Here is a list of all the postings Frank lyszkiewicz has made in our forums. Click on a thread name to jump to the thread.
Thread: New to this Site |
12/02/2020 15:37:20 |
Hi all I hope you are all having fun make your projects I am a from wigan I joined a supple of weeks back to ask for some help with a acme nut on a Mitchell lathe I perches in December and was offered help and advice straight away and Pete Rimmer offered to make one for me and did a first class job witch as been refitted to the lathe and as on play in it spot on. it's good to know there's still some gentlemen out their Frank Lyszkiewicz |
Thread: lefthand acme thread |
11/02/2020 20:13:38 |
Fitted the new nut pete rimmer made for me and couldn't be happier it fitted like a glove absolutely no play in it first class work Thank you very much for your help and to all for their advice Regards Frank |
28/01/2020 21:22:17 |
Thanks howard, mart and for your help Regards frank |
28/01/2020 18:09:26 |
Hi all these are some pic of the screw and the acme nut as you can see in the second pic it is badly warn |
28/01/2020 18:06:15 |
28/01/2020 07:32:29 |
hi all sorry its 7/8ths major diameter not 7/16ths as I stated earlier |
28/01/2020 01:23:45 |
Hi I'll post some pic with mesurment's and check that I've got it right to be on the safe side. P's I work night's that's why my response's area a bit delayed thanks |
27/01/2020 21:25:28 |
Hi thanks for the the help it's a 4 t.p.I for a 7/16th's rod I contacted A couple of places but some didn't do them and other would only Do them in bathes that would cost around £900 to a £1000 I've checked the rod and there's no visible ware on it the nut is very badly warn though
27/01/2020 19:45:25 |
hi all I've purchesed a Mitchell lathe but the acme nut is badly warm I've tried to find a engineers to make one for me but with no success I live in wigan and would appreciate any help in finding someone how can make one regards frank |
Thread: Newby machine help please |
09/12/2019 04:36:48 |
Hi Marc iv'e got a Mitchell there should be 12 gears in total one each of 30, 42, 44, 45, 46, 48, 57, 60, 63, 80 and two of 40, if you need a copy of the manual I can photocopy it for you regards frank |
