A differential gearbox for my hobbing machine
Gustav Thiesen17/02/2017 14:58:53
16 forum posts
18 photos
Many thanks to Chris Robinson!
In February 2016 i asked in this place for background informations about a gear train capable to produce prime number gears.
http://www.model-engineer.co.uk/forums/postings.asp?th=115116
At http://www.lathes.co.uk/ i found a version, which was equipped with a differential gearbox helping to produce prime number gears. The first answers didn't help. So i decided to make a copy of the jacobs
hobbing machine with o normal gearbox.
But in my mind a wish list with two features was still opened:
1. Creation of a planetary gear in the form of a bevel gear differential.
2. Additional supplements to enable helical gear manufacturing.
As far as part 2 is concerned, I am not yet surely determined, since another way by making a connection with one of my dividing attachments with my Milling machine in the sense of a spiral milling device would also be an acceptable way.
The implementation of Part 1, however was difficult to understand, in particular the mathematical
Conditions. After several months' waiting time the author of the article in http://www.lathes.co.uk/,
who is the only one having created a differential gear for the Jacobs machine found my questions and agreed
to help me, especially giving informations about the mathematical foundations.
Thus there was no longer any obstacle to dare to build.
For the bevel gear differential, 4 identical bevel gears were used according to the method of Ivan Law
(20 teeth, module 1), the corresponding spur gear with 40 teeth, module
1.25.
A second shear was quickly created. The first disappointment followed at the same time, as the two
shears proved to be very unstable. A somewhat bumpy run was only possible with hand- and power-
Support. After all, the fundamental running was given.
dscf3471.jpgdscf3472.jpgThus a more stable gear set-up had to be achieved.
Compared with the examples on MEW, an additional idler gear on each side was required, because I had right turning hobs and I wanted that the hob was turning towards the gear blank.
Due to the fact that a fixed size was assigned to each intermediate wheel on each side, a relatively short and stable shear was provided for the second variable idler.
On youtube you can see the machine hobbing a 127 teeth gear.
Youtube: https://youtu.be/M4jmJ65aI0Q
Edited By JasonB on 17/02/2017 15:03:14
Gustav Thiesen17/02/2017 15:07:09
16 forum posts
18 photos
Excuse me, I'm not used to the conditions of the forum. Some text has disappered.
I must say that the first version of the machine with two shears was instable, because the work was done only with the help of my hands to keep the shears calm.
celso ari schlichting16/05/2023 16:13:21
145 forum posts
Hello Gustavo
I found your project a few years ago on YT.
I live in Brazil, and import fees for plans are very high. I saw you built your gear hobber  its made  of solid metal. In addition to making the project more accessible, it seems to me that your version is more robust. Do you have an email so we can talk? I would like to build your version of the machine.
my email is [email protected]
my YT page is https://www.youtube.com/@fazeremcasa520
