Member postings for Ronald Morrison
Here is a list of all the postings Ronald Morrison has made in our forums. Click on a thread name to jump to the thread.
Thread: Sieg C1 lathe autofeed and screw cutting
03/11/2020 11:00:21
The fact that the lathe motor can be run in reverse makes threading to a shoulder for imperial threads much easier. With the motor running in reverse use a boring bar with a thread cutting end on the backside of the stock , bring it to the shoulder, then engage the "half nut'. Now you cut threads away from the shoulder so you don't have to have lightning reflexes. Making a stop for the carriage lets you set the starting point so the tool never hits the shoulder.
Thread: Calliper - Dial reading
02/11/2020 21:44:56
Posted by Clive Foster on 02/11/2020 20:31:06:
Dial callipers don't have a battery to go flat on you when needed.
I'm prejudiced. With maybe 50 or so micrometers, verniers, callipers and similar about the place going electronic isn't going the happen!
One day I should do a proper census.
If your eyesight starts to go bad the fact that you have to replace a battery occasionally will not bother you so much as not being able to see the numbers on the dial nor the lines on the vernier. I have to replace the battery about once a year on each of my digital calipers. Since I know that, I keep a few spares on hand.
02/11/2020 20:04:48
Why not save yourself the agonizing over the metric dial caliper and just get a digital? The cost is not much different, the digital has numbers big enough to read and with a quick push of a button becomes an imperial caliper. Very easy to set a new zero as when you are turning to a specific dimension you can set that dimension as a zero and read how much needs to be removed to get the intended dimension.
Thread: Choosing a lathe
29/10/2020 21:28:07
I also didn't know what I would be using the lathe for but I inherited a 10X24 inch Chinese made lathe with a gap bed. Now that I have had it for several years I know what I would use the gap bed for as I did need it for one project. It came with a steady rest which I also have found a use for. Bigger is better in my mind because I can still make little parts on a big lathe but no big parts on a little lathe. With that in mind, space available and how to handle the weight of the lathe getting it to that available space must be considered even before checking your wallet to see if you can afford it.
Thread: Budget CNC
29/10/2020 21:22:06
Does the CNC he desires need to be able to cut metal? Would a wood cutting CNC machine satisfy him for a while? How about helping him build a CNC router? With that approach he/you can save some money and have a better understanding what it takes to make a CNC machine. Knowing that will set him up to be better able to understand and use a CNC mill. Here are a couple videos on making one.
Do it yourself CNC
$500 home built CNC router
Thread: Overrating a power supply for a DC motor?
23/10/2020 11:46:10
Posted by Hollowpoint on 22/10/2020 22:08:22:
Need some help guys.
I have a small DC motor I want to use on a project. The motor is 24v 200w and "rated" 11 amps.
I suspect the amp rating is at full speed with no load but not sure? Obviously if that is correct with heavy load it will draw more amps.
How do I choose the correct amp power supply? Do I need to go bigger? how much bigger?
How fat is your wallet? Ideally you want a power supply that can produce 24 volts (motor is rated for that voltage) and infinite amperage. That would keep the voltage constant over any load possible. Now you know that the motor can only draw 11 amps maximum so in theory a power supply that can produce 24 volts and 11 amps should be sufficient but in the real world, as the power supply approaches that maximum load the voltage drops. I'd probably be looking for a supply that could produce twice the rated amperage as that should be fully capable of maintaining the voltage at 24V but then I would compare that supply cost to how my wallet looks and think about a compromise. How often would I need that full power? What will be the consequences if the voltage drops a bit under full load?
Thread: Milling spindle motor - AC or DC
01/10/2020 12:10:56
Speed control technology has rapidly advanced such that what is available for speed control for DC motors now wasn't available when the book was written. What was normally achieved by changing pulleys can now be adjusted with the turn of a potentiometer. The advent of technology to create brushless motors with high performance is quite new also, again probably since the book was written. It is also possible that the author has a bias.
Thread: Cheap Milling Vice Question
27/09/2020 11:59:10
Put an endmill or fly cutter into the spindle of your mini mill and measure the distance to the bed. Now subtract the height of the vice you mentioned from that to see what size of material you can fit into the remaining space. You may decide that the swivel base will take up too much of the space available for the amount of times you will benefit from the swivel.
Thread: Boring bars
09/09/2020 11:56:09
Rigidity is critical in removing metal with a lathe bit, boring bar, or a milling cutter. The typical boring bar will be steel. Hardened steel is more rigid than mild steel but solid carbide is even stiffer. Look for the solid carbide boring bar.
Thread: Help with lathe valuation - First post, be gentle!
22/08/2020 11:00:40
Here is what those kind of lathes sell for new in the United States.
https://www.harborfreight.com/7-inch-x-12-inch-precision-mini-lathe-93799.html?_br_psugg_q=mini+lathe
Thread: Cup grinder application
12/08/2020 11:38:15
Select the white wheel instead of the diamond unless you are only grinding carbide or are using it in a low speed grinder. When using diamond for grinding steel where the steel will become hot the diamond (pure carbon for practical purposes) can dissolve into the steel increasing its carbon content but leaving little cutting action from the diamond.
Thread: Fiber change gears
17/07/2020 11:14:09
Delrin should not need lubrication buy shouldn't be harmed by lubrication either.
Thread: New Lathe - poor suface finish on my results
12/06/2020 14:09:01
Posted by Ace Chandler on 12/06/2020 12:53:35:
Posted by Ronald Morrison on 12/06/2020 11:43:55:
1. Check that every gib is adjusted to get a slight drag. Don't expect the manufacturer to have adjusted everything to the best fit. Loose fitment on the cross slide and compound will get you bad results.
2. Sharp tools make accurate cuts. Dull tools push the steel instead of cutting it. Carbide inserts have their place. They are made to be able to withstand higher temperatures that come with high RPM and heavy feeds. They cannot be super sharp because they are brittle and the edge will chip. If you want super sharp so you can make very light cuts use high speed steel and learn to grind the proper shape and to hone it to razor sharp.
3. Back off the tool from the steel before backing the carriage for the next cut.
could you help me understand a bit more what the first point precisely means? - does "slight drag" mean that it should feel a little tighter than one might intuitively think was needed?
Snug up the gib while trying to turn the handwheel. Do each gib screw and make sure the screw is slightly snug but does not bind the handwheel. The handwheel should still turn relatively easy but not freely. Hard to explain better without being there.
12/06/2020 11:43:55
Thread: Machines and equipment sourcing chronology...
01/06/2020 10:42:40
i put off buying a bandsaw for years, using the hacksaw for all my small cutting and oxy-acetalene or plasma for the bigger cuts. What a mistake! Now that I have a bandsaw I will carry parts 100 meters to the bandsaw instead of picking up the hacksaw that is 1 meter away. The accuracy of the cuts is better than I ever managed with the hacksaw and I can clamp the stock in, start the bandsaw and walk away to do other things, knowing that the bandsaw will just shut itself off when the cut is done.
Thread: Single point threading
26/05/2020 15:42:17
I have a terrible time threading up to a shoulder as I can't seem to stop the carriage just at the right time with the motor turning the spindle so I made up a crank that would turn the spindle. That lets me turn the spindle very slowly, much slower than the motor will go and I can then stop the turning just where I want.
Thread: 3D CAD software - what do you use?
20/05/2020 11:18:10
Posted by Bandersnatch on 20/05/2020 01:33:22:
Posted by Barrie Lever on 20/05/2020 00:04:49:
Posted by Bandersnatch on 19/05/2020 22:16:16:
Do you do 3D printing?
Yes but almost exclusively from my own designs.
I do my own stuff too (really get a kick out of modelling then seeing the printed result!).
However I'm printing something right now from Thingi. It's a longish print (~8 hrs) and it's not going that well. I think the design could be modified to improve printing (and function actually) with some simple changes. But .... I only have an STL file. The only other recourse is to remodel it from scratch.
Edited By Bandersnatch on 20/05/2020 01:35:18
Thingiverse doesn't prohibit posting the CAD file in with the STL but most people don't care to make changes or the person posting doesn't want others to make changes so they don't upload the CAD file. When you see an item you want to modify, the maker's name is on the top of the first picture. Clicking on that name opens an "about" page with a place at the bottom to send a message. Asking for the CAD file would be my method for starting to modify.
Thread: G code sender for grbl
12/05/2020 18:48:13
Take a look at this mill controller. Since all you want to do is move the table of the mill this might work for you. It does need an Arduino Mega 2560 as an Arduino Uno does not have sufficient memory space.
Thread: Die grinder or dremel - relieving cast iron
12/05/2020 10:39:14
Posted by old mart on 11/05/2020 20:36:26:
You can get a cheap die grinder on ebay for much less than your price, and it is ten times as powerful as a Dremel. They will hold carbide rotary burrs up to 3/4" diameter. If you have a compressor, a pneumatic die grinder is even cheaper than an electric one.
The pneumatic one will really eat metal with the carbide burr but be sure to be wearing eye protection and leather gloves as the metal particle as tiny an very sharp. If you get one in your finger it is nearly impossible to see it to be able to remove.
12/05/2020 10:34:21
I can't help you with any app for an Android but I use a Raspberry Pi 3B as the computer to drive my Arduino and have the choice of Universal Gcode Sender or bCNC. They both work for sending the code but I can't get the toolpath to show on UGS while bCNC does. The setup feature in UGS makes adjusting the steps for accurate movement a lot easier than doing it by hand.
