Here is a list of all the postings Tomek has made in our forums. Click on a thread name to jump to the thread.
Thread: Stuart boiler feed pump |
13/03/2019 18:15:25 |
Drawings calls for 2 holes 5/32 x40tpi at distance 3/16 from the cylinder end. It doesn't show any groves from the bore side. Appreciate that you mention this it might save me a lot of head scratching later on trying to work out why the pump stopped. |
13/03/2019 07:40:31 |
You're right. As for the bottom holes it wouldn't be a big problem the top ones are going through the valve bore and a bit of excess adhesive could do a mess and affect valve movement. Tap and thread it is then. Thanks for your help |
13/03/2019 07:24:03 |
Thanks Jason. I thought that thread will be a safer option. Wouldn't like to see these little pins leaving holes under pressure and flying towards my face |
12/03/2019 20:54:48 |
Hi all! I'm currently building stuart boiler pump and got stuck on the steam chest. On attached photo you can see that some of the steam passages need to be drilled through from outside and then blanked. What would be the best way to blank this 1/16 holes? Steam chest is gunmetal casting. Should i turn small brass pins slightly oversize and push them in? Or should pins have small taper? Another idea is to tap these holes 7 or 8BA and screw pins in. Would loctite be of any help and withstand the temperature? Any suggestions please?
Thread: Beginners new build questions |
27/09/2018 21:31:03 |
Cheers, will definitely look into this. Well i guess it's time to start shopping for castings ![]() |
27/09/2018 08:49:50 |
Thanks everyone for these useful informations. I have found plans before on John-tom website and also manage to find few Model Engineer issues with Juliet articles on Ebay. Jan I didn't realise that drawings can have faults. Obviously errors always happens but I thought these would be corrected by now after so many years. And hats off for building loco without castings, that would probably take me ages ![]() ![]() |
26/09/2018 21:55:59 |
Bob thanks for comment on drawings. Rob Roy would be my second choice but I was worried that 0-6-0 chassis wouldn't take a sharp curves (my garden is about 26 feet wide) not sure what is minimum radius for 3 1/2 but Juliet will manage that. Good tip with joining club. There is actually one nearby and I really should visit them one day. I know they do a public running every Sunday so maybe pop in and have a word with members. Cheers for all replies and if someone could comment on quality of castings from different suppliers that would be great. Thanks |
26/09/2018 20:20:40 |
Thanks for your reply Neil. I didn't know there's alternative boiler for this loco. And I will look for a copy of the book you mentioned. Cheers |
26/09/2018 12:16:21 |
First of all hello to all forum members. I'm new to the hobby with only little experience so far but after successfully completed few stationery engines i would like to try building a steam locomotive. I was searching for answer which loco would suit me the best and i think 3 1/2 gauge Juliet would be my choice. I could run it in my back garden and castings are cheap enough so even if i make major mistake while machining, replacing a casting with a new one won't hurt as much as it would with 5 inch gauge. I also decide to go for Baker's valve and yes I know Stephenson's would be much simpler but I just love the look of all moving parts on the outside, so Baker's it is I would appreciate if some of the members could share opinions and give a bit of advice maybe. First question would be: where to buy drawings from? Blackgates and Reeves drawings are both 7 sheets where GLR Kennions only 6 and only half a price of the first two? Why is that? Am I missing something? Would let say Reeves drawings be more detailed than GLR? Other thing is where to source castings from? What is your experience about service from different suppliers? Will castings from one be better quality then the others? And finally is there any book describing building a Juliet? I know about ME articles from 1947 and i'm lucky to own some of them but there's lot of referring to previous builds like "machine part as described for Lassie" or "do something as per Lassie notes" and obviously it would be easier to buy one book than collecting dozen of magazines. It's going to be a long time project as i can only spare few hours a week, but certainly any advice from forum members will speed up a build so any comments much appreciated. Thanks!
