Member postings for David Davies 8
Here is a list of all the postings David Davies 8 has made in our forums. Click on a thread name to jump to the thread.
Thread: Hydraulic Copying Attachment - Micrometer Adjustment
30/04/2020 12:41:51
Gents
The patent says: the depth of cut is adjustable by moving the fulcrum axis 5 of the lever 4. Does this mean that by changing the fulcrum the setpoint going to the summing junction is reduced so that the travel required to achieve a null position is reduced?
I'll get my coat!
Thread: Carriage movement varies along the bed
28/04/2020 12:57:48
Cai
the gib strip is on the side of the carriage and adjusted with four screws which are fitted with locknuts. I believe what you refer to as being underneath is the retaining plate which is adjusted with shims.
Pinning the gib strip as suggested above by ega will stop it riding up on the points of the adjusting screws which will reduce the running clearance.
HTH
Thread: Myford dividing head enhancements
25/04/2020 09:07:09
I have almost completed an adaptor to hang a Myford DH off the tail end of my Boxford CSB. It is essentially as the one referred to above in the BHI Journal. To get the DH at a sensible position I chose to support it from the banjo spigot on the LH lead screw bearing via an arm locating on a plug fitted to the DH over arm socket.
HTH
Thread: Blot On The Landscape
25/04/2020 08:52:24
Double decking:
The Southern Region of BR ran two sets of DD EMUs from the early Fifties to 1971. They were not true DDs but split level to work within our cramped loading gauge. Apparently the turn around time for station work was greater as the number of doors in the stock could not be increased whilst maintaining the greater capacity.
Ironicaly the Great Central referred to above was built to the continental loading gauge. What a shame it was a victim of Beeching,s axe.
24/04/2020 20:19:18
Marples (Beeching was only carrying out orders) believed his motorways should carry the freight so the Great Central disappeared and the Settle and Carlisle nearly followed.
Ernest Marples, as well as being Minister for Transport had his own road construction company. I wonder why he was so keen on motorways?
Thread: Boxford change gears for screwcutting.
24/04/2020 12:39:30
Hello Terry
Harold Hall has a page on his website which may help you, it gives all the possible changewheel selections for a given pitch based on a 5t step in wheel teeth. This may have been derived from NthreadP but only Harold could answer that.
HTH
23/04/2020 21:37:25
Hello Bob,
those rods are neat! I realise that the Humber is not a very high powered bike but do you need to nitride them after you have finished the machining? I once saw a set of rods destined for a 1760cc Ford X flow that had been shot peened - they had a surface not dissimilar to a golf ball. The engine ran ok though!
Cheers
Thread: Boxford handwheel handles
17/04/2020 22:56:15
I always thought that CSB stood for College, School and Borstal! I get reprimanded if I spend too much time on mine. I have two, both 1958 models and both modified with a B type apron.
stay safe
Thread: Large Crane
04/04/2020 23:45:27
Peter
one wonders how such a crane can perform lifts as it looks capable of doing without rolling. It would be interesting to know how a stable counterbalance is achieved.
thanks for posting!
Thread: The Manley Ventilator
15/03/2020 07:14:49
PGK
This link took me down a very interesting route which lead to the inventions of John Blease. It was amazing to read that although not a doctor he had acted as an anesthetist on one occasion! Dr Manley subsequently joined Blease's company.
Cheers
Thread: The Workshop Progress Thread 2020
26/02/2020 11:49:25
NIcely done, Duncan.
If you want to send me a short description and a few hi-res photos we could feature it in MEW, with due acknowledgement to Joe, of course!
Seconded!
Thread: Adjusting an M&W level
20/02/2020 06:44:28
Robin
I was recently given an ELM level which is a 12" version of the ELS. It had a broken vial. I removed the old vial which was held in by a potting compound similar to Polyfilla and am about to rebuild it with a vial obtained at a very reasonable price from Cromwell tools (I have no connection). Each end of the vial holding tube has two vertical screws, one screwhead inside the end plug of the tube, the other beneath the end of the tube. both have access holes for an allen key.The lower of the two screws acts as a jack for calibration, the upper one is a securing screw. To calibrate, the securing screw is released and the jacking screw is adjusted as required. I haven't done this yet but my understanding is that the level is calibrated by obtaining the same deviation when the level is swapped end for end on a flat surface. Once done, possibly over many iterations, the securing screw is tightened and a final check is made.
HTH
Thread: 1/4" BSF v 1/4" CEI
03/02/2020 20:49:34
I had a 1961 BSA A7 500 many years ago, that had cycle thread fixings all over the engine. The barrel to crankcase studs were 3/8 Whitworth into the alloy cases and cycle thread where the stud passed through the barrel base flange. I cleared out the local bike shop's stock of 3/8 nuts during the rebuild.
Thread: Bench grinder troubleshooting
03/02/2020 11:11:36
Gene
I have used Dow Corning 736 silicon sealant to secure winding tails after digging around for star points on 3 phase motors. This has a max temp of 315 degrees C.
As an aside I also used the same product to re-secure/seal the glass window of my kitchen oven door. It has lasted over 5 years with, sometimes, an inside temperature of over 220 degrees when baking bread.
HTH
Thread: How to hand grind 55 degree cutter for 32TPI?
03/02/2020 05:41:29
Morning all
Hopper mentions Martin Cleve above: in his book ' screwcutting in the lathe' he describes a simple jig to aid producing a screwcutting toolbit on an off-hand grinder. See pages 123 et seq. l made one and am very pleased with it. It is worth getting a copy as it is a mine of useful information.
HTH
Thread: Why does everyone disagree with you
27/01/2020 11:50:30
Hi All
Following on from Plasma's post above, if you search Google for the 'Dunning-Kruger Effect' and read same, it may explain why some members mock questions asked by others.
Thread: D'Andrea automatic boring head
23/01/2020 18:12:28
Hi Nick
All PDFs downloaded. Thank you very much for your help!
21/01/2020 22:21:03
Hi All
Album showing photos of head added. The head is a TA 120, this signifies that the O/D is 120mm.
19/01/2020 20:45:19
Hi Nick
Thanks for your kind offer.
Thread: Product Descriptions (Up to scratch?)
18/01/2020 21:42:21
Note that for longer work the swing over the cross slide is more important than the swing over the bed.
