Member postings for old mart
Thread: Backplates
09/10/2022 15:45:02
A directly screwed on chuck will normally save a bit of overhang adding slightly to the length of the bed, useful on smaller machines.
As Andrew mentions the drawback of directly threaded, I bought a NOS Toolmex 6" four jaw independent lightweight chuck threaded for Myford. The centre got bored out to max size and a Smart & Brown 1 3/4" threaded backplate fitted. Myford lovers will be issuing a fatwa against me now.
Edited By old mart on 09/10/2022 15:51:49
Thread: Fine feed carriage stop starts!!
09/10/2022 15:41:07
Seems like everything has been suggested, but I would check if the leadscrew rotates smoothly by itself without any end float and shows no sign of being bent. You could try different leadscrew gears if you have any and see if the pitch of the banding changes. Suspicions of the pitch of the leadscrew matching the banding have already been posted.
Keep us up to date with results as you go, the information is valuble.
Thread: Would you chance it - bluefox tools MT4 alignment bar
08/10/2022 20:50:56
I have two of Indian origin,a 7 1/2" and an 11 1/2", both with a MT2 end. After turning a 60 degree end on a steel 3/8 bolt in situ and checking between centres, the results were dissapointing, over 0.0005" tir. Then I realised my mistake, using a live centre in the tailstock. With a dead centre, the runout was affectively zero using a Baty 0.0001" DTI. And that was either way round for both bars. There are lots available now, including plain cylindrical ones. I don't know which company made them or even if they come from the same one.
Thread: Expanding mandrels.
06/10/2022 21:21:13
One of those tools which I will get around to making one day. I had to make one once, but it was a special shape and not much use for general holding.
Thread: Through spindle stick out...
06/10/2022 21:16:12
When our factory was in Guildford, there was a large early type cnc lathe and the guy operating it put an 6 foot length of 2" diameter aluminium in it without a bar feed and turned up the speed. The 4 feet overhanging the headstock bent and hit his toolbox and everything in it embeded in the ceiling about 25 feet above. Just as well the lathe weighed about 5 tons, it survived the hilarious incident. When the building was demolished, somebody might have found some tools. The lathe was sold and ended up in India.
Thread: If anyones in need of an angle grinder
02/10/2022 19:58:03
I have just googled "Bosch X lock" and now realise that the discs are indeed proprietry. I would guess that Bosch are hoping that other manufacturers will take up the system, rather like SDS which is now a standard. There were plentiful supplies of the X lock discs available, but not much chance of getting one of the bargain grinders from Screwfix, there seems to be no stock left. Makes me suspicious that the whole X lock system is a dead duck about to become extinct, seeing the price.
Thread: Galvanitic/electrolytic reaction
02/10/2022 19:44:40
Probably the flanges are a slightly different alloy composition, and higher up the electrochemical series.
Thread: Back gear cluster now removed
02/10/2022 19:41:16
When you get the lathe repaired, you may be able to get hold of one of the 3D printed gear locking devices to fit on the large gear nearest the front of the spindle. Using one of these spreads the force of unscrewing the chuck over many teeth. No more broken teeth. The lathe model and number of teeth on that gear would be required before ordering one.
Thread: DIGITAL CALLIPERS @ LIDL
02/10/2022 19:31:20
The rough movement of the more recent ones is the problem, the slideways look like they have been hand ground by a monkey.
Thread: What to do with a sticky (as in toffee) portable radio
02/10/2022 19:27:16
Most of the trouble I have had is not with the hard plastic parts, but the soft rubbery handgrips deteriorating. Sponge can also turn into nasty sticke powder, linings of Mitutoyo and Moore & Wright instrument boxes come to mind, plus light sealing in film cameras.
Edited By old mart on 02/10/2022 19:28:17
02/10/2022 19:18:07
Posted by vintage engineer on 01/10/2022 21:26:14:
I soak parts I have silver soldered in boiling water to remove the flux.
Thats what I was taught to do, no acids and should only take a few minutes, just a wire brushing before rinsing and drying.
Edited By old mart on 02/10/2022 19:19:05
02/10/2022 19:14:09
I have just remembered the term for the dished discs, it is "depressed centre", easy to get hold of. My old Royobi uses them and can manage 125mm as well. A quality machine made in Hiroshima, not China, and not at all radioactive.
02/10/2022 19:02:53
Ady, what do you think of the quality of your new calipers?
Edited By old mart on 02/10/2022 19:03:07
02/10/2022 18:07:46
I have never heard of an angle grinder that uses non standard 4 1/2" discs. Normally there are only two types of this disc, the plain and dished which are freely available.
02/10/2022 18:00:28
I wonder if anyone has bought two gears of the correct specs and joined them together to make a cluster?
02/10/2022 17:54:08
I noticed that, but I already have 3 of them and there is something that I have noticed also. The first one is still in use, excellent value, but the successive calipers bought about 3 years apart are mechanically inferior, while being electronically more advanced. That was enough for me to transplant the reading head from the last one into the body of the first. They are not in the same class as my Mitutoyo or Tesa, but only a fraction of the cost.
Thread: Machine tool dealers in the south
30/09/2022 17:49:38
How about Warco, about 11 miles South East of Guildford Surrey.
Edited By old mart on 30/09/2022 17:53:23
Thread: Ideas on how to form the joggle plate for a small tool makers clamp
29/09/2022 16:51:40
Why not a washer under a flat plate?
Thread: Which Stuart models can be done on a 7x14 lathe with no mill?
28/09/2022 21:12:43
I have a 7 x 12 which I bought second hand with a vertical milling attachment. This didn't work well mainly because the attachment was not on the centreline of the spindle, being attached where the compound fits. I have seen ready made adaptors on ebay which address this offset problem which would allow milling up to about 3" to be done
Thread: Star or Delta
28/09/2022 20:58:50
Probably not, I thought star was for 440V and delta for 240V, no doubt the experts will enlighten us.
