Here is a list of all the postings Martin Newbold has made in our forums. Click on a thread name to jump to the thread.
Thread: 2 inch face mill problems |
14/05/2018 20:12:17 |
Jason thats a 1.9" dia cutter the vid you posted was using whole bit . As I said on my m8s rigid dinosur mill which is so solid it ways several tons I only use a 1/2 fluted mill tool on this using half the cutter. It doesnt need a dro as it doesnt flex. The video also showed no use of cutting fluid or oil or coolant / lubricant. If your DRO is not reading zero then your head is flexing and if its alternating then you are not cutting evenly . Some metals have had spots in them . This is worse in alloys . Just saying as I dont use inserts as they overheat without coolent and then distemper or blunt which happens for me. I have just installed coolent on lathe and am not sure i would still use inserts.
M |
13/05/2018 22:13:18 |
Cricky how much are you tring to cut. i would try half that and a smaller mill bit . I dont think your machine is big enough to support what you are doing. That looks like an inch bit and you are trying to cut complete inch in one pass.?
When I have been milling I use less than a 1/2 fluted mill on a big very heavy old friends machine that doesnt move when you cut . This smaller mills are not so solid,
Posted by JasonB on 06/05/2018 18:37:13: I bought one too and had the same poor result. You can see by the worklight how much vibration is caused. I think it is only cutting on one tooth and the whole cutter is riding up on the work.
13/05/2018 22:06:09 |
if its rocking. Is it rocking on the face you have cut beacuse steps of differant hieght in the cut face. Sometimes the mill may not be inserted and secured properly and may be dropping lock the vertical hieght on each pass if you have the option. check your fixing of the part your milling. Its easy to get swarf under it and or bolting is not holding t down flush with the mill bed. Have only used flueted mills not inserts and generlly if its a large area a bigger mill will git better than small one as it will not require so many steps. Finally how much are you cutting on each pass . M. |
Thread: Advice |
13/05/2018 21:59:13 |
+1 for cobalt drills, espp Dormer plus keep the drill speed low and lubricate the tip.
Drill smaller hole and build up hole size in steps to a larger final size
M |
Thread: Strength of Cast iron |
13/05/2018 21:55:13 |
Perhaps a slighly differant thought on this subject if you are as it seems worried about pulling out a thread. Perhaps another question is how are you lifting it and what are you attaching chains too as if its a roof then I think you should be considering this is not good practice. Most heavy machinery is still walked by leavers into position. I am not sure why you want to lift it and just through ths into debate as if its heavy enought to break out the thread then why do this? All the best M Edited By Martin Newbold on 13/05/2018 21:55:58 |
Thread: Recommissioning an old motor |
13/05/2018 21:44:47 |
if you have modern workshop or house consumer unit with an RCD then plug it in hands free. It will either trip the RCD or run up . Warming it up may induce condensation in it it which might short out windings be careful if you are running warm air through it as this can do same . Basically with a modern fuse box with an inbuilt RCD an earth leak with throw the RCD trip and stop you getting electrocuted. . Obviously if you are at all worried or dont have an RCD consumer unit or a separtate one get someone who is an electriction to do it or get one that you are more sure of. You havent said what its going onto and what power it is as it might be unsuitable and more worthy of the dumpster . M Edited By Martin Newbold on 13/05/2018 21:45:40 |
Thread: Mounting a new lathe chuck |
13/05/2018 21:32:51 |
i wanted a 100x 1" x 10 tpi backplate for my spindle on my Drummond too. I havent found one yet, I found a 5" one and am looking for a front bolt bernard at present.
M
13/05/2018 20:26:30 |
Brilliant Dave , Thank you for sharing as its been a devil to get one on mine for my 100mm drive dont just assume your spindle size as unless it fits perfectly it will not work and break the threads in back plate . Yes i did this |
Thread: Repurposing a 25cc strimmer engine |
13/05/2018 20:18:49 |
You can make an adapter out of sheet steel. If its the coil you are replacing then just line it up close the old one the most important thing is to make sure its as close to the flyweel as you can get without rubbing the flywheel. Usually the flywheel will have a electric or magnetic switch under the flywheel which will fire the coil through a capacitor to engerise the spark through the coil. Even modern systems have to have this switch capacitor and coil arangement even with cdi. While you have it apart look at the ppipe work routing from the fuel tank to the carburettor these are usually not very refined and could do with a spring through them. M
Thread: Is this normal in backing plates |
13/05/2018 09:59:25 |
Haha Andrew its nice to be lucky once lol it doesnt occur very often |
12/05/2018 11:37:03 |
Lol , Howard this is just a hobby I was lucky enough to buy a 1" 10tpi 5" backplate and its a sweet fit like my other badly interfaced chuck which is 4.5" So am now looking for a sweet 5" bernard or pratt chuck that bolts right through. I did buy one but hermes messed up delivery and never got it as the seller got cross as hermes made no attempt to deliver at all . I must add of late Hermes have gotten better. MY pum p is working well and can spray cutting fluid everywhere and redecorate my tools luckily i understand it has an anti rust agent in it Martin Edited By Martin Newbold on 12/05/2018 11:38:05 |
03/05/2018 20:46:46 |
If the gauge is correct Jason then It cannot be a Drummond B, lol. It was much modified before i got it . If ML7 is 8TPI it would explain a lot why this failed. All the best M
Posted by JasonB on 03/05/2018 20:33:18:
Martin what is that 10tpi thread gauge photo in your album measuring, looks like your spindle nose to me so why try an 8tpi backplate? Anyone else think this thread looks a bit long? Edited By JasonB on 03/05/2018 20:35:15 Edited By JasonB on 03/05/2018 20:36:22
Edited By Martin Newbold on 03/05/2018 20:47:16 |
03/05/2018 20:40:40 |
Well i just tried measuring my other plate and it would concur that its 1" x 10TPI Posted by Martin Newbold on 03/05/2018 20:25:11:
Hi everyone By the way i do have another 80mm back plate marked up v1012 but cant find out who made this or what threads are in it i measured the thread part which is 1/2" and 5 threads there in with the blank unthreaded section 1" dia would this infer it is 1" x TPI 10?
M Edited By Martin Newbold on 03/05/2018 20:37:51
03/05/2018 20:25:11 |
M Edited By Martin Newbold on 03/05/2018 20:37:51 |
03/05/2018 20:22:27 |
Tim, I think your right . I bought the back plate not with the chuck am still learning about this threads as they are very hard to know the difference by eye and all look similar. I found a tale piece for drummond b and its listed as 1" x 8tpi. All the best M Posted by Tim Stevens on 03/05/2018 20:14:11:
Martin You need to be aware that the ML7 chuck thread is 1 1/8" and 12 threads to the inch. This is not something I think is correct, I know it and I have checked it by measurement. It is not difficult to check the diameter and the pitch, and anyone who tries to fit a chuck by guesswork rather than measurement is likely to have problems. If you do not have a thread gauge, get one. And do us all a favour, please. Next time you have a problem, TELL US what the problem is about. Your message implied that it 'just broke' when you now say that your chuck never fitted properly in the first place. So, we suggested all sorts of likely causes, and some unlikely ones, when you knew what the problem was likely to be, and it was not a problem with the chuck itself, most likely, but the fact that it did not match the lathe it was fitted to. I'm sorry I wasted my time. I'm sorry you wasted my time. Don't do it again. Most of us have little enough of it left. Tim
03/05/2018 20:17:59 |
Hihi Hopper Over powered no way . It just sufficient . Have an inverter fitted so am running at approx half power . Am very pleased with the drive the new gearbox i built is excellent and do not think this is causing any problem. The back plate was not fitting as well as i hoped but did some work in brass before without failure. It has been somewhat modified yes but stock spindle is same as original i think . I was not taking to much off to allow the tool to dig . My belt would slip before any damage was incurred through a tool dig even though there was not one. I am going to get a 1" 8TPI backplate and try that from RDG if they come back with some information
Posted by Michael Gilligan on 02/05/2018 09:59:16: Posted by Hopper on 02/05/2018 09:16:43:
No I havn't been following the whole saga closely enough to remember every detail. Do the modificationss include a larger spindle thread to match an ML7 backplate? I would expect the belts to slip or the tool bit to snap off long before a lathe tore the chuck off the spindle if the threads were properly made and engaged. If Martin could clarify ... . No modified spindle thread, so far as I am aware MichaelG.
03/05/2018 20:01:26 |
Posted by Hopper on 02/05/2018 12:19:29:
Posted by JasonB on 02/05/2018 12:02:49:
Could this be the adaptor That's an odd one. I thought Drummond M Type was 1" x 8tpi, not 12tpi as the ad in the link says. Either way, lot of extra overhang there. I think a proper Drummond backplate from lathes.co.uk would work better. OMG dont but one I bought one from Myford it was dreadful didnt fit properly at all was as bad as the ML7 backplate fitting it could be it was wrong TPI . Myford said they had lots of probs its possible its not as listed but clue less here and refunded great company. |
03/05/2018 19:57:08 |
Hi everyone . Thank you for the comments I think the ML7 must be 1" x10tpi . Am pretty sure that mine must be 1" x 8TPI. I might buy a RDB one to see if it fits better which is 1 " x 8TPI. I am hoping they are all not rubbish cast iron I have to confess the one i bought it didn't screw right on as far as my original chuck I am guessing the thread differences was the problem Am sure this might sort it out. Have been busy with other bits with my chinese pump and cutting liquid conversion so haven't had time to get one yet have been in correspondence on eBay RDG to check the cast iron is not cheap rustable version with steel in it. but will wait till i find out. All the Best
Thread: Drummond Shaper Feed |
03/05/2018 19:45:46 |
What is this please? |
Thread: Recently Acquired Drummond B lathe |
03/05/2018 19:44:17 |
I dont think its a B as thought mine was a B it looks later as you have the myford 4 sort of bar mech it looks a bit earlier than Myford 4 as you still have the carriage control at end like mine but a rocker undermeath with the screw to the side mine goes through the centre of the lathe it might be an 'M' |
