Member postings for KenJ
Here is a list of all the postings KenJ has made in our forums. Click on a thread name to jump to the thread.
Thread: M-DRO Magnetic Tape / Linear Encoder
16/05/2020 20:59:46
+t1q7th6s4egcw32zoz2ig.jpgootaldcfqqiu2w32dehyma.jpg%3xvbpp+stuxydzestwwpa.jpgm-dro.jpgPosted by Roger Benson on 15/05/2020 11:58:32:
Posted by KenJ on 25/03/2020 20:30:04:
Many thanks to you both for the information.
I have placed my order with M-DRO for the Easson 3 Axes Display and compact magnetic heads.
Kind Regards
Can you post some pics and details which heads and tape you bought. I want a similar system on my SX2.7 but finding that there are so many different type to choose from.
Roger,
I hope the attached details and pics are of assistance.
29/04/2020 11:52:37
Mike,
I have the ES-8A Readout, so slightly different from your one. I also installed the compact heads with tape.
1) The Brackets were far too large for my SX2.7, hence why I manufactured my own, which I believe is pretty common.
2) The manual for the ES-8A is not too bad. I have used the basic functions including PCD, Lhole and SDM, but must admit that I have NOT used the Arc function as yet, so cannot comment on that at the moment.
Good luck with deciphering the manual.
Ken
27/04/2020 15:39:08
Mike,
Thanks for the information. All looks very neat!
I bought the Easson 3-Axis also from M-DRO with the micro tape and made my own brackets out of Aluminium angle and stuck the tape to that. As yet, I only have fitted X&Y. Very pleased with the result.
Ken
26/03/2020 17:54:47
Many thanks to all.
25/03/2020 21:52:25
Bryan,
‘Thanks for the information. Yes, Its my intention to use aluminium “U” channel with the opening facing down and head up inside.
Many thanks
25/03/2020 20:30:04
Kind Regards
22/03/2020 12:15:27
ChrisB,
Thanks again. I also like the idea of the tape and produce brackets etc to suit.
Martin,
Yes, pics are always good for ideas.
Cheers
22/03/2020 10:45:55
Thanks for the quick response.
What i really meant was the difference between the two Magnetic types i.e. the Mini Head encoder with Tape or the M-DRO EH-05 linear magnetic encoder.
Cheers
22/03/2020 10:24:51
Re: M-DRO Magnetic Tape / Linear Encoder
I'm now at the stage of wanting to install a DRO on my Sieg SX2.7 Mill and now looking for advice / information.
Whilst I appreciate that the “Mini Head Tape” style is smaller than the Linear Encoder, is there any other benefits or otherwise? There is very little difference in the cost.
Any assistance will be greatly appreciated.
Many Thanks
Ken
Thread: New Mill
10/04/2019 17:26:30
So SX2.7L it is ......... being delivered this week from Arc.
Thanks to all who responded.
Kenneth
01/04/2019 16:56:36
Never a lot of information on Blue and Grey. Plenty on Red and Black or Green and Yellow.
Many thanks
Kenneth
31/03/2019 12:03:08
"Originally posted this under wrong heading"
So, I will be adding a mill to my workshop. The criteria will be R8 and no larger than the Warco WM16 (which isn’t R8).
My choices are;
1. SPG SP 2217-lll B LV
2. Amadeal VM25LV
3. Arc SX2.7L
Any advice / comments will be greatly appreciated.
Many thanks
Kenneth
Thread: New Lathe
31/03/2019 09:43:43
My choices are;
2. Amadeal VM25LV
3. Arc SX2.7L
Many thanks
Kenneth
23/03/2019 07:59:52
My WM240B arrived and is now set up, cleaned and checked; all seems ok. The Warco process was faultless, ordered and arrived within one week.
Ancillaries from Arc and cutting tools from Glanze, all of which seem to be of reasonable quality.
Now the hunt begins for a Mill of a size that will suit my requirements, which is not massive. Perhaps WM16 or SP2217-III LV (R8).
Kenneth
Thread: Anyone got this lathe?
04/03/2019 15:48:30
Hi,
Has anyone got this lathe?
Any information / reviews will be greatly appreciated.
Thanks
Thread: New Lathe
18/12/2018 19:46:41
Thanks to all........
Bazyle, thanks for the information regarding the search on the front page, I hadn’t noticed that.
Kenneth
18/12/2018 07:42:57
Thanks to all for the response.
I note that a Sieg SC4 has been mentioned, so can I ask what the preference would be vs a 240 either Warco or Amadeal? The budget is there for either. Along with the lathe will be a milling machine such as X2.7 or AMA VM25 / Warco WM16B.
The equipment will be used for pure Hobby (no locomotives) and restricted to whatever the aforementioned equipment can handle.
Any guidance will be greatly appreciated.
Many thanks
Kenneth
PS. After sales service is also important.
Edited By KenJ on 18/12/2018 07:49:08
Edited By KenJ on 18/12/2018 07:50:31
Thread: Warco Major or WM16B
12/12/2018 11:04:55
Hi Lionel,
Did you purchase the 16B and if so, what is your verdict?
KenJ
Thread: New Lathe
05/12/2018 18:24:59
Hi,
What would be your preference if only these two available;
  1. AMABL180 Lathe BRUSHLESS MOTOR
  2. SIEG SC3 HiTorque Mini Lathe - Belt Drive with Brushless Motor
    Thanks
Thread: Amadeal AMABL210 Bench Lathe 8x16
18/11/2018 15:37:01
Thanks Niels. It seems not many with knowledge of the equipment.
