Member postings for kevin large
Here is a list of all the postings kevin large has made in our forums. Click on a thread name to jump to the thread.
Thread: Electronic advice
02/02/2019 19:51:04
Hi Dave I don't have a circuit diagram
And in the first pic did you see the little bit burnt out on the thing with the white stuff on no 9 in from the left
02/02/2019 19:43:43
Thanks Dave
The end terminal is earth
When it went I plugged it in the vfd came on then flicked the switch to start lathe and it flashed and that was it
It worked fine day before but was cold in garage and I think the speed was set quite high so don't know if that's what caused it
02/02/2019 18:39:59
Thanks guys I've now ordered
But have now found more problems pics in album
Thread: Vfd update
02/02/2019 16:48:28
Cuople of pics on my album looks like more stuff burnt out is this repairable ?
31/01/2019 21:08:56
Thanks guys I've managed to upload some pics into my album hope they help
31/01/2019 20:15:36
I need a ceramic disc capacitor for a vfd the part no.
JD472MY1
I can only find them in China
My question is does anybody know if I could get one in the UK
Or recommend an equivalent
Thread: Vfd
29/01/2019 15:52:31
Hi all had a look inside vfd today there are 2 little round things like a lolly on 2sticks one looks burnt if I can find out what they are may be able to solder in new ones will try an figure out how to put a picture on
Edited By kevin large on 29/01/2019 16:00:13
27/01/2019 16:00:08
Hi all went to turn lathe on today and vfd flashed and then tripped the electric now it doesn't work it powers up but when flick switch to start lathe it says error 1 which is power protection any ideas is there an internal fuse?
Thread: Gearing
20/11/2018 14:27:31
I am trying to slow an electric motor by gearing I have an 18 tooth driving off the motor I have a 45 tooth and a 24 tooth what needs to drive what
Thread: Boxford model a
04/11/2018 16:47:50
Hi all modified the the spindle and now all done thanks all for advice etc
29/10/2018 18:47:40
Only trouble with modify it I didn't write down the measurement s of the MK1 shaft and I would need the lathe to able to modify it
29/10/2018 12:59:44
I have found the problem it looks like the spindle I have been trying to fit is a MK2 not a MK1
So have a spare MK2 spindle if anyone needs one
28/10/2018 16:57:44
I've tried putting the tailstock up against the spindle front and light tapping of rear bearing but does not seem to go on any more as I said the spacer looks as though it's up against the gear behind maybe the gear needs hammering on further?
I can't tighten the nut enough to pull it all up together
28/10/2018 15:40:18
Hi all I've changed the spindle today or tried got the old one out ok got the new one in but don't seem to able to get the last bit of slack out the rear bearing looks as though it need to in about another 10mm the spacer behind the bearing appears to be up against the gear
Do I need to draw it in with something seems really tight I don't want to damage anything
Any tips appreciated
Thread: new vfd
23/10/2018 18:18:42
Posted by John Rudd on 22/10/2018 19:16:43:
No problem at all....
If the inverter has a programmable parameter for motor max current, you should input that into the relevant parameter to provide protection against overload..
You may need to input the number of poles/speed of the motor too..
Which inverter have you got in mind?
eBay item number:
323255847117 this is the one I am considering thanks for your input
22/10/2018 19:08:04
I need to get a new vfd for my boxford it has a .75kw motor can I use a 1.5kw rated vfd ?
Thread: Valve guides
03/07/2018 19:52:43
triumph used both but cast iron last longer and is fine for road use
03/07/2018 18:38:40
I would like to make new valve guides for my old triumph bike I have some meehanit 250 in stock will this be suitable
Thread: Vfd
17/11/2017 17:09:14
Yes I know what you mean about electronics
The Chinese vfds are confusing I bought my pod off ebay I now have the pod working except for the speed control but will keep at it
16/11/2017 20:07:00
My remote pod has the speed control. on switch. Forward and reverse switch and jog ?
