Member postings for Square Peg
Here is a list of all the postings Square Peg has made in our forums. Click on a thread name to jump to the thread.
Thread: What is this tool?
12/11/2020 11:05:08
Think you could be right...
12/11/2020 10:44:18
Thread: Cutting long tapers using homemade top/compound slide
07/04/2020 13:20:39
Thanks for the replies, I think I may have a go at making one if I can't find one to buy...
02/04/2020 19:29:41
Posted by Alan Waddington 2 on 02/04/2020 18:41:24:
Posted by Square Peg on 02/04/2020 15:57:26:
Posted by Alan Waddington 2 on 02/04/2020 15:31:36:
Is it a Harrison L5 or L5a ? If so pretty sure iv’e got a genuine Harrison taper turning attachment tucked away somewhere.
It's a new fangled 140...
02/04/2020 15:57:26
Unless im misunderstanding the problem, why not just make a taper turning attachment ?
Cuz I've got no idea how they work!
02/04/2020 14:52:34
I often need to clean up tapered tools for jewelers and silversmiths and am limited by the 3" of travel on my topslide. I was wondering if making a longer top slide was a viable solution. I was thinking of powering the slide by using a small 3-phase motor and VFD. It seems simple enough but was wondering why nobody seems to use that method.
Thread: Outside jaws for Pratt 160mm 3 jaw chuck
20/03/2020 11:02:29
Close but no cigar! Thanks for looking. Home and Workshop have a set for a reasonable price so I'll have to bit the bullet. What's really annoying though is that I have 2 of the jaws, the third was missing when I bought the lathe.
Thread: New member from north Wales
20/03/2020 10:47:32
I have a top of the range rolling mill but i'm limited by its max opening of 6mm so I may make a bigger one. I like your punch jig, i may copy that idea but modify it to work under a fly press, one of my fave workshop tools.
19/03/2020 20:39:17
Hi, I'm not a model maker but joined the forum anyway as it contains many fellow metal workers who I can learn from. I am a toolmaker who makes new tools for silversmiths and tinsmiths e.g. planishing stakes, snarling irons etc. I use my lathes, mills etc to make tooling for my homemade hydraulic press.
Cheers
Bob
17/03/2020 18:33:43
Thanks for looking Howard.
17/03/2020 16:08:20
Hi Chris, I'm in north Wales...
17/03/2020 11:35:34
I'm after a set of outside jaws for my Pratt 1213 160mm chuck. For the price of original parts I can buy a new (not original) chuck and back plate. Suggestions?
Cheers
Bob
