Member postings for Terry Chapman
Here is a list of all the postings Terry Chapman has made in our forums. Click on a thread name to jump to the thread.
Thread: Living Van Plans
12/08/2019 15:44:23
Im looking for the same but in 3/4" scale??
Thread: 1" Minnie oil pump problem?
03/06/2019 16:14:49
Hi Jason,how do I check for those please? The rod is ok for sure.How about the rest? Thanks for help BTW.
Terry
Edited By Terry Chapman on 03/06/2019 16:44:22
03/06/2019 15:12:12
Posted by JasonB on 03/06/2019 13:08:15:
What Clive said, as the reverser gets closer to neutral you will get progressively less movement of the valve rod and as that is what drives the lubricator you won't get enough movement of the arm to engage the next notch on the ratchet.
If your engine won't stop then your regulator is letting by
Is that something I could sort? Im an ex mechanic so used to lapping things in etc?
03/06/2019 12:25:15
so if I push the lever forward I can just control with regulator and pump will work ok like that?
The only prob I have is when the regulator is shut the engine slows but doesnt stop completely unless I stop the flywheel manually?
03/06/2019 10:40:50
Posted by Clive Brown 1 on 03/06/2019 10:28:53:
Dunno about the Minnie, but my Allchin water pump drive is off the crankshaft. The lubricator drive is off the valve spindle so the ratchet stroke is altered by the position of the reversing lever. If the stroke were to be too small, the drive wouldn't pick up a new tooth. I can't see that being an issue as the engine won't run with the valve gear in that position anyway. As long as the pump works with the cut-off at a working position., that's OK.
Hey Clive, what do you mean by cut off? Yes.the pump works from the valve spindle and your correct what you say re.picking up the next tooth?
Please excuse my ignorance,so your saying as long as its working with the lever forward or reverse thats ok?
Terry
03/06/2019 08:44:02
Hi, After having a new boiler built for my Minnie,and rebuilding it,I cant seem to get the oil pump to work when the forward/reverse lever is in neutral? When its fully forward or back its fine. Any ideas or is this how it is? Thanks
Thread: laying up an engine
04/11/2018 13:53:09
Ive got a 1" coal fired Minnie.Whats the best way to protect it after cleaning it up etc after firing? I was thinking a light spray of WD 40 through the tubes/firebox etc?
Thread: re seating a ball??
04/11/2018 13:50:28
I done the 'Tap' job and is all fine now thanks
01/11/2018 14:56:47
Posted by RevStew on 01/11/2018 14:39:25:
Brass pin punch onto the ball and a sharp tap with a hammer works for me.
Thanks,Ill give that a go?
01/11/2018 14:12:18
Hi,Ive got water coming into my oil box and had a look look at the one way valve and it seems the balls not sealing?
Whats the best way to re seat bearing (excuse the pun) its about 1/8" diameter.
Its off my 1" Minnie.
Thread: 1" shovel?
11/10/2018 16:40:20
Posted by JasonB on 11/10/2018 13:23:43:
You might just get away with a 3.5g shovel from Blackgates they are 7/8" wide or just a long handled tea spoon seems quite common.
Blackgates also do little galv buckets so you can clean the engine afterwardswink 2
Thanks for that Jason.
You wont remember, but I was the guy with the leaking 'Minnie'? Just had a new boiler made for it.Just putting it back together complete with paint job!!
11/10/2018 13:03:41
Hi,anyone know where I can get a little shovel so I can steam my Minnie,or maybe make one?
Thread: plans and book value?
05/07/2018 18:35:56
Posted by henryb on 05/07/2018 18:34:03:
I paid about £56 off ebay
Drawings and book?
05/07/2018 18:24:45
Posted by JasonB on 05/07/2018 17:45:59:
As said enter the correct title "Scale Model Traction Engine Building" into the search on abe books site and hope you get the £30 one not the ones over £80
Or you could save your money as the magazines that had the build articles in them are on this site and the book is basically a collection of those articles.
Just increase the number at the end of the URL to get the next mag here
Edited By JasonB on 05/07/2018 17:49:55
would £80 all up be a fair price?
05/07/2018 17:34:07
Posted by J Hancock on 05/07/2018 17:31:36:
Google abe .
You will see a range of prices for any book you want.
where?
05/07/2018 17:29:17
hi, how much can I expect to pay for the book 'model traction engine building featuring 'minnie' and drawings.Used?
Thread: Scrap 'Minnie'?
23/06/2018 13:18:53
How do I download pics?
23/06/2018 12:45:27
Posted by Mark Salzedo 1 on 23/06/2018 10:34:01:
Hi Terry,
Sorry to hear about your Minnie .But I wondered if it runs on air alright? If so, would you consider selling, as I am looking for a small traction engine just to run on air in the workshop?
If so, perhaps you could kindly email me at: itechnician2014 at gmail dot com.
Thanks. Mark
sent email
23/06/2018 12:14:03
I dont want to run it in public ,just a couple of times a year steam it?
I wonder whats the worst could happen?
23/06/2018 12:09:49
Posted by Hopper on 23/06/2018 10:42:28:
Did you ever find out exactly where the leak is coming from? Is it totally not fixable, not even for non-public use?
Edited By Hopper on 23/06/2018 10:43:11
Hi,I took some pics with my endoscope and you can actually see it coming out but I cant find how to post them?
