Member postings for AJAX
Here is a list of all the postings AJAX has made in our forums. Click on a thread name to jump to the thread.
Thread: Vintage Portmac vertical milling machine
04/10/2021 21:25:11
The well-known Lathes website states the following:
the spindle accepted standard dead-length Crawford collets (1.5" long with capacities ranging from 1/8" to 1/2" )
Is this something I could obtain without selling a kidney?
Edited By AJAX on 04/10/2021 21:25:33
04/10/2021 21:23:17
Posted by Michael Gilligan on 04/10/2021 21:02:23:
Very useful looking little mill
Z axis adjustment looks interesting … presumably it is this ‘BC’ model: **LINK**
http://www.lathes.co.uk/portmac/
Yes, the Z axis is "interesting" but it seems to work very well. I've only tried it for a couple of test cuts but I rather like it already. Unlike most older machines I've owned, this one appears to have very little wear.
I read the same webpage which mentions the "BC miller" but I wonder where the author gets that name from. Mine has various names on the castings including VM20 and VM4.
When I Google "Portmac" all I get is Apple Mac computer ports!
04/10/2021 21:14:26
Posted by Dave Halford on 04/10/2021 20:46:04:
You only need 6 collets to cover all the relevant cutter shanks.
1/4" 3/8" 1/2"
6mm 10mm 12mm
Having just checked what I actually possess, I need to correct what I stated earlier. I have one each of 1/4", 3/8" and 1/2" collets. The milling machine also came with a good amount of end mills -- I'd guess at about 100+ which should keep me going a while.
I don't have any metric collets, which may or may not be a problem.
04/10/2021 19:04:50
I'm now the proud owner of this suitably vintage milling machine and apart from the colour (which may or may not suit your taste) it appears to have been very well cared for and cuts surprisingly well. I've taken a few test cuts using 1/2" end mill in mild steel and the cutting was smooth and clean, something I didn't really expect as I'm used to a much larger machine (3 HP SEMCO at work).
20211004-184440 20211004-184707 20211004-184748
The machine does not use a draw bar and I'm unfamiliar with the collets which I'm guessing may be difficult to source. It came with quite a lot of tooling including a few 1/4" and 1/2" collets. For smaller tooling I'm wondering about making some custom tool holders with a fixing grub screw (grinding a flat on the tool).
All comments welcome (including what colour I should paint it).
Brian
Thread: MES Kennett tool and cutter grinder
04/10/2021 18:41:15
I recently purchased a part-completed Kennett tool and cutter grinder. It seems to be mostly complete apart from missing a few adjustment screws / stops and a couple of tool holders. It appears to have all the paperwork and drawings so should be relatively easy to finish.
Quite by chance I have a spare Parvalux 1/6 HP 2800 RPM motor but I still need to turn a new pulley for the motor and spindle. Should I follow the original specification (presumably for a round belt) or would it be advantageous to try something else? I will of course be keeping the pulley ratio unchanged.
The grinder (or rather, box of grinder parts) came with a number of grinding wheels some of which were damaged. The obviously damaged ones have been binned but I'm also considering what to do with the others; I realise the safest option would be to bin the lot. If buying replacements, should I consider diamond wheels rather than regular abrasive wheels?
Up until last week I always sharpened lathe tools off-hand on a small bench grinder but in addition to the Kennett I also picked up another grinder fitted with a diamond wheel and the finish is incredible.
Does anyone have drawings for a wheel guard and/or suggestions of how one could be made and fitted to the Kennett?
I can post photos if anyone is interested.
Thanks,
Brian
Thread: Saving the Planet … or is it ?
26/09/2021 18:20:32
Posted by duncan webster on 13/09/2021 18:20:44:
I'm not rich enough to shop in Waitrose, so it doesn't apply to me.
I bought some heavy duty bags from Lidl about 7 or 8 years ago. Still using the same ones now. They might just turn out to be bags for (my) life.
Thread: Twinner Multi-Jigset (what is this tool for?)
25/08/2021 11:50:59
This may help. I found the clamps sold as a complete set with other parts. I'm still unsure about its purpose.
https://www.ebay.co.uk/itm/Vintage-Twinner-7-Piece-Multi-Jigset-N0-1-Original-Case-Ross-Ptners-London-/203483106221?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=710-127635-2958-0
25/08/2021 11:40:30
Posted by Mike Hurley on 25/08/2021 09:03:10:
to me these look like adjustable tools to set things over a certain amount. I would think that a range of different jaws would have been available to suit the job in hand, the screw thread is fine adjustment for amount of ' throw ' and the lever actually closes the jaw and provides the set.
I'm thinking here typically of the tooth set on either hand saws or circular saw blades. I have a similar ( but more compact type ) for just this purpose - called a saw set and made by Eclipse. The types in the photos would possibly just be more versatile versions of this?
regards Mike
Thanks Mike. I assumed it was some type of mechanics tool but you may well be right.
25/08/2021 11:38:41
Posted by not done it yet on 25/08/2021 07:29:16:
IF it sells, or you could get another one, on sbay. Good bargain for a couple of clamps for a quid
I don't think anyone would be foolish enough to pay so much for these clamps. Of course, if anyone happens to know such a fool then feel free to put them in touch!
Thread: Oil Dauber
24/08/2021 22:37:06
Thanks - I had previously wondered what that hole was for. Seems like a matchstick would perform just as well as a "dauber".
24/08/2021 22:30:02
I bought a pair or matching clamps from a local car boot sale. 50p each. Three of the jaws are missing (easily replaced) and I don't have an immediate use for them, but they have an excellent clamping action and appear well made.
Before I consider re-purposing or modifying them, does anyone recognise them or their original use? They are marked Twinner Multi-Jigset and 2195.
20210824-123308 20210824-123344 20210824-130051
The only "information" I can find via the Internet is a number of sellers on eBay trying to sell them without any apparent knowledge of what they are for.
Thread: Corbetts Little Jim Lathe restoration - newbie needs advice
02/08/2021 20:55:18
Posted by Andy Thompson 3 on 06/07/2021 14:55:22:
Duffer, Ady1 - I have done domestic electrics and repaired things for decades so reasonably confortable. Earth continuity is fine, insulation is fine and circuit is RCD protected.
Not wishing to doubt your abilities (or in any way suggest mine are superior to yours), but how did you check the insulation? With a multimeter, or do you have a Megger-type 500/1000V insulation tester?
Thread: Rebuilding car trailer and welding/bolting galvanized frame
27/07/2021 23:24:56
Posted by Robert Atkinson 2 on 27/07/2021 19:54:47:
Doing substantial modification to the trailer i.e. from tent to load carrying would almost certaintly require an new inspection and approval. Many will say "not a problem". Howevert if you get stopped (trailers are often stopped due to level of theft) or have an accident they won't pay your fine or take the point for you... Insurance may be an issue too if you have an accident. If another car is damaged they have to pay the third party, but that does not stop them coming after you to get it back if you had a un inspected trailer.
Up to you to decide on the level of risk you are happy with.
Robert G8RPI.
Thanks for raising this point - it's always worth rechecking.
This page (screenshot below) looks like it might be useful, but none of the linked sections/pages refer to trailers.
trailer1
https://www.gov.uk/vehicle-approval
The next page (screenshot below) appears more useful but I suspect it may apply only to large goods trailers and not small trailers of O1 class.
trailer2
https://www.gov.uk/apply-vehicle-test-certificate-lorry-trailer
Perhaps the best way forward will be to phone an approved test centre to confirm what rules actually apply.
Edited By AJAX on 27/07/2021 23:26:45
27/07/2021 23:10:26
Here is something that may also be of interest - the inspection costs (which I do not believe are required in my case) seem quite reasonable.
trailer-inspection
source - https://www.gov.uk/government/publications/individual-vehicle-approval-inspection-fees/vehicle-test-costs-trailers
Edited By AJAX on 27/07/2021 23:11:02
27/07/2021 23:02:33
For anyone taking an interest in this thread (and wondering whether their trailer would pass inspection) I found the official IVA inspection manual quite useful.
27/07/2021 14:12:34
Posted by pgk pgk on 27/07/2021 13:20:39:
I recently replaced the rotting wood base on my farm trailer with salvage steel 'planks'. 2 coats of farm oxide appear to have given it a surprisingly durable finish. Also discovered that the stuff can be sourced in a rainbow selection of colours with minimal prep.
pgk
Sounds good for your application, but maybe too heavy for my needs.
27/07/2021 14:11:30
Posted by Nigel McBurney 1 on 27/07/2021 12:19:49:
I would not weld to a galvanised chassis,welding and zinc do not mix,when grinding the zinc coating off I have found that the zinc appears to have penetrated into the base steel and it takes further grinding into the base material to get clean material,this is ok with say 10mm thick plate,but the welding will still spit and bang occasionally,so use bolted construction and only drill holes into the centre line of the channel, do not drill the flanges of the channel,it will serious ly weaken them, If you are converting to a box trailer the way to stiffen the trailer is to make sides from angle iron ,welded at the corners then fill the frame with 12 mm ply and make it a really tight fit so that it becomes a girder section, on light trailers the weakest point is where the trailer "box" meets the drawbar and it may pay to to add some plate to the channel section drawbar , make sure the wheel bearings are well greased and get a spare wheel nearly all trailer problems are old tyres and bearings failing. Also make sure that you inform the car insurance company that you have a tow bar fitted,they are regarded as accessories. some time ago I checked with Direct line about my Discovery ,although it had been fitted from new with a towbar Direct line needed to know,as they regard it as an accessory and must be declared,and updated the policy though there was no extra cost .
Thanks, that's just the information I was looking for. I'm now suitably put off the idea of any welding on the trailer chassis.
For reference, most of the trailer is made from U-section galvanized steel, 1/8" thick. Actually, "U-section" may be a misnomer as some has another rolled edge for stiffness. Most of the bed is constructed from 2.5" x 2" and the A-frame (bolted onto the chassis) is built from 3.5" x 1.5".
Now that you have put doubt into my mind, I will phone my insurer to check...
27/07/2021 11:42:12
One thing I might mention is that after collecting this trailer with my existing lighting board, I realized that due to it's width (over 1.3 m) the lighting requirements are different to a smaller box trailer - e.g. fog lights are required, side reflector requirements, etc. Braked trailers manufactured after October 2012 also require a reversing light, which I think would be a good idea for this trailer, but perhaps not a legal requirement as I suspect it is older. In fact, since checking these rules I'll have to take another look at my nearly 50-year-old "skip" trailer to check that it is road legal.
27/07/2021 11:31:13
Posted by Nicholas Wheeler 1 on 27/07/2021 08:04:20:
Is it really worth using a trailer tent frame? They're even flimsier and smaller than a caravan, which are are virtually useless once the body woodwork rots away. The suspension and wheels on trailer tents tend to be the lightest components available too.
I say this having recovered the wreckage of several such things that weren't up to the job they were being used for.
All valid comments and I agree that some caravan / trailer-tent frames are unsuitable for conversion, but this one seems adequate for my needs. With some modification, mostly a small amount of bracing, a flat deck and some hold downs, I think it will be adaptable enough and safe to use. I plan to fabricate some bike / kayak / material carriers that can be added/removed between uses.
This trailer frame is plated 650 kg max gross weight. I don't know whether this assumes some structural integrity from the tent box framework which has been removed, but I don't plan to go anywhere near this weight.
The Al-Ko axle and 145R10 tyres seem more substantial than most I've seen on small box trailers (e.g. Erde) with the added bonus of a working brake system.
Of course, I could be wrong!
Brian
27/07/2021 11:11:22
Posted by Dave Halford on 27/07/2021 10:11:43:
Your trailer will be plated for the weight it was as a trailer tent and no more, don't add so much weight that you can't carry anything in it.
Thanks for raising this, but I expect it to be well within the limit. The trailer (Conway Products Ltd, model number CDX/93) is plated 650kg maximum gross weight and appears substantial enough for my intended uses which will mostly be limited to carrying bulky but not particularly heavy items (e.g. kayak, family bikes, sheet materials, fencing posts and rails, etc.) It happens to be braked which is nice, but maybe not essential for my intended uses.
