Here is a list of all the postings John Hall 7 has made in our forums. Click on a thread name to jump to the thread.
Thread: Griptru wil not ad just |
19/09/2023 23:40:08 |
Please can anyone tell me what edition of ME contained the details of the Griptru chuck by Nick Clarke |
Thread: Dismantling a Pratt Burnerd Grip Tru Chuck |
14/09/2023 17:22:18 |
14/09/2023 17:08:21 |
The Tommy bar did come with a hex on one end…I have one from new and it has the hex for the adjusting screws… maybe they were not provided on all models…mine is a 4” Itis actually shown in use in the instruction manual Edited By John Hall 7 on 14/09/2023 17:18:42 |
Thread: Cleaning morse taper sockets |
11/04/2023 08:24:09 |
The brass ones are ok for guns, but not so good for removing rust |
10/04/2023 15:53:27 |
The cheap spiral brush sets on EBay are good value…stainless, brass and nylon in various sizes… similar to the one’s previously mentioned, but much cheaper Edited By John Hall 7 on 10/04/2023 15:56:01 |
Thread: Milling cutter insert identification |
05/03/2022 18:18:54 |
I’m trying to find any information regarding the insert codes..there’s lots of different ones. There looks to be lots available, but with a different code after the R215.44…obviously for different applications |
05/03/2022 16:19:42 |
Already tried Google..lots of R215.44 stuff,but no relevant information… Ive emailed Sandvik… |
03/03/2022 16:30:21 |
Hi, I need help identifying the inserts available for a Sandvik Coromant cutter I have. It has 3 inserts. written on the side of the cutter is. R215.44-40A32-15CL. I’ve looked on Sandvik’s site, but couldn’t find any relevant information. it doesn’t seem as straight forward as identifying lathe tool inserts. cheers John |
Thread: Welding cast iron vice |
27/01/2022 16:05:57 |
Thanks everyone for your ideas.. David, yes I’ve used the plugging method before with excellent success, but this is a cluster of holes that extend to the corner of the casting. is it Sifbronze number one that you used?…does the finished repair match the cast iron colour, giving an invisible repair, which I’d like, or is it more of a brass colour? cheers John |
21/01/2022 21:58:11 |
I have a few drill holes to fill, and a separate cast iron item that is cracked..I was hoping to grind open the crack and fill.. |
21/01/2022 20:47:21 |
Has anyone any experience using 55%silver solder for brazing cast iron?…Youtyhas a few videos using this.. |
21/01/2022 18:36:18 |
Part of the damage is on a corner, so yes it is structural as in that JB weld wouldn’t hold up to knocks etc.. cheers |
21/01/2022 18:27:47 |
Hi, I’m restoring an old Wilson Turret vice, and would like advice on the best/easiest way to fill a few drill holes in the cast iron vice base. Would it be possible to mig or TIG filler into the holes, or would brazing using one of the modern multi use filler rods be the way to go? THANKS.. |
Thread: Vertex Tool Cutter Grinder |
17/10/2021 10:49:15 |
Nice work..I’m considering doing the same, when I get some experience at thread cutting…I’m still on the steep learning curve… |
17/10/2021 10:49:14 |
16/10/2021 21:21:20 |
A bit of information live found these machines use a variety of collets. The Warco uses L20 collets, which are quite expensive and not readily available… AliExpress sell a set of 17 metric “U2” as they call them L20 collets for approximately £100 delivered to the uk |
Thread: Cross slide adjustment? |
01/01/2021 21:53:35 |
There should be 4 gib screws...if you can’t see them, then they have used the threaded holes to mount the dro, which. Is quite odd..you need to remove the dro to see what’s been done..you may need to re Mount the dro by making additional threaded holes |
Thread: Question about knurling wheels |
23/12/2020 11:49:01 |
The Jones & Shipman tools use 1/4” Edited By John Hall 7 on 23/12/2020 11:50:56 |
23/12/2020 11:47:54 |
Yes 7/32 does seem an odd size...maybe so you could only use wheels supplied by Marlco🙄 |
23/12/2020 10:09:21 |
