Here is a list of all the postings John Gregson 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Aveling and Porter Steam roller TE 23 |
24/06/2019 22:03:09 |
Thanks for last post all sorted sarik are sending a copy £12.50
24/06/2019 09:23:18 |
Aveling and Porter Steam roller TE 23 . 2” scale drawn by John Haining i Making model TE 23 steam roller, as I just got the drawing from a model engineer and the sheet 3 is missing Can you please help we’re I can locate a copy of drawing.
Thread: Smart and brown lathe |
14/04/2019 09:06:50 |
I have emco 8 lathe, can please help with the taper on the headstock as making a new backing plate for my 4 jaw chuck
thanks john
Thread: Making Square Nuts, 4 mm Spanner, 3 mm high in 8BA or M2 |
20/01/2018 09:46:58 |
Get them laser cut, and tap the holes after they been have cut. And ask for a sample before you place the order to see if it works out for you, good luck.
Edited By John Gregson 1 on 20/01/2018 09:49:42 |
Thread: Chilled cast iron piston casting |
05/02/2016 19:46:23 |
Re grind a tungsten carbide tip to a sharp point . Run at low revs and get under the chill, or buy diamond tip.
Thread: Your recommendations to a total beginner looking to use CAD software? |
15/08/2015 23:24:41 |
I still got auto cad 2000 running on very old laptop platform window me and newer laptop On Xp I find this easy to use. John |
Thread: Most economical way to Countersink Stainless steel plate |
14/06/2015 08:11:37 |
John Countersink with three cutting edges slow speed 125 to 250 and slow feed if you have, plenty of cutting fluid . Try liquid soap and oil this as worked for me john |
Thread: Bits of steel for small jobs |
12/06/2015 11:39:57 |
Can you help as lost model engineer work shop no 226. Which was the magazine with the wiper motor speed control. Can you please tell me where I can get another copy or post the information of this we control online. As I have little milling machine from which I am making feed drive John
Thread: Your lathe bench |
18/04/2015 21:18:48 |
i like your lathe work bench, is It able to move about the work shop great idea. You more photographs John
