paul.
Thread: Pipe size
10/05/2020 19:33:01
Thanks.jason.i thought I was not far off I just needed to confirm.
Thanks Paul
10/05/2020 16:31:37
Hi can any one advice is 5/32" copper pipe the correct size to run a stuart Turner s50 from a 501 boiler.
Thanks Paul
Thread: Air supply to test run steam engine.
07/05/2020 12:59:17
Update. I have purchased. A 24lt.9.6cfm.2.5hp compressor .thanks for the advice given by you all.
Paul
07/05/2020 12:17:27
Thanks to you all the advice you have given is amazing. I could have made a big mistake. I am now haveing a rethink on the route I am going to take.
Thanks Paul.
06/05/2020 19:41:32
Hi Alan and stuart .good point on noise. I did think about the air brush compressors. I had a look at bambi compressors I agree some thing like this is the way to go..thanks again.
Paul
06/05/2020 16:54:03
Hi.can any one suggested a small compressor which will give me enough air to test run my steam engine, (10h).i am a bit stuck on this,thanks.
Paul
Thread: New members
01/05/2020 21:55:24
Hi Stephen .I have started looking on utube a few weeks ago that's when I thought I have a go at the 10h.and s50 stuart Turner kitsso far not to bad.now I have a small mill.
Paul
Thread: Proxxon
01/05/2020 19:38:15
Thanks colin. For the information it's a great help.i have bfw40 it does what I want light cuts on my stuart Turner casting I will invest at a later date.on a bigger mill.i am quite impressed.with the little mill. 250watt .for now.
Paul
Thread: H10 stuart Turner cylinder
01/05/2020 19:13:55
Hi.jason.thanks for all the info.that is some machining.i get there one day with practice. I am getting better by the day sercret is take my time reading the drawings slowly.
Paul
30/04/2020 07:57:00
Thank you all for the advice. Great point on honeing. All so graphite string,thanks for showing the video. I am picking up these tips .I find it pays just to take my time and if I get stuck shout for help.thanks again. 😊
Paul
29/04/2020 21:40:07
Thanks.neil. I have a .002" clearance. I was a bit concerned .like you say it's not under a work load.the bore is not as good as I would like still my 1st attempt. The mistake was the side of the boreing tool rubbed slightly. Still see how it goes.i can allways get a cylinder casting from stuart Turner. If I am not happy with it.
Paul
29/04/2020 17:46:23
Hi.could any one give me advice on what min and max clearance you would work to between piston and cylinder.on h10.do you have to allow for expansion.
Thanks paul.
Thread: Proxxon
27/04/2020 21:13:04
Thanks to both of you.for your advice i see in the arc catalogue. There show milling cutters with 6mm shanks.it gets easier with help.not sure about China. I will look into it.
Paul
27/04/2020 19:23:26
Hi,can any of you please tell me when I can get after market mill cutters to fit proxxon bfw40/e. Colllet size .2.35.3.00.3.2.4.0.5.0.6.0mm. I know this is a toy,compared to some of the mills you have but at the present time it does the light milling I need.thanks.paul rogers.
Thread: New members
26/04/2020 21:15:30
Thanks Neil.i have a lot to learn I will do my best to keep my question and crys for help sensible.
Paul.
Thread: Proxxon mill
23/04/2020 14:04:19
Thank you steve. For the drawings. I have checked in.my Zeus book it is 1/2unf.20tpi.you are a star.tool station sale them at half the price.i am leaning a bit each day.
Thanks.paul Rogers.
23/04/2020 10:47:20
Hi,all the chuck will be for very light drilling. I will get confirmation on thread size.thanks for all the help.i will let ever body know the out come. Paul rogers.
23/04/2020 09:46:28
Hi,l need a bit of help.i have just purchased proxxon mill,bfw40e could any body tell me where to get a chuck for it,I think its 1/2 unf.thread. thanks.paul rogers.
