Here is a list of all the postings Chris Gill has made in our forums. Click on a thread name to jump to the thread.
Thread: A bunch more puzzling tools |
08/07/2017 21:18:48 |
Posted by Gordon W on 08/07/2017 09:21:55:
If that hammer has a taper spike it may have been used on the lead pipe, belling out the end to connect to copper pipe. I used a podger for that job. That may be it. The hammer was hidden under the floor near the old lead-work. It was certainly hard enough when it hit me on the head! I'd have been very tempted by the shackle mawl if I'd inherited the thing - one grandfather designed battleships. Posted by Ian S C on 08/07/2017 10:14:46:
Snap for the drill in #3, about 40 years ago Dad bought a set of drills that were on offer by a well known English wood working magazine, they were described as best quality British made drills, I still have the 1/8" one, it looked normal when it came out of the box, and after the first hole in a bit of wood it looked like the photo above. I think the rest of the drills were OK, perhaps the 1/8" ones missed heat treatment, or were made from low carbon steel. Ian S C Interesting - I didn't think of that option. The set is conveniently labelled "foreign", as we did in those days. So no clues about material or maker! I think it'll stay in the curiosity box. The suggestions for the tapered drill make sense but it seems odd to use a number (#15) drill for this. And I wouldn't have thought of a saw-set for the other one. Maybe I'll try it on my 5-foot tree saw sometime. Many thanks all - sorry I can't seem to quote everyone properly |
07/07/2017 19:16:45 |
While explaining the contents of a socket set to my little grand daughter, after she'd tipped them all over the floor, I remembered I still have some tools that I haven't identified yet. Can anyone help me out? My first one is obviously a hammer but I don't know what job it was intended for. I discovered it 30-odd years ago when I was replacing my lead pipes with copper. Two of them refused to come out so I wrapped one around each arm, put a foot against the wall and pulled hard. Part of the ceiling came down (I intended to dry-line it anyway) and this hammer bounced off my head. I reckon it had been there since about 1935 but what was it for? My second one is, I'm told, often seen at car boot sales but I still don't know what it is. One slot is worn and the tip is shaped like a screwdriver bit. My third one is a 1/8" drill that was in the remains of a jobber's set. The flutes all appear quite coarsley ground and this one the flutes even reverse direction. On one of the others the flutes go straight before continuing in the usual way. But why? Finally, another drill. This is a short #15 with a flat on the shank and tapered flutes. What sort of material would require this one? As usual, thanks in advance |
Thread: Why did my tool dig in? |
30/06/2017 23:36:44 |
Posted by not done it yet on 30/06/2017 23:16:34:
Was the cross slide locked off? Ah, b**er, don't think I did. |
30/06/2017 23:15:10 |
Posted by Chris Evans 6 on 30/06/2017 22:24:41:
Gosh how long is a piece of string ? Ah, yes. I'd tightened gibs and backlash to the point where it was getting too tight. I'd set the tool height but there's a question mark here and clearance was good. Swarf was my original thought - may need to invest in decent coolant feed (or hose pipe) |
30/06/2017 22:21:29 |
Posted by peak4 on 30/06/2017 22:16:59:
Tool slightly below centre height maybe, such that any deformation (bending) of the tool forces it into the work, rather than away from it. If it's a touch above centre height, then a minor flexing is more likely to move it away from the surface of the workpiece Ah, interesting. It's a while since I checked my height setting tool. Making a better one has been on my "one day" list. Maybe I should have a go. Thanks |
30/06/2017 21:48:57 |
Hi, I wonder if someone can help me understand what happened today. I was boring out a 20mm hole in a bit of 12mm thick BMS. I'd drilled to 18mm and roughed out with a carbide tool and swapped to HS for finishing off but the tool chattered so badly I swapped back to carbide. I was only running at 320 rpm because the workpiece centre of gravity was way off-axis. I was cutting on the back-stroke in the hope of getting a finer cut (yes, OK, carbide - slow - fine don't work together). And then, with 1 thou to go, it dug in and left a gouge in the middle of the hole. Not a catastrophy in this case but scruffy and something I'd like to avoid if I could just figure out what I did wrong. Thanks, Chris |
Thread: Helping dad vertical engine |
14/06/2017 23:37:04 |
Hi Eric I didn't realise until I did a trial assembly. If it's any consolation I had to remake a part today because I got the first one upside down for part of the marking up. Doh! Chris |
13/06/2017 20:25:33 |
I'm busy making this engine at the moment and I believe I've spotted a small error on page 513 (April 2015). I think the central portion of part 39 (the parallel shaft) should be 26mm long, which is the sum of the central portion of part 22 (14mm) and two copies of part 24 (6mm). This means the overall length of part 39 will be 46mm. I'd also suggest making the studs (part 41) a bit longer, say 36mm, as the existing length only engages 3mm at each end. I made mine from 4mm threaded rod to save time. Otherwise, looking forward to seeing it run Chris |
Thread: What Did You Do Today (2017) |
10/06/2017 21:42:57 |
C.I. spanner for assembling (Vono) beds ? The drill for re-seating water taps ??? Third implement is a Tank cutter with spare blade (pointing upwards)?
I agree with the spanner - I had a feeling it was for beds. But I think the two-blade thing is a hole cutter for wood (it fits my old brace drill). Still not sure about the other one Chris |
10/06/2017 21:02:38 |
Today I visited my mum to repair and sharpen her gardening shears and replace a leaky old outdoor tap. Not serious engineering, I know, but we ended up rumaging in cupboards and she pulled out an old tape measure like the one below (which is mine). Her tape is 25ft and mine's 50ft, they're identical fabric tapes in polished leather cases marked up in feet & inches (no fractions) and links (that's 7.92 inches or 66/100 feet). Interestingly, though we think they were both my grandfather's, mine shows the maker as Chesterman of Sheffield while my mum's is John Rabone & Sons of Hockley Abbey. Other finds, in a random assortment of broken drills, old wine-making kit and other bits we found two interesting drills (I'm sure there's a better word) and a cast iron spanner. Look out children, you'll inherit these one day! |
Thread: Another newcomer |
21/04/2017 19:15:22 |
Hi Brian At the moment I'm just starting work on my second Stuart Hart model. No doubt it'll be interrupted by the need to make some new tool or other. After that, probably more static engines, but who knows ... |
Thread: TAPER TURNING ATTACHMENT ON A HARRISON M300 |
19/04/2017 23:48:43 |
Hi all I recently borrowed one of these TTA's and wrote up some notes. I've created a post "Harrison Taper Turning Attachment for M250/300" in the "Workshop tools & tooling" forum. Hope it helps. Chris |
Thread: Harrison Taper Turning Attachment for M250/300 |
19/04/2017 23:44:13 |
Hi I recently borrowed a Harrison TTA and used it on my M250. My friend asked if I would write up some notes as he wanted to use it on his M300. I've converted the notes into a PDF which I'm happy to upload if I can find a way. In the meantime, I hope this Dropbox link will work: Chris |
19/04/2017 22:41:08 |
Hi everyone I'm a relative newcomer to the world of model engineering so I often trawl the magazines and forum for ideas. All being well, I'll be able to make some contributions before long. In terms of background, I spent about 40 years in the world of IT although the first 8 were in or around many of the industries of the North-East, especially British Steel at Redcar (RIP). Oddly enough blast furnaces, chemical plants, nuclear medicine and all the rest didn't introduce me to the Harrison M250 that still seems to have plenty to teach me! Chris |
