Charles R | 04/08/2020 12:20:36 |
24 forum posts 15 photos | Can anyone shed light on the purpose of this metric Moore and Wright tool? Looks like a conventional depth mic but has the scale going in the opposite direction. |
Nicholas Farr | 04/08/2020 12:46:53 |
![]() 3988 forum posts 1799 photos | Hi Charles R, could just be a micrometer head fitted to a custom made block which probably fitted to an instrument or machine for setting procedures. Does it have a number on the thimble? Regards Nick. |
Clive Brown 1 | 04/08/2020 13:22:50 |
1050 forum posts 56 photos | Agree with Nick. The standard M&W depth mic. had a rather more shapely block. |
Mike Poole | 04/08/2020 14:00:38 |
![]() 3676 forum posts 82 photos | The micrometer parts are available for use on custom jigs etc. They are handy to make into a special purpose mic should you ever develop the need for one. Mike |
Clive Foster | 04/08/2020 14:01:28 |
3630 forum posts 128 photos | That style of micrometer head an bock is frequently found on the micrometer adjusted slides / carriers used with optical benches and tables. Usually two counterbored holes to fixt it. Clive |
Charles R | 04/08/2020 20:26:32 |
24 forum posts 15 photos | Posted by Nicholas Farr on 04/08/2020 12:46:53:
Hi Charles R, could just be a micrometer head fitted to a custom made block which probably fitted to an instrument or machine for setting procedures. Does it have a number on the thimble? Regards Nick. Hi Nick...think you may well be correct and there's no M&W model number on the thimble. |
Charles R | 04/08/2020 20:30:18 |
24 forum posts 15 photos | Posted by Clive Brown 1 on 04/08/2020 13:22:50:
Agree with Nick. The standard M&W depth mic. had a rather more shapely block. Hi Clive...I thought the same myself about the unshapely block, which incidentally measures (exactly) 1/2" in depth. |
Charles R | 04/08/2020 20:31:24 |
24 forum posts 15 photos | Posted by Mike Poole on 04/08/2020 14:00:38:
The micrometer parts are available for use on custom jigs etc. They are handy to make into a special purpose mic should you ever develop the need for one. Mike Hi Mike...didn't realise that and thanks for info. |
Charles R | 04/08/2020 20:33:52 |
24 forum posts 15 photos | Posted by Clive Foster on 04/08/2020 14:01:28:
That style of micrometer head an bock is frequently found on the micrometer adjusted slides / carriers used with optical benches and tables. Usually two counterbored holes to fixt it. Clive Think you may have hit the nail on the head Clive, as there are indeed 2 small counterbored holes in it. |
Charles R | 04/08/2020 20:35:58 |
24 forum posts 15 photos | Also, it's different in that it reads in the opposite direction to a normal depth mic, plus it's only graduated to 13mm. |
