Member postings for Bodger Brian
Here is a list of all the postings Bodger Brian has made in our forums. Click on a thread name to jump to the thread.
Thread: Chinese mini mill/drill lubrication
27/08/2016 17:16:29
Thanks chaps.....
That confirms what I'd more or less decided. The reason for not using grease (as it attracts "nasties"  should have been obvious if I'd have thought about it more!
Brian
Edited By Bodger Brian on 27/08/2016 17:17:15
Edited By Bodger Brian on 27/08/2016 17:18:05
Edited By Bodger Brian on 27/08/2016 17:21:00
27/08/2016 16:37:52
i did wonder if I should post this in the 'beginners' section but here goes......
I have a Chinese mini mill/drill which I purchased many years ago and the manual is long lost, so I'm afraid I can't quote exact model names or numbers. After a long period languishing in a shed at the bottom of the garden, it has been relocated in my new workshop and I've stripped it down for cleaning.
My question is what, if anything, should the leads screws (is that the right term?) be lubricated with prior to reassembly - oil or grease? I would assume that the screws are steel and they run in nuts that appear to be of brass, bronze or similar metal. The small amount of crud that was visible on disassembly didn't give me much of a clue.
Brian
Thread: What to get: Imperial or metric
26/08/2016 14:48:20
I don't have an problem with imperial measurement as such but it's fractional measurements that aren't intuitive for me. For instance, which is greater - 25/32" or 3/4"? Sure, I can do the maths & work it out but unless you're used to it, it isn't obvious (and I say that as someone who usually came top of the class when fractions were taught in maths at school).
Put it into decimal - 0.78125 or 0.75 - and the answer is plain to see, and that applies to whatever units you want.
Brian
Edited By Bodger Brian on 26/08/2016 14:49:31
Thread: What would you ban and why? (Definitely tearoom!)
23/08/2016 13:29:23
Posted by V8Eng on 21/08/2016 20:55:55:
Ban the word "like" from being spoken unless it is in the correct context.
Along with the phrase "my bad". I always want to reply "your bad what?"....
Brian
Thread: Cowells lathe paintwork
08/08/2016 13:48:11
After months of research, thinking, planning & general dilly-dallying, I've finally plundered my piggy-bank and splashed out on a used Cowells lathe.
Whilst there doesn't appear to be any problem with play, excessive backlash etc on the mechanical side of things and everything turns as I'd expect it to, cosmetically it could be better, as the base as a number of chips in the paintwork. My question is two-fold :-
1) I realise a quick phone call would give me the answer, but does anyone know if paint to match the original is available from Cowells?
2) Rather than just touch up the paintwork, ideally I'd like to remove the base, strip it back to bare metal and paint afresh. How easy would it be to strip the old paint entirely? The last thing I want to do is devalue my new toy investment.
Brian
Thread: DIN 55027 / ISO 702/III / BS4442 bayonet lathe spingle question
27/07/2016 13:41:01
Posted by Rainbows on 27/07/2016 12:39:47:
http://docs.cntd.ru/document/gost-12593-93
Who is good at russian?
I have a Lithuanian colleague here at work who should be able to translate, although I think it would be a bit much to ask him to translate the whole document. Any particular bit you're interested in?
Brian
Edited By Bodger Brian on 27/07/2016 13:41:22
Thread: What Did You Do Today (2016)
18/07/2016 19:43:34
Posted by Sam Longley 1 on 18/07/2016 17:49:11:
I had not used a funnel to fill the tank & there was a bit ( well a lot actually) of petrol on the engine & the wife said I was not to do it. But you know how it is - you have to show these women you know how things work !!!
"If at first you don't succeed, do it the way your wife told you to in the first place"
27/06/2016 13:54:41
With wifey's approval (& assistance) I finally started moving my long neglected workshop tools & machines from the garden shed into a spare room in the house to create a new workshop / man cave.
Although she is quite happy for me to do this, she insisted that the room can easily be re-instated as a bedroom if necessary so the worktops aren't exactly ideal but I'm not complaining.
The day when I can get back to doing 'stuff' in a warm & dry environment with reliable electrics is fast approaching smiley
Brian
Thread: Headstock Collet Chuck - Query about Accuracy
24/06/2016 20:59:28
Thanks for clarifying things chaps. I've never actually seen a collet chuck in the flesh & I must admit that a slight taper on the register hadn't occurred to me as a possibility.
Brian
24/06/2016 13:46:57
Posted by Frances IoM on 19/06/2016 19:44:30:
basically yes - I fitted a ER16 collect chuck to my small Perris depends on how your stockstock mounts a faceplate - for my Perris this was a 2.5in by 1/2" of EN1A which had to be drilled and tapped with a 1/2" UNF (20tpi) (done on my larger lathe) then fitted onto Perris and skimmed to square on the Perris headstock then the register cut the mounting holes drilled and tapped on the back plate - the chuck was drilled for 5mm cap heads.
This might be a silly question but in order to get a runout of 1 thou or less (which seems to be what people aim for), would the register on the backplate have to be machined so that the chuck is a pressfit onto it? or am missing something obvious?
Brian
Thread: Draughting Pens
21/05/2016 22:01:15
Posted by John Fielding on 21/05/2016 15:34:45:
Does anybody remember Amberlith and Rubylith method of laying out pcb's with pad and tapes? I have a drawer full of pad and tapes which nobody uses these days.
I certainly do. Part of my first job at Alcan Labs in the late '70s was laying out artwork (at 2x full size) with tape and transfers, photographing the results on a large pedastal camera, developing the film & etching the PCB. It wasn't Amberlith or Rubylith though - the name of the tape manufacturer escapes me at the moment. Oh happy days....
Thread: Building a GOTO Mount
02/05/2016 21:59:27
Posted by Neil Wyatt on 25/11/2015 19:13:11
It took me a while to understand 'nets', if you use these instead of a wire to join up power pins etc. then you don't need to physically join them up on the circuit diagram. This is what I have done with +5, +12 and GND.
I hesitate to use the word 'always', so I'll settle for 'generally' or 'usually' when I say that any connection between two or more points is called a net (some software even assigns a net name to a pin that has no connection but that's another story). The type of connection that you're referring to is often called a 'global net' or 'global' for short.
Apologies for digging up an older post.....
Brian
Thread: electric - measuring the kwh for my workshop
26/04/2016 09:12:52
I must confess I'm a bit confused - easily done! The OP starts by asking about measuring the amount of electricity but seems to change to wanting to control on/off times. Which is it - or is it both?
Brian
Thread: Early Cowells lathe spindle thread size
22/04/2016 13:49:56
I should emphasise that I'm only in the planning stage at the moment & am by no means settled on a Cowells.
When 'the management' first bought up the subject of re-locating my workshop (with a ageing Chinese mini-lathe), there were 3 options; a new fully insulated shed, taking over the garage or using the spare room once sprog #2 had left home. The size of replacement lathe would depend on that decision - or perhaps it'll be the other way round!
Thanks for all of the links and comments anyway.
Brian
20/04/2016 20:33:54
Thanks for the replies chaps
If, and it is still a big if, I decide to go down the Cowells route, it looks as if it'll be best if I avoid those with the larger thread pitch. I wouldn't want to spend all my time looking for expensive / hard to find parts to go with a new toy.
Brian
20/04/2016 13:58:32
Whilst engaged in further research about suitable lathes for my workshop relocation, I discovered that whilst current Cowells lathes have an M14x1mm threaded spindle, earlier versions were M14x1.5mm (please correct me if I've got that wrong).
From an admittedly cursory look on't internet, it appears to me that backplates, chucks etc (of any make) for the earlier 1.5mm size are not readily available - at least in the 'new' category.
Is this is a fair reading of the situation or am I just not looking in the right place?
Brian
Thread: Bronze Wool?
03/03/2016 20:29:05
A quick Google search comes up with brownells.co.uk. Alternatively, there is at lest one supplier on Amazon.
Brian
Thread: Use of domestic room as a workshop
09/02/2016 20:31:09
Posted by Stephen Benson on 09/02/2016 16:58:26:
I have my machine tools in the garage and run my clock repair workshop inside keeping the clean jobs inside keeps me warm and listening to my music while ensuring I do not upset the boss
I must confess that hadn't occurred to me - have a larger lathe in the garage and smaller lighter stuff indoors. It gets round several problems in one go.
Thanks for the inspiration.
Brian
09/02/2016 20:25:52
Posted by Ajohnw on 09/02/2016 18:01:39:
It has cushion flooring. Good quality so easy to sweep up and it lasts.
Can you elaborate on the 'cushion flooring' ? Could be of interest.....
Brian
09/02/2016 20:20:24
Thanks for all the thoughts guys - plenty of food for thought.
Brian
