Here is a list of all the postings Adrian Harrison has made in our forums. Click on a thread name to jump to the thread.
Thread: Practice facing |
03/01/2019 23:12:43 |
Thread: Surface finish |
03/01/2019 18:20:50 |
Posted by larry phelan 1 on 03/01/2019 17:25:14:
Not sure that you need much more speed for screw cutting ?? not for screw cutting no but for turning |
Thread: Thanks for the add |
03/01/2019 16:55:17 |
Posted by Brian H on 03/01/2019 08:12:08:
Welcome Adrian. My first lathe was also an 'M' type Drummond and I had many happy hours on that making things. You will find information about your lathe here; http://www.lathes.co.uk/drummond/index.html Brian Thank you for that link Brian and that traction engine you have in the picture looks amazing!
03/01/2019 16:52:54 |
Posted by David George 1 on 03/01/2019 08:20:51:
Hi Adrian I have an M type lathe like you although i have done a few mods to mine like just pluging the first jole in the bed to prevent small parts disappearing to fitting a quick changed toolpost. It's worth having a look in my photos to see results and ideas.
David HI David, i really like the look of your M type so I'm sure i will be asking you some questions as i can already see a few modifications I would like to make to mine.. That plug is a really good idea and one i will do this weekend.. |
03/01/2019 16:46:30 |
Posted by "Bill Hancox" on 03/01/2019 05:19:02:
Welcome. Just one piece of advice. Before you power up, thoroughly check it for freedom of movement. Do your best to find a copy of the owners manual. Buy a good training manual, if necessary one for any lathe of comparable size. The manual will provide you with generic safety and operation information. My learning curve took about 6 months. Good Luck. Hello Bill, I diid go over the lathe with some good quality oil and checked everting was moving as it should be before i turned the motor over.. I did find the back gear would not stay engaged but thats now not a problem after some good use.. |
03/01/2019 16:37:23 |
Posted by Mick B1 on 03/01/2019 09:37:36:
Posted by Adrian Harrison on 02/01/2019 21:50:01:
... ...but I'm thinking my lathe being an older 3 speed pulley just is not fast enough
With a decent HSS tool, there's practically no such thing as not being fast enough. Sometimes finishing and screwcutting is done at speeds of 10 M per minute or less, or even by hand-rotating the spindle or chuck for some tasks. Screw cutting, now there is a discussion! |
03/01/2019 16:33:44 |
Posted by Ady1 on 03/01/2019 09:09:29:
I made my own live centres, one of my first projects Bought a pack of cheap bearings from ebay for the job, they aint brilliant but I still use them 10 years later Buy a DTI with a magnetic stand for 20 quid, you'll definitely need it before long Enjoy and GL Edit: I did a headstock stripdown here. Take your time and enjoy the learning of new skills Edited By Ady1 on 03/01/2019 09:13:52 thanks for the link Ady1, just about to sit down with a morning coffee and read the whole thing..
03/01/2019 04:48:30 |
New member from Canada BC, I bought an older lathe two months ago which is an m type Drummond.. Really happy with what I bought and now I just need to learn how to use it 😁 |
03/01/2019 04:44:31 |
I will order that book tonight and I'm sure I should have a knife tool in all the hss tooling that came with the lathe |
03/01/2019 02:42:38 |
Thanks for all the replys much appreciated, I will start tomorrow buy adjusting the head stock bearings.. I will also buy a live center as I only have a dead center at the moment.. The k you Hopper for explaining how to adjust the head stock bearings |
02/01/2019 22:05:53 |
what is the best tool profile for what i am trying to do?
02/01/2019 21:50:01 |
I will try a bar stock that i have tomorrow on the lathe and see if thats better.
Thread: Cross slide tool |
02/01/2019 21:36:33 |
the handle is a about the same hight as the one in the picture..
02/01/2019 21:07:26 |
I bought an older Drummond m type lathe a few months back and i am having problems with getting a good surface finish.. |
Thread: Atlas shaper |
02/01/2019 17:10:37 |
people are buying these again so don't scrap it
02/01/2019 16:24:09 |
this is another tool that came with my lathe that looks like it was made to bolt to the cross slide.. would this be a radius cutter?
Thread: what tool is this? |
02/01/2019 16:15:24 |
thank you everyone for the input.. yes I am now starting to think it was a puller or pusher for a one off job.. |
02/01/2019 05:48:08 |
this tool came with a lathe that i bought a few months ago and i am trying to find out what it is used for?
