Member postings for BOB BLACKSHAW
Here is a list of all the postings BOB BLACKSHAW has made in our forums. Click on a thread name to jump to the thread.
Thread: Cheap spindle DRO
19/03/2016 10:51:01
I have received a spindle DRO from China, it was cheap so worth a chance, problem with it that it has no instructions how to wire it up.
The plug has three wires, black,blue,brown. The read out has five wires.
Plane White.
Long Red and Short Red.
X marked along the wire.
Red Dash.
[ marked in red along the wire
It also has a Blue plug on the end of the three wire unit, does that come out.
Thanks for any replies.
Thread: Edge Finder
12/03/2016 18:24:36
In answer to Harry Wilkes post, www.kanabco.com is the web site for the Virtual Machine Shop.
I shall check out the book by A Throp, Thanks.
11/03/2016 12:48:19
As last post about touching the tool, as stated ,professional machinist use this method, as for climb milling etc as I have said I have a good understanding and know all this from basic lathe and mill training when I was 15, now 61. All I am saying is that the book the Milling Course goes from the basic to the advanced in a few pages. I would love to be proved wrong,has anybody read the book and completed all the jobs.
11/03/2016 11:18:40
I think these latest posts are missing my point, the making of Tee Nuts and basic stuff like this I have made with out the need of a book. But then making a Dividing Head , how many out there have made a Dividing Head after a few pages in a book. You can learn to use a mill and lathe making something of interest, surly not tooling, I would consider the making of these specialist tools but surly after a few years of experience. The thought of a novice spending hours and hours on a Dividing Head then when experienced that Dividing Head you made is not accurate enough, as advised in the book finding a edge by using the milling cutter just as it starts cutting the metal. Make it again.
11/03/2016 10:09:39
Having a good understanding of engineering but a beginner with the lathe and mill I recently purchased a book the Milling a complete course. My first impression was favorable but then looking at the jobs to be made I could not understand the logic of the author,tee nuts then afew simple jobs on to a Boring Head to a Dividing Head. These tools are cheap to purchase, the metal to make these would cost as much as the tools to be made on the course.
I have found you tube and the virtual machine shop to be my guide now on the best way to use a mill and lathe, one of the best tools I purchased this week was a edge finder for £7.00, advised on you tube as the accurate way to find a datum. I had been doing things the hard way on this as the milling course instructed. The edge finder is so easy and accurate that my wife who has no idea on engineering was getting the datum to .01 mm on the DRO.
The Milling a complete course in my opinion is out of date, but useful If you would rather spend hours making a tool that is cheap to buy. My other books The Amateurs Lathe, and Basic Lathework I find excellent, and read all the time as a reference.
Thread: SX2 PLUS MILL
28/02/2016 01:59:39
Thanks for the information Neil, looks now I can do both. Certainly a must have is DRO as I am finding converting fraction to decimal then forgeting if divide 25.4 or multiply 25.4 to metric then either .025 for Z axis or .020 for X and Y then turning the handle the correct way rather confusing.
Bob
27/02/2016 20:51:58
If fitting a DRO on the SX2 plus, I have noticed on You Tube that a lot of these are fitted on the back of the table, another had fitted on the front. Both ideas have drawbacks, on the back limited on the axis as the DRO will hit the back, on the front you can not adjust the gibs or lock the table. Has anyone fitted a DRO to a SX2 and give advise on the best way of doing it. As past posts I have made all the parts for the stops this week so at the moment one part of me wants to put stops on and the other to buy the DRO.
Thread: Slip Gauges
25/02/2016 20:39:22
The post from Danny about they should be used as gauges as a precision tool. The set I got from e-bay cost £30 and was the same type that we used when doing fine limit sheetmetal work, they were used as an adjustment aide when cutting, bending, punching holes using the fly press all types of fine limit adjustment. The welder actually had his own set when setting up using tig welding, if I remember correctly I think we had around five boxes of Precise John Bailey gauges to use. But obviously the tool shop had their own and God help you if you even looked at them, so if I paid a lot of money for a new box today I doubt if I would use them as the stuff I am turning out would not justify an expensive item.
24/02/2016 20:35:04
Another useful tool I have had for years but now showing wear is a optical centre punch. I remember paying a lot of money for it, but looking at Axminster they seem quite cheap..
23/02/2016 20:51:59
Hello. As a past fine limit sheet metal worker for over 25 years, now semi retired and out of engineering for over 15 years, I have started this new hobby of model engineering now around six months. I am surprised how much I enjoy being in the shed working on my lathe and mill, and using my hands making some small engines, as at the time in sheet metal work I hated every hour at the factory. I have purchased a lot of essential tooling needed for lathe and mill work but noticing only one thread on slip gauges has made me create this one. I purchased a set of slip gauges on e-bay last November, Precise, John Bailey 1964, a set we use to use years ago, I must say that they have been one of the most useful ofl toolsl . They are .862 inch square with around 60 gauges from 3 inch down to .100, I have used them as parallels, stops, height gauge for centering on the lathe, packing when drilling etc. As I have said with only one thread on slip gauges are other model engineers aware of how useful they are..
Thread: Stirling Engine
14/02/2016 20:10:19
Hello,
Thanks for these replies , and now have the information I need
Bob.
13/02/2016 22:49:20
Hello,
I have found the plans for this Stirling engine on the net but four pre made parts are not shown, 16, 21, 25, 45, has anyone got the sizes of these parts. I think that a guess to the size would be good enough, but on these type of engines is the hot piston any different to the cold piston in diameter
Thread: Ring LED light
13/02/2016 04:59:18
Hello
I am looking to put a LED ring light on my milling machine after reading about the idea from a American web site. The only type I can find is the type used for flash photography, the size is ok but that is about all. Any idea where one can be purchased at a reasonable price, as one for microscope use is around £100.
09/02/2016 15:37:29
Thanks for these ideas, the article given by Russell is of help and looks a simple solution which I shall adopt. A DRO will be the next step on my mill and lathe in the near future.
Bob.
09/02/2016 00:01:20
Hello
Before I start drilling and tapping on my SX2 P mill has anybody put stops on the table for the X and Y, I would of thought that stops would of been a essential part of this small mill. I am generally happy with the mill but before I do any modification on it my idea of stops may not be the best solution.
Thanks for any replies, Bob.
Thread: Where is the best place to buy material from
24/01/2016 17:51:22
Hello
As a member for around six months with a lathe and mill I have exhausted my supply of scrap material that I had aquired from my engineering days long ago.
I am just supprised at the cost of material today as the stuff I need was just thrown in the scrap bin.
I have looked on e-bay but postage puts the price up, so where do you members get brass, alu and steel from.
Thread: Warco WM16 or WM18?
20/12/2015 02:13:29
Hello, after writing a post about what milling machine to get, I have read these replies and would like to have a VM18.
My problem is lifting it in position as I am now limited in space, is it possible to strip the machine down to moveable parts and reassemble when on the stand.
If you can not strip it down, I have chain pulley that lifted my lathe with ease, but how do you lift a mill with a pulley, its going to be top heavy or a problem it will flick over, the strip down if possible would be my best option.
Bob
Thread: What milling machine to buy
19/12/2015 02:16:05
Hello, I have took partial retirement so now have more time to make things which I have missed doing as I have been out of engineering for over 15 years. My wood shed with solid floor has now been insulated walls and floor and I have installed a new lathe, weight 120kg. I done my home work on the lathe I wanted, a belt driven and generally quite basic. My problems started when I got it, put it this way if I did not have any knowledge of engineering the lathe would not be fit for purpose. I was sent parts that was missing, the gibs needed shimming out the list went on. I now have it running well and have archived 3/10ths over 8 inches. I have many tools from my engineering days so I have not had to purchase many tools to make anything, plus e-bay has helpt stuff so cheap. I am now looking for a mill, weight must be around than 80 kg as it will be a problem getting it in. I don't want to go through all the problems I had with the lathe, so any advice would be appreciated. As for metal stock where is the best place to get it, as what was thrown in the scrap bin now commands big money postage included. I even wrote a letter with a stamp addressed envelope to a old employer of many years ago asking if I could buy some scrap aluminum, didn't get a reply, worked for them for 10 years as well. Thanks for any advice on this matter Bob.
Thread: New to model engineering
21/08/2015 17:06:00
Hello
This has started me reminiscing, I worked for Adroit Tools in Luton in the 70s and to do fine limit small sheet metal components with a tolerance of + - .15mm or 0006 inch we used the fly press with in shop tooling that used Promecam top tools and beds, Pierce All punch and dies. shop made guillotine. All small jobs of tight tolerance were done on the fly press using slip gauges rather than the main machines.
This is another item in the shed I would love to have, but again its how to get it in there owing to the weight, is the fly press used by other engineers in the work shops as they can do any small job with tight tolerance with home made tooling.
Bob
21/08/2015 16:20:55
Hello, thanks for your replies on this matter, it seems that the lathe needed wll weigh around 180kg that is the problem I will have is getting a lathe of this weight in position.
The warco vm240 weighs 110kg which more manageable, are they worth considering.
As has been said by OuBallie I need to insulate the shed first.
Many thanks Bob
