Member postings for Simon Robinson 4
Here is a list of all the postings Simon Robinson 4 has made in our forums. Click on a thread name to jump to the thread.
Thread: Is a bath sponge suitable as temporary fix for car air filter?
18/01/2023 13:56:35
After the heavy rain last week I gave my diesel car a check over and discovered rain water had got into my paper air filter and it had fallen apart. There’s a leak at the top of the bonnet and rain water seeps into the air filter box. Thankfully no water got into engine and it turns over as normal.
Is a dry bath sponge suitable to replace the filter with so I can drive out and buy a new air filter?
Thread: How were words and numbers printed onto old instrument panels?
05/11/2022 22:09:01
Before laser etching how would words and figures be printed onto instrument panels and dial faces like on vintage aircraft like spitfires or the cabs of old locomotives etc? They look like they are engraved into the metal or plastic but how?
Thread: Help: Cordless angle grinder keeps shutting down?
09/06/2022 20:09:26
Posted by DC31k on 09/06/2022 19:28:16:
Please can you tell us the make and model of grinder.
Do you have any other tools that take the same battery? Does the battery work well _under_ _load_in the other tool?
Does it have a momentary switch that you need to keep pressed to operate it? Or is it a latching on-off switch? When it shuts down, if you switch it off and then back on again, does it resume working?
If it is easy to do so, open it up and check for loose connections, intermittantly broken wires or dry solder joints. Actually I’ve used it a lot and it’s not needed a full charge so maybe the battery capacity is reduced.
its a Parkside grinder I got from Lidl. The battery seems to reach full charge quite quickly. Less than 20 minutes.
I think it’s a latching on off switch that slides forward. It doesn’t need to be pressed all the time.
Sometimes it starts up again after shutting down by switching it on.
Edited By Simon Robinson 4 on 09/06/2022 20:11:37
09/06/2022 18:18:55
When I switch on my cordless angle grinder it keeps shutting down seconds later, especially when I touch my piece of work. It was working ok yesterday but occasionally in the past it shuts down. Now it’s doing it every time I switch it on.
The battery is well charged and healthy
Thanks in advance for any replies.
Thread: What are the best quality needle files?
26/05/2022 20:08:17
I got a cheap set of needle files and they have already dulled and blunted having used them for less than 20 minutes on wood. The ones I haven’t used yet have rust on them despite being kept in a dry centrally heated house. They were ok when I bought them.
What are the best quality sets of needle files that won’t wear away and won’t corrode? I use them most often for filing windows and doors in plastic models but also want to use them on metal too.
Thread: How do I remove grease from wood prior to painting?
26/05/2022 13:35:04
Posted by IanT on 25/05/2022 21:53:08:
I generally use white spirit to clean up, using a very fine wire wool - let it dry and if there is any oil/grease left repeat. When happy, very lightly sand. Water/soap can also work but tends to raise the grain more. Don't soak your model and the PVA joints should be fine.
If painting, use a special primer such Bulls Eye 1-2-3, relatively expensive but it works very well (and there's no need to use 'knotting' either). 1-2-3 is a 'white' primer so may not suit every job of course.
However, it adheres well and will stop anything coming through to spoil your top coats.
IanT
PS If it's just oil from your fingers, prevention is a good (better?) idea - so wear gloves.
Edited By IanT on 25/05/2022 21:55:07
Thanks. Can I add a tiny bit of artists black acrylic paint to the 1-2-3 white primer to make it grey?
26/05/2022 13:32:36
Posted by Derek Lane on 25/05/2022 22:41:21:
I have never had problems from the natural oils from my hands when finishing wooden models. If however you are talking oil and grease that you have picked up from handling metal engineered models and the like the hand cleaning is the answer before working with wood.
Oxalic acid will clean it off but if left on may dis-colour the wood as in that it can act like a bleach.
I don't paint my wooden models but do apply a lacquer for protection after applying a sealer first.as in this model
Very nice. What scale is it? and how did you make the tracks?
Edited By Simon Robinson 4 on 26/05/2022 13:33:21
25/05/2022 21:35:36
I’m making a very small wooden model and the natural oils from my hands and fingers are getting into the wood when I use my fingers to handle small parts. Obviously the primer may not stick to the wood properly if it’s greasy. How can I best remove this but not undo the PVA glue I’ve used? Alcohol or soap and water? Any other ideas?
Thread: Damp shed: what’s the best way to add ventilation?
19/03/2022 15:12:46
Posted by Dave Halford on 16/03/2022 18:41:57:
What did you 'seal' the roof with? It should have been heavy duty felt, the expensive stuff. 6x4 sheds tend to be made cheap with the thin felt and thin walls made from fencing panel timber.
Without gutters rain will run off the roof hit the patio and bounce up wetting the walls.
It’s tongue and groove panels but the felt is thin and poor and nailed on which I’ve had to paint tar over.
I think my big mistake was painting the inside of the shed in white emulsion because the moisture can’t absorb into the wood and evaporate to the outside due to the paint layer and so it just condenses. The outside is also painted but with Cuprinol.
19/03/2022 15:08:41
Posted by James Alford on 18/03/2022 09:21:24:
I have a 17' by 19' wooden garage which is used as a workshop. Whether it is luck or not, I do not know, but it gets no damp or condensation.
The walls and doors have foil-backed bubble-wrap insulation stapled over them with flake board on top. The roof is unlined. There is a modest amount of ventilation under the eaves and around the doors which are a "comfortable" fit. There are also a couple of holes drilled in the apex.
The wooden floor is up off the ground, standing on beams. I put a sheet of plastic damp proof membrane over it and covered this with hardboard and those cheap inter-locking rubber mats.
Originally, I also lined the roof with polystyrene covered with hardboard. This was a major cause of damp and was soon removed.
It is not the warmest place on Earth, but it is dry and damp free.
James.
Edited By James Alford on 18/03/2022 09:21:43
Edited By James Alford on 18/03/2022 09:22:19
Edited By James Alford on 18/03/2022 09:22:43
I wonder if my mistake was painting the inside walls in white emulsion? It’s stops the wood from breathing and probably increases condensation as dampness can’t soak into the wood and evaporate through to the outside due to the paint. Both inside and outside are painted.
19/03/2022 15:04:48
Posted by Neil Wyatt on 19/03/2022 10:15:09:
Interesting to read how damp air actually rises. The condensation problem on my metal roof was terrible, even with a dehumidifier. I used the metallic bubble film. It has a reputation for not being hugely effective compared to other insulation, but I wanted something that wouldn't lose me headroom and could go between beams and the roof as much as possible. It's been really effective, I used a version with self-adhesive strips on it, but ended up using a roll and a half of double-sided tape as well for about 20m^2.
I'm hoping it will help keep things cool in summer as well.
Never though about it but car roofs must get a lot of condensation between the upholstery and metal roof. I’m not sure how they prevent condensation in vehicles otherwise the ceiling would soaking wet most of the time.
19/03/2022 15:00:31
Posted by Peter Cook 6 on 19/03/2022 14:16:53:
My little 6 x 4 shed (used to store the mower, shredder and other potentially useful junk) used to get damp. I installed a couple of passive vents, one low at the back, one High at the front and a cheap solar powered vent in the door. That has kept it dry ever since.
What sized vents did you use?
16/03/2022 16:22:48
I have a 6 ft by 4 ft wooden tool shed with apex roof which gets very damp in winter. I’ve re-sealed the roof but there’s always dampness inside the shed despite being placed on a concrete patio on sleepers with reasonable space around it.
Should the vents be on both ends of the shed just under the apex point or should there also be vents low down as well? Any other ideas?
Thread: Selling your models: do they have to be licensed?
02/12/2021 23:27:18
If you make scale models of say Hitachi trains or Boeing aircraft and intend to sell them, do they need to be licensed by the manufacturer of the object that’s being modelled for example does a model Boeing 747 have to be licensed by Boeing even if it’s made entirely by yourself and your own plans?
Thread: Does charging your car battery on fast charge damage it?
23/11/2021 16:30:57
Posted by IanT on 23/11/2021 14:54:21:
I will just mention that newer (Start Stop) batteries do not like old battery chargers (don't ask how I know!)
I now have a new 'Start Stop' charger (from Halfords) that offers 'fast' & 'trickle charge' settings which seem to be fine. It was much cheaper than the new battery.
The old battery charger is now regulaled to rust removal (electrolysis) duties - for which it is ideal.
IanT
That’s sounds a good idea. Never thought a car battery charger could be used for electrolysis. So I guess you put the negative clip on your work and the positive on something else or the other way around?
23/11/2021 14:06:56
Ive got two settings on my car battery charger. High and Low. I’ve heard that using the high charge often can distort the electrodes over time. But surely when I drive along the motorway the battery is getting a much higher charge from my alternator than any plug in battery charger can even give it.
Any thoughts?
Thread: Can red oxide primer be painted on to Rust?
17/11/2021 19:27:47
I’ve got a can of Wilkinson’s red oxide primer but it says on the label that rust should be removed with a rust remover before applying the primer.
I was under the impression that Red oxide primer could be painted on to rust unless this brand is just red paint and has no anti-rust properties?
(Im wanting to paint some unused Met spike posts that have gone rusty)
Thread: Model Paint Cancer warning on tin.
04/11/2021 22:10:54
Posted by Nigel Graham 2 on 04/11/2021 19:22:28:
Use it.
The tin is labelled to suit as wide a market as it can, hence that peculiar warning.
I've an idea I have seen somewhat similar elsewhere; but I forget what for. That assertion appears written by lawyers for lawyers rather than technical people, and one is tempted to ask if it means the paint is safe in Utah or Nevada.
The reference might show what is really meant, what concentrations, situations, etc.; what part of the body it may harm, and what precautions to observe. It's probably based on frequent, heavy industrial use of the offending ingredient; not occasional hobby use of the complete paint.
Most paints, lubricants and solvents are or contain substances that can cause skin damage and even cancer with sufficient prolonged or frequent exposure, so obviously need the usual workshop hygiene precautions; but for proper information I suspect the paint's real MSDS would be more useful than something written to suit legal blokes in one single US State!
So use it, but simply take common-sense care in doing so.
Seems to be the trend in there. We’ve had a tin of US made Cadmium & Nickel grease in our garage since the 1980s and it says that it contains a small amount of a suspected carcinogen not had any problems from it. Maybe the warning is designed for the California market. But similar UK made cadmium Nickel greases don’t have this warning.
04/11/2021 18:56:33
I bought a small pot of a well know brand of enamel model paint and was shocked to read on the tin that it causes cancer. It mentions: “that this product contains chemicals known to the state of California to cause cancer” it then gives a web address P65Warnings.ca.gov. This is obviously quite disturbing. None of my other paints of the same brand that I got in the past have this warning. Do the newer paints have different more hazardous chemicals in them? Making me think twice about using my new paint.
I bought the paint in the UK so don’t know why it has warnings relevant to California on the tin.
Thread: What’s the best diesel stabiliser/ additive for car?
27/02/2021 13:06:52
Posted by peak4 on 27/02/2021 12:46:36:
When I was looking into fuel stabilisers for petrol, which does go off, StarTron seemed to get the best reviews.
I note that they also do a diesel version. http://www.starbrite.com/startron
Just beware that in the UK it seems to come in different concentrations, so the more expensive version might work out cheaper.
One issue with diesel is that of "Diesel Bugs" which grow/multiply in the tank in the presence of moisture.
All seems fine at first when you set off, but the black gunge gradually blocks the filter(s) leading to fuel starvation.
Any marine chandlers should be able to supply something to kill them off if you end up with a fuel infection.
I would assume that the StarTron additive will keep them at bay as well.
Bill
That sounds quite good. Thanks I’ll see if Halfords have it.
