Member postings for john carruthers
Here is a list of all the postings john carruthers has made in our forums. Click on a thread name to jump to the thread.
Thread: Lady Stephanie
11/01/2016 11:48:25
Pump gear drilled and tapped. It still needs some M2 Allen bolts for assembly and the flanges filed to match. Once the 3/16" bronze balls arrive I can pop them in and file the plugs flush.
Thread: 900 year old Triumph
11/01/2016 09:28:02
I see some nutter has fitted a turbo to one, now that I imagine will be heard throughout the land.
(or at least the scream when he sees his insurance quote).
10/01/2016 08:08:12
Evidence for 900 year old Triumph and how to build a motorcycle...
Thread: small pump
09/01/2016 13:18:13
I use an old lever grease gun head as a small pump.
Thread: Which files should I buy
08/01/2016 17:58:31
>>I have in my mind that Nicholson (?) files are supposed to be good quality? Does anybody know if this is the case?<<
Yes, the older Nicholson files were good, I have a SnapOn branded set of Nicholson warding files from the 70's, as good as the day they were made.
I believe their newer files are sometimes stamped 'Brazil'
Edited By john carruthers on 08/01/2016 17:59:02
08/01/2016 08:53:11
I use Vallorbe/Grobet files now, mainly an 8" second cut. Best money I've spent on tools.
I get mine from Axminster, there are many other suppliers.
http://www.axminster.co.uk/catalogsearch/result/?q=vallorbe+files
01/01/2016 14:03:44
Thread: The Workshop Progress Thread (2016)
01/01/2016 08:22:17
Had LS running (sort of) on air, the valve needs timing.
29/12/2015 15:19:59
After a fortnight moving the sister-in-law and a lurgy I'm trying to get on with Lady Stephanie again. Got the parallel motion roughed out.
Thread: Patrick Moore in Model Engineer
29/12/2015 09:11:58
The Victorians worked out decent scope mounts. 'Keep the weight between the bearings' and you won't go far wrong.
Just been helping sort out the dec drive on the 28" at Greenwich, a rigid yoke on substantial piers.
I also saw PM's heavy mount when it went to AWR for a refit. It never came off the pallet, too heavy to move manually.
Edited By john carruthers on 29/12/2015 09:13:58
Thread: Pillar drill spindle return spring.
24/12/2015 08:22:24
Have you watched this guide?
https://www.youtube.com/watch?v=gWwmgC_TkBQ
17/12/2015 08:46:31
Haven't had much shed time over the last fortnight. I have done some small parts and made a start on the radius links, may have more pics next week.
Looks like your casting kit has more brass parts than the gun metal I had Nick.
Are you not tempted to finish it? I wondered about working in fiddly miniature too, but a set of magnifying goggles helped no end.
Thread: Lathe paint
16/12/2015 08:04:56
Parsons still make their enamels, very tough and hard wearing, easy to apply with brush or spray.
Thread: Gyro build problem
14/12/2015 08:02:12
It's all proportional to the V^2 rather than the M.
Thread: Lathe Super C3 or SC2
11/12/2015 18:36:24
+1 for the SC3.
I acquired one earlier this year, excellent value for money.
I fitted tapered roller bearings from day one and replaced the single half nut with a pair of nuts after a couple of weeks.
Peerless support from Ketan et al at Arc.
Thread: Lathe tachometer
09/12/2015 17:08:37
I use a Wilko bike computer, £5 or less, comes with the magnet as well
Thread: How often do you use the morse taper in your lathe headstock?
07/12/2015 08:05:45
Depending what jobs come in I might use the mt3 spindle taper with Morse collets every day for a week, then not for a month.
Made an adapter to take little Jacobs type chucks too so it earns its keep.
Thread: What is better than Shellac ?
05/12/2015 16:18:07
I use acetone, cheap and easy.
Thread: Internal Combustion Engine Supercharger
04/12/2015 17:48:56
One of my teachers, the late Charlie 'Cog' Wheeler had several 7s, one of which had a tiny brass Shorrock blower.
He also tried using a minor 1000 air pump as used on US export models to help clean up the exhaust.
Then he settled on a modified Alpine conversion kit for a minor 1000, worked well for many years in daily use.
03/12/2015 19:27:18
Superglue or double sided carpet tape.
