Member postings for not done it yet
Here is a list of all the postings not done it yet has made in our forums. Click on a thread name to jump to the thread.
Thread: What kind of steel is this?
17/05/2023 06:50:55
Posted by Steve Tyson on 17/05/2023 00:10:45:
Could be 'key steel', if you heat treat a sample and it remains soft (relatively), that'd be my guess.
Steve
In a similar vein to AJ, he means ‘anneal’. Heat treatment can cover a multitude of separate events, so can be hardening or softening.
Thread: Dore Westbury Milling Machine
16/05/2023 15:05:02
I use couple of wedges, one from each side, to loosen the MT, if a light tap (with a white- or yellow-metal mallet) does not free it off. Wedges are strung together to prevent droppage and it only needs the drawbar to be loosened, so the cutter and holder cannot drop out completely until under-control removal.
Thread: Help needed with my maths please
16/05/2023 11:27:14
Move it back to somewhere you can lift it. Then move it back at ground level? Only need bars/pipes underneath it in that scenario
In your current position it will depend on where the mill is suspended from. Single point in the middle or two points virtually over the supporting structure. It’s not, so far, really a maths problem at all.
Thread: Convince me I don't want a Warco surface grinder
16/05/2023 09:15:36
Posted by jaCK Hobson on 16/05/2023 08:35:16:
I don't 'need' one. It's a hobby... just playing.
Agreed. I don’t often use mine - but when needed, it is there.🙂 I now don’t have to bother about the finish on some parts from the mill - particularly fly cutting - if it can be sorted on the surface grinder. Extra time, but it is only a hobby.
Edited By not done it yet on 16/05/2023 09:16:09
Thread: Cables
15/05/2023 14:19:39
Posted by Nick Wheeler on 15/05/2023 09:28:08:
Posted by Speedy Builder5 on 15/05/2023 06:43:39:
I find generally that cables are too short or not flexible when cold .
I think that's one of the signs of a better quality tool: you don't need to prop an extension cable close enough to the job that you knock it off every time you breathe out. Although I've often wondered why a euro torch for a mig welder is 3metres long, yet the earth lead barely sticks out of the machine.
You don’t normally want, or need, to move the welder. But you do need to move the welding torch from one end of the job to the other. That is why they are different lengths, with the torch being the longer by quite a degree.
Welding torch and lead is much lighter than the welder.
Thread: In case you need to replace you mill X power feed
15/05/2023 07:02:20
Nice, shiny, chinese kit. Agree that mark-ups look to be fairly excessive (but maybe there is a high warranty failure rate?). OK for many, but I knocked up a satisfactory long-travel power feed for my little mill for less than thirty quid and some of my time.
One based on this vid: LINK but to suit what I had to hand and a mod to the feed screw.
Thread: Parallels
15/05/2023 06:52:12
Not parallels but a gander at emmas spare room machineshop vid on youtube - of her reviewing a cheap set of angle plates might be enlightening for anyone considering buying cheap. Easy to find as it is, I think, the only review she did - she was just too honest and showed what rubbish the kit really was. Here is a LINK .
I use the Arc set, almost universally - but they can be awkward if drilling to closer than 5mm from the edge.smiley
If I want any more, I may purchase a wavy set and make/finish any, like those in the warco link, on the surface grinder. Mine would likely be case-hardened mild steel, rather than through-hardened - unless I’ve got some suitable tool steel close to the size(s) needed.
User selection is always a relevant factor. The warco ones are a bit naff if your vise is a deep one, little point in paying for 150mm if every thing will be satisfactory with 100mm parallels, wavy ones are softer (spring steel) but may be relevant for drilling close to an edge.
For raising items from the mill table, I also use old bearing races and other precision parts recovered from used items. ‘Spacers’ made on the milling machine can be perfectly adequate for most operations, I might guess?
Thread: Cables
15/05/2023 06:04:36
I generally don’t care about the box, after unpacking. What annoys me is that very few tools have any means of storing the tool neatly - like somewhere to affix the plug or some means supplied to wrap the power lead around the tool, for mains-powered tools.
Thread: Every answer
13/05/2023 18:38:40
Posted by Robert Atkinson 2 on 13/05/2023 13:39:37:
Sorry Jason, the machine most certainly does know and care if a single or 3 phase motor is fitted.
Robert.
Agreed with what Robert had to say.
Well documented instances of single phase motors, affecting operation, include Raglan lathes which didn’t operate too smoothly while running at reduced speed and Centec mills (on its factory stand - maybe not all types of stand) which suffered from substantial noisy vibrations. Three phase motors improved the operation of both those machines. 50Hz vibration cannot be seen to improve the finish obtained finish of the product but the finish may well be better without that added vibration.
Thread: How to relocate a Bridgeport series 1 milling machine.....
13/05/2023 08:06:09
Looks like a good machine once the wear is accepted or attended to.
Also a good way for the vendor to sell two machines with one auction cost.
Question: How far can the head be rotated, to lower it?
Obviously Steve at landylift doesn’t move this mill every day of the week but he will have moved quite a lot and will be a very safe pair of hands while it is in his care. He is also very helpful with delivering as close as possible to final position, apparently.
Good luck with your new acquistion!
12/05/2023 07:09:57
Posted by Stephen Follows on 11/05/2023 23:50:15:
Has anyone else noticed that you can find any answer you like on the internet?
I have been debating for months on whether to fit a three phase motor on my Myford ML7 lathe. Apparently the bearings will seize and the lathe will be a worthless pile of junk inside half an hour or it’s the best thing I could do and will give me years of wonderful service at high speeds.
Who does one believe?
Firstly, this is a case of ‘don’t believe all you read/see on the internet’. It helps to look for corroborative evidence.
This is basically nothing at all to do with the motor - only the lathe, by virtue of idiot operators. Myfords were limited to the original top speed to avoid early spindle bearing failure. A small increase in speed may be possible due to the design engineers conservatism on that front. Not sensible at all on a worn machine, mind.
Here is an analogy from fairly early in the last century.
Early petrol engines could operate on gravity/splash lubrication. Oil dippers on the big ends scooped up oil for the big end bearings and splashed oil around, that could be directed to the crankshaft main bearings. This system was OK for many engines of the day. Diesel engines (heavier loadings on the crankshaft bearings than petrol equivalents) were generally limited to lower engine speeds (of around 850rpm).
Later, engines were fitted with pressure systems from an oil pump. Some diesel engines were OK up to about 1600rpm without a pumped feed to the bearings but these employed a low pressure oil pump which sprayed oil to the crankshaft bearings from suitably positioned nozzles. I have one (1930/40s?) petrol engine that can rev to 2200rpm using that system.
Eventually all larger engines adopted a direct pumped lubrication system, allowing the engine maximum speeds to be steadily increased.
Of course, there were other design changes as well - replacement of cast iron (to Aluminium) for pistons is one such progression.
Drip-feed of plain bearings is reckoned only be good to about 1100rpm, tops. For Newton Tesla three phase conversions, engineers will have programmed the VFD to limit the motor maximum speed.
Thread: Bulkhead Penetrators (Getting a good vacuum seal)
11/05/2023 19:02:20
This part is needed for my clock, with a pendulum is intended to swing in a low vacuum, as low pressure as I can manage.
I think SOD means he actually wants a high vacuum. It is still only about 14psi, but permanency is the hard bit.
Thread: 5mm square hole
11/05/2023 18:47:38
Clickspring has a youtube video on making a square broach. Have a gander at that?
Would need to start with bar at root two times 5mm.
Edited By not done it yet on 11/05/2023 18:49:13
Thread: How to check the operating voltage of LED indicators
09/05/2023 16:48:47
Posted by duncan webster on 09/05/2023 15:24:42:
Posted by SillyOldDuffer on 08/05/2023 16:43:15:
....... Correctly wired LEDs last for ever,......
Edited By SillyOldDuffer on 08/05/2023 16:43:38
Not necessarily so, we get odd failures in our signals, nearly always the greens. They are running well below max rating, when they stop emitting light they still conduct, so as we have 2 in series the other one still shows.
Probably of cheap chinese origin - sub-standard production runs of good LEDs. The lifetime guarantee only lasts until they are connected and powered up, in a circuit!
Thread: Whittling down round bar stock with emery paper.
09/05/2023 06:32:46
I don’t think these bearings should actually just ’slip’ along the shaft. There are fairly precise tolerances for bearing fit to shafts - usually needing to be press fitted. Yours may need loctiting if loose on the shaft.
Thread: Myford cross slide leadscrew info needed
08/05/2023 09:15:42
and the link from NDIY is interesting.
I only added that link because it was the first I came across. I know there are UK sources of such feed/lead screw materials. HPC Gears are the usual UK company that can supply, but there are others
HPC Gears offer a 300mm length of 1/2” ACME LHT for 43 quid (no idea if it includes VAT/ delivery/etc. Personally I find them expensive, but good (and they do need to make a profit!).
I don’t particularly bother about a bit of backlash. Adding another ~1/2mm of cut takes off another ~1/2mm.
My lathe used square feed screw threads (still does). Does it really matter what thread-form is employed - as long as they work? Raglan obviously made a considered choice when they did that, back about 80 years ago.
I’ve also made a ‘zero backlash’ feed screw nut by the ‘‘heat’n’squeeze’’ method, using acetal. Never actually used one, but they have been by some. The threads definitely need ‘easing-off’, IMO, mind.
I do wonder how long a high quality Whitworth or UNC arrangement would work for most hobby machinists - maybe not appropriate for those who use their lathe all day, everyday - but for the more intermittent users it may last a looong time.
Thread: Replacement lathes. Recommendations?
07/05/2023 13:38:29
Posted by Tony Pratt 1 on 07/05/2023 13:03:21:
Fascinating post which I am following with interest, from my own experience owning & using British iron both in industry & as a hobby, rebuilding a Myford 7 and now with a 3 year old Warco, I would retire the old lathes and start afresh with new gear unless the OP wants a load of grief trying to resurrect 70 year old machines. No right or wrong answer to this problem.
Tony
Probably correct regarding the resurrection of old machinery for a lot of buyers.
I had time on my side and waited until I found my lathe, which has not since been ‘resurrected’ (was in very good working order, with a good range of extras - and at the right price).
The only myford I might be interested in would be the 254, which was pretty well based on my machine, anyway.🙂
Thread: Strong Magnets
07/05/2023 07:43:00
One might take a look at rotors (for workshop made wind turbine generators. Extreme care needed when handling those! A ‘nasty nip’ would not be relevant if they got out of control!!
Thread: Mill vice
07/05/2023 07:36:00
I have a 4(?)” vise similar to those shown in the first reply. It gets used occasionally, but is not my favourite by any means.
My favourites are the type ll as marketed by Arc. I have two - the 70 and 90mm. Some don’t like them at all, of course - a bit like Marmite?🙂 The smaller one is generally fitted to my smaller mill, as that mill needs all the help it can get where the z axis is concerned.
They do require more careful fixing to the bed and are not so simple to use (compared to simply winding a handle), but that does not bother me one iota.
There are other machine vises around the workshop. These include a smallish Abwood (about 80mm?), a tilting Abwood and an original Centec.
If I were to find other type ll vises (smaller or the 120mm) on an auction site, I might well make a bid if at the right price - as I have ‘borrowed’ the shallow vise from a Drummond shaper before now (on the Raglan).
One more possible advantage of the type ll may be that they can be mounted at a position of choice, rather than only at the nearest appropriate T-slot.
Thread: Ideas for rekindling the love
06/05/2023 18:00:58
Posted by Dave Halford on 06/05/2023 17:33:01
Valve timing, compression, spark timing and fuel. Any one of those will stop it
Fix the Wyvern and slay that particular dragon.
Dave,
Exactly my thoughts but I declined to put up the first reply.
Andrew,
It seems like the valve issue may be the first issue to attend to. It may be the only one.
I am like quite a few others on here. I’ve not done much in the workshop lately.
Health issues in our household have severely limited time available. To be honest, things started to go wrong in 2018, then covid seclusion followed, and now recurrent illness to contend with. Allied with getting older by the day (just like everyone else, of course ) doesn’t make things any easier…
