Here is a list of all the postings Robert Atkinson 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: Peculiar electrical problem |
26/09/2023 15:54:38 |
Posted by Chris Pearson 1 on 26/09/2023 13:21:46:
Posted by Martin Shaw 1 on 25/09/2023 23:58:17:
Like most properties of the age of mine in a town or city the earthing is TNS. Then I think that you can quite reasonably conclude that your machines are sound. However, with TN-C-S current in the earthing conductor may have nothing to do with leakage so if you find it, you cannot conclude that something is amiss. (And don't forget that even with what looks like TN-S, there may be N-E links nearby.) Hi Chris, Can you please explain your reasoning behind the earthing system making a difference to machine leakage current? I think I'm missing something. Any connection between neutral and earth downstream from an RCD will alost certainly cause it to trip. Robert. |
Thread: 'Thread' clean-up |
26/09/2023 12:33:13 |
Clean the first couplr of turns manually. Bore out a block (tufnol, alloy, wood) to the OD of the post. drill two holw onf pitch apart 90 deg to the bore. fit a pin with diameter = groove width in one and a clean-up cutter in the other. run it up the thread with the guide pin behind the cutter. . |
26/09/2023 08:42:44 |
OK we anre now deviating away from the original issue of LEAKAGE currents of around 0.03 amps (30 milliamps mA) into Mains earthing systems that have to carry FAULT currents of hundreads of amps. The leakage currents form VFDs and similar devices are not due to faults. A resistance of 10,000 Ohms (10k) with 240V (UK mains) across it will cause a current of 0.024A to flow (Ohms law I = V/R). This close to the 30mA trip current of a domestic RCD. !0K is thousands of times higher resistance than a mains earth. Lets forget about earthing systems. SOD. The Fluke picture is not helpful becuase it is addressing using a clamp meter for it's typical application of mesuring load current not leakage. I can design a vey simple means of detecting leakage current. A current transformer with two primary windings one carrying the current in the line the other tha current in the neutral. Oh wait that's a current clamp meter around live and neutral. It's also what is built into most electrical installation meters. As for finding where the leakage is that is not difficult given a sensitive clamp ammeter. First measure and note the leakage current by placing the live and neutral in the jaws of the clamp meter. As an extension to the testing, it is also possible to tell how much of the leakage current is due to the filters in a VFD or similar. To do this you need a phase sensitive current sensor. As the filter leakage is due to capacitors the current is ninety degrees out of phase with that caused by "normal" resistive leakage. I've designed this sort of equipment. An example is protection of the high current feeder between a generator and a circuit breaker panel without using fuses in the feeders. You just run the feeder conductor through a current transformer at the generator end and another at the load end. Connect the transformers secondaries in series anti-phase to a sensitive current relay. Load current flows through both transformers and cancel out. Any current due to a fault between the two transformers (to neutral or "earth" Robert. |
Thread: MEW subscription renewal cost |
25/09/2023 20:20:45 |
The Guidance seems to imply regulation 4 applies in this case (trader-consumer, digital content, direct debit or credit card. Section 13 says discounts to encourage a particular payment method are allowed but the discount must not exceed the actual dfference in costs of the two payment methods. |
25/09/2023 18:04:26 |
I Just got a email about renewing my digital subscription to MEW. The price was given as £48 for a single payment by direct debit. To pay by card or paypal is £52 for the year. How can this be? I thought charging more for card paments was outlawed a few years ago. |
25/09/2023 17:55:43 |
Posted by Chris Pearson 1 on 25/09/2023 12:03:24:
Posted by Master of none on 24/09/2023 23:01:37:
In discussions with Meggar, they recommended using the clamp meter around line and neutral together. A parallel path to earth through an extraneous conductive part (e.g. water pipe, gas pipe or structural steelwork) could reduce the current in the earthing conductor and give a misleading measurement of the difference between line and neutral currents. The clamp meter needs to cover the range 0-30mA. Only: (1) if there are any extraneous CPs (which is seldom the case in modern homes); and (2) the device is attached to an ECP and the fault or leakage is to that. It does not have to be leakage to a conductive (metal) part extraneous or otherwise. An old junnction box screwed to wood and exposed to water will cause leakage current. The RCD senses line / neutral differential current so that is what you need to measure when testing. |
25/09/2023 07:47:01 |
Wot I said.... |
24/09/2023 20:40:47 |
Strangely enough a "cheap chinese" VFD is, barring faults, likely to have less leakage current than a good quaility one. This is becase the cheap ones tend to leave out the EMC fiter capacitors that cause the leakage current.
24/09/2023 19:19:24 |
You don't actually measure thr current in the CPC ("earth" conductor). This is becuse the leakage culd be finding a different path to ground. You do what an RCD does, measure the difference in current between the line and neutral. A clamp meterto do this has to go around the line and neutral. Robert. |
24/09/2023 18:21:25 |
This fault is as already been said almost certainly caused by leakage currents that result from the design and normal operation of the VFD and filers in particular. This higlights the fact that almost all VFDs are industrial devices and not intended to be connected to the domestic mains supply. Robert.
Thread: Milling Advice |
23/09/2023 20:11:47 |
I found this thread interesting as I'm just doing a job that needs a flat surface with a good finish. It is similar to Andrew's application a heatsink for high power semiconductors. This is a aluminium heatsink and as usual with these it is near pure so soft and sticky. It's also used so I have to re-surface it and plug a couple of holes. The original finish was obviously made with a fly cutter. I did consider that approach but my mill is a small high speed model (SX1LP). so not Ideal. I decided to try a 90 degree (two insert) 25mm indexible end / side mill from ARC |
Thread: Single phase speed control - VFD? |
22/09/2023 19:12:16 |
These supposed "PWM" controllers like this one: Are not PWM they are phase angle controllers. They control the average power. At anything over 50% the peak voltage will be the same as the peak mains voltage. They are OK for heaters, incandescent lamps and universal motors. They will work, as previously noted, with fans due to their load charactistics. There are also more "packaged" versions like : https://www.amazon.co.uk/Regulator-Controller-Variable-Electric-Temperature/dp/B0BYSX8QBT/ref=sr_1_18?crid=T2GZU4OP4J8F But it clearly does not meet UK safety standards and the plug is unsafe. Robert. |
Thread: What is a cordless tool? |
22/09/2023 18:41:03 |
A pocket sized 50mm angle grinder - bike thieves must love them. |
Thread: Will this heater idea work |
22/09/2023 18:01:29 |
Posted by Benedict White on 22/09/2023 16:52:00:
Posted by Robert Atkinson 2 on 22/09/2023 16:48:01:
Posted by Benedict White on 22/09/2023 16:18:37:
If you intend on buying kerosene or red diesel, buy it from a petrol station that sells it. You do have to fill in a form. Using it for heating is a permitted use. (For either red diesel or kerosene). About 80-90p a litre. Correct. The problem with Aviation fuel is that it is not marked (dyed) so they can't easilly tell if it is used in a road vehicle (highest taxation class). This means there are stricter regulations and controls on it. The laws were changed fairly recently with more restrictions on reduced duty fuel. You can no longer use it in transport refrigeration units and pleasure boats can only claim a rebate for the portion of fuel used for heating rather than propulsion. Robert. Kerosene isn't marked. It also looks like and smells a lot like diesel. (It will ruin a diesel pump and injectors if you use it for such though). Unmarked kerosine is sold at the full rate of duty. Robert. |
Thread: Measuring instrument storage. |
22/09/2023 16:58:17 |
Chopping boards are generally made from the Ultra high molecular weight polythene (UHMWPE) mentioned by Macolm. Also useful as neutron moderators Robert. Edited By Robert Atkinson 2 on 22/09/2023 16:58:44 |
22/09/2023 16:48:01 |
If you intend on buying kerosene or red diesel, buy it from a petrol station that sells it. You do have to fill in a form. Using it for heating is a permitted use. (For either red diesel or kerosene). About 80-90p a litre. Correct. The problem with Aviation fuel is that it is not marked (dyed) so they can't easilly tell if it is used in a road vehicle (highest taxation class). This means there are stricter regulations and controls on it. The laws were changed fairly recently with more restrictions on reduced duty fuel. You can no longer use it in transport refrigeration units and pleasure boats can only claim a rebate for the portion of fuel used for heating rather than propulsion. Robert. |
22/09/2023 16:04:12 |
Posted by Steviegtr on 22/09/2023 15:26:10:
If you look on youtube there a lot of folk who have fitted the chinese diesel heaters outside of there homes & ducted the warm air indoors with a lot of success. I fitted one to my workshop (i wont put a link to the video on utube ) But it's there. My workshop is 3M x 4M & it gets toasty warm in winter. I spent a total of £42 throughout winter on diesel. That was paying top price for fuel. I have since found the local flying club sells Kerosene much cheaper. It is an alternative that works & a lot of forum members on this site use them i discovered. These are what are fitted to most Campervans. Steve. NO NO, Hell NO!!!!! These chinese diesel heaters are not well made, are not intended for use in dwellings and are not approved for this type of use. Most of them are not properly approved for ANY use. If it burns the house down you will probably find you insurance was invalidated by usin one. Additionally Steve, assuming that the "kerosine" you bought at the flying club is aviation fuel, you have just admittedt to fuel duty fraud on a public forum. I can't see why you would by any other kerosine from a flying club. It is also illegal for them to sell it to you. In contrast I buy Jet-A for my gas turbine engine from a responsible supplier and have to pay the full rate of duty. In theory as I'm using it to test an aircraft engine it should be duty free but the supplier, quite reasonably in my view, say that ANY sale that does not go into a aircraft or ground support equipment on the airfield is charged at full duty. The small number of sales is not worth the effort to ensure that it is not duty evasion given the consequences to their business if it is. If I don't like It I can go elsewhere as far as they are concerned. Robert. |
22/09/2023 12:57:17 |
Hmm, those appear to be 3 Phase output, single phase input VFDs. The OP needs a single phase OUTPUT VFD. |
22/09/2023 12:44:13 |
+1 on Tony's comment on using immersion elements without water. They are designed for fast heating so need the water to control the temperature. Another issue is that solar cells don't work well with fixed resistance loads. For your sand heaters idea you could use some MOSFETs on a heatsink in the sand and a maximum power point tracking (MPPT) controller. Robert. Edited By Robert Atkinson 2 on 22/09/2023 12:44:55 |
21/09/2023 20:38:52 |
You can get single phase VFDs but they are uncommon. This makes them relatively expensive. Most are not suitable for capacitor or centrifugal start motors. Proper details of the motor would be required before anything else can be decided. Are you sure it's not a universal (brushed) motor? that would open up a lot of possibilities. They are common on machines with the motor integrated into them. Robert. |
