Here is a list of all the postings Ian L2 has made in our forums. Click on a thread name to jump to the thread.
Thread: What did you do today (2015) |
16/01/2015 19:57:46 |
Posted by Bob Brown 1 on 16/01/2015 14:08:16:
One major problem when a spare is not provided assumes that the puncture is relatively small, I had one go flat on the motorway and by the time I picked up on it the tyre was never going to be inflated with a can of fluid side wall cream crackered. I personally make sure there is a full size spare in the boot as once changed allows you to continue your journey at normal speeds, space saver tyres have a speed restriction and the fluid does not always work. Bob BTW The AA reviews list the type of spare fitted as standard. **LINK** Edited By Bob Brown 1 on 16/01/2015 14:10:48 I was told that one of the latest Jags sports car can have spacesaver spare which is great but when you have fitted it following puncture you have to send for help as the wheel you have just removed wont fit in boot
Thread: hard thrust washer |
16/01/2015 19:22:48 |
Posted by speelwerk on 16/01/2015 18:51:20:
Perhaps one of these? Niko. http://www.fabory.co.uk/pages/categories.html?catId=fabory_0000092195_0000092684_0000092700 Thanks speelwerk. That's exactly what I am looking for problem is they don't sell to anyone only resellers & distributors. and they don't give links to distributors. I will email them and see what they say.
16/01/2015 17:57:57 |
I'm looking for some thin (0.5mm) washers with maybe a 0.6mm option that I can use to take up some movement behind a gear, it is constantly rotating not very fast. The ctr hole is 15.5mm and outside around 24mm could go to 16mm inner and 25 outer. I was thinking thrust washer and thought there must be kits around with a selection of sizes but as yet I have not found any, Any one any idea where I can try? |
Thread: Granite surface table for £6.99 |
14/01/2015 20:55:57 |
I could do with something flat so will have to look round for kitchen worktop. But in mean time I'm using glass shelf out of old display unit not sure how flat glass shelf's are. |
Thread: modification surgestions |
12/01/2015 21:14:38 |
Posted by CotswoldsPhil on 12/01/2015 14:10:10:
Hi Ian, Here is the link to the thread about the Axminster NVR switch. http://www.model-engineer.co.uk/forums/postings.asp?th=102212 Regards Phil H Thanks Phil.
12/01/2015 13:16:00 |
Hi John Thats very good point about chuck coming off need to re think that one. some of your other mods are interesting. Will print the pictures for when I get home. Any one I saw some mention (and link to web site) of start/stop + e.stop unit with no volt release built in for around £15 but cannot find it again if any one has seen it if you could point me in right direction please.
11/01/2015 21:26:30 |
If any one know's how to get to edit my rubbish spelling please tell |
11/01/2015 20:52:30 |
Ok My lathe is only couple weeks away from being fully functioning so now starting to consider little upgrade, The lathe is the Halifax version of the Atlas 10". The motor is switched via fwd/off/rev rotary type switch. Now what I am intending to do is replace it so one can add emergency stop and possibly guard switch that mod is not a problem as I've bean designing, building & wiring machine controls systems for 40 years the problem is the lathe runs on for some time after switch is turned off. The consideration I'm pondering on is putting some form of brake on somewhere then I start to wonder if also some form of clutch so I can allow motor to run and just take up drive via the clutch/brake system. I don't want it to be a complex system one thought was adding disc brake off Push bike (think there called cycles these days Edited By Ian L2 on 11/01/2015 21:20:31 |
Thread: elf and safety gone mad |
11/01/2015 19:25:49 |
Posted by julian atkins on 11/01/2015 13:22:57:
. fatalities have reduced by 87% between 1974 and 2014, and non fatal injuries by 77% between 1974 and 2012. How can anyone come up with a percentage like that comparing 1974 with 2012 as the lower fatalities could also have something to do with fact that an extremely large percentage of the workplaces are now closed down.
11/01/2015 12:18:12 |
Posted by Russell Eberhardt on 11/01/2015 11:18:49:
Posted by jason udall on 11/01/2015 10:24:15:
And still our phones must be turned off to prevent interference at various locations..? Looks like that worked well This started in the days of analogue phones when a few people discovered that if you held your phone near a petrol pump it would under register. It was a fault with the pumps not the phones. The petrol companies introduced the ban on phones on forecourts under the pretence that it was for safety because of a risk of sparks being generated. The myth never went away. Russell. But the pumps where there before the pumps. Think they saying if dropped could cause spark but even not being used it could fall out of one's pocket so that does not work.
10/01/2015 22:08:49 |
I work in industry where the H&S is a joke they are so up there own with "cannot do that your not trained" (I've been doing job 40 years) but the biggest joke and they don't want to listen to me as it will cost them (the management) quite a lot of cash. The workshop is for the most part sheet steel fabrication and welding the overhead crane used to move large bits of steel into position before welding. Joke is all the hand grinders 9" and 12" + hand drills are 240 volt run off mains extension leads. |
Thread: Bubble Foil Insulation for workshop, anybody used this? |
10/01/2015 21:29:24 |
Was only looking at this stuff yesterday as its used as additional insulation under Static caravans. The reviews are quite good. The problem with the thicker loft insulation type stuff on caravans is the mice, and other little wild life love it so thinking the shed could also become hotel for them. |
Thread: play in bearing to spindle |
08/01/2015 21:46:21 |
Posted by Russell Eberhardt on 05/01/2015 11:26:16:
Posted by Ian L2 on 04/01/2015 18:14:14:
Vibrates and sounds clunky but that might be the belts as one is incorrect size and both very old (new one ordered) and appears to run eccentric to the eye.
Tried to get Dti on the register behind chick but Dti jumps like a good-den which is not surprising as having close look, the surface is bit damaged. I had
It sounds as if you are getting into a bit of a pickle. You need to separate the different possibilities for the DTI jumping around. To check the spindle rotate it by hand not under power. That will eliminate any vibration from the motor or belts. When I first got my Atlas I had a fair amount of vibration until I corrected the following:
Russell. Hi Russell You mentioned "replacing the countershaft bearings" I have the atlas part numbers as 9-108 and 9-109, Do you still have the old ones? just wondered if there is any ref numbers so I can try the bearing shop that we use at work to see if they are common easy to get bearings. I have new belts and without spindle belt fitted there is quite a lot of clunking from countershaft. Thanks |
05/01/2015 21:25:15 |
Well just had another go with Dti. Tonight I put clean M.T in Spindle (also cleaned inside) the M.T sticks out about 20mm from spindle so I had Dti on M.T about 10mm from spindle. At this point I get Dti fluctuation of 0.02mm (not sure what would be good reading this close) but I did noticed the Dti is not steady as in it jumps between readings. Would poor bearing cause jumps on Dti. |
04/01/2015 20:55:32 |
Posted by speelwerk on 04/01/2015 16:34:20:
Will give it a go wont cost much and its not permanent so now't to loose. But know idea where I can get it from! what's it used for might point me in direction of supply. This is what I use but no doubt there is UK supplier. http://shop.vogel-germany.de/product_info.php?language=en&info=p4826_thickness-gauge-foil-din-1544--brass--0-025-mm--2500-mm-x-150-mm.html&= It is very thin and you will have to experiment with it what the best way is to use it, if you can use it at all. Niko. They also have it in stainless with a thickness of 0.010 and 0.020 mm. Edited By speelwerk on 04/01/2015 16:41:19 Looking at how much I would need to purchase and a couple thickness I think I'm going to get some feeler gauges that I can cut into 3 spaces and see if I can determine just how much I need to increase by & by using them as packers will also help with determine if spindle is true. from that I can talk to platters with some knowledge as to how much I need to build up by. |
04/01/2015 18:35:09 |
Will give it a go wont cost much and its not permanent so now't to loose. But know idea where I can get it from! what's it used for might point me in direction of supply. This is what I use but no doubt there is UK supplier. http://shop.vogel-germany.de/product_info.php?language=en&info=p4826_thickness-gauge-foil-din-1544--brass--0-025-mm--2500-mm-x-150-mm.html&= It is very thin and you will have to experiment with it what the best way is to use it, if you can use it at all. Niko. They also have it in stainless with a thickness of 0.010 and 0.020 mm. Edited By speelwerk on 04/01/2015 16:41:19 I'm thinking to start with putting this in in 3 strips about 10mm wide evenly spaced around then depending on results going up to 6 evenly spaced. if nothing else will eliminate the bad fit from smoothness
04/01/2015 18:14:14 |
Posted by Russell Eberhardt on 04/01/2015 16:26:45:
Can you explain what you mean by "not as smooth as one would expect". Do you mean that there is vibration or grittiness? Or do you mean that it has a wobble as it rotates? The place to check for the spindle running true is on the register behind the thread on the spindle nose. I get 0.005 mm on the cylindrical part and 0.01 mm and I've never changed the bearings in the 40 years I've owned the lathe although I did remove them and give them a good clean in solvent. Russell Vibrates and sounds clunky but that might be the belts as one is incorrect size and both very old (new one ordered) and appears to run eccentric to the eye. Tried to get Dti on the register behind chick but Dti jumps like a good-den which is not surprising as having close look, the surface is bit damaged. I had
04/01/2015 15:35:38 |
Posted by speelwerk on 04/01/2015 11:35:03:
Before you start electroplating you can try if thin brass foil (0.025 mm) wrapped around the spindle does it, Niko. Niko Will give it a go wont cost much and its not permanent so now't to loose. But know idea where I can get it from! what's it used for might point me in direction of supply. Russell will check on your flat disk comment as in box parts there is some more parts which looking at them have hot been fitted for some years. As it happens I've had it running today all be it on the old bearings as I was interested to see how it ran with the old ones and I only needed to get some parts rotating to clean with wet and dry. Well its not as smooth as one would expect so here is my predicament:- (A) It could be the old bearings that aren't as good as could be. Don't really want to fit new ones at chuck end yet as once its on it's stopping on. (B) It could be the m/c shop that skimmed it did not have it bob on. Would hope not the case as its pretty good place with CNC, m/c's and they were aware of what it was for The place i work use them and ( (C) The movement this thread was started for is the cause. (D) Spindle is bent. (E) 3 Jaw chuck is not up to much. I'm measuring with DTI on face of backing plate where it screws to spindle. I will pop chuck back off and see if there's any where else I can get DTi. Probably need to get spindle checked for trueness to start with But not sure how I can do it as I've not another lathe!
04/01/2015 11:01:34 |
Posted by Ian S C on 04/01/2015 10:01:48:
With Bearing lock the bearing can be moved with ordinary bearing tools, it's not a shaft lock. The original bearing wasn't going to move much, pressed on the shaft, the shoulder I presume locates the bearing inner race. Ian S C Hi Ian S C I will try get photo later but the bearing does not go up-to the shoulder, the outer race is held ridged in housing and the inner race pushed into the rollers taking up movement & pre-loading by collar being tightened (not much more that hand tight) and locked using grub screw onto threads. If I end up using lock tight I will have to keep rotating the spindle every now and then so as to not cause bearing damage (not sure how often one should rotate) not beyond the realms of automatically doing this on time clock. Need to look at cost to get shaft electroplated and ground to correct tolerance then I can decide which way to go. Photos added:- Edited By Ian L2 on 04/01/2015 11:31:47 |
Thread: Engineers level |
03/01/2015 22:27:06 |
Posted by Ian Phillips on 03/01/2015 21:47:15:
In a dream last night, the simple answer came to solve the lathe levelling problem! It was a technique to eliminate even the sag of a test bar and dramatically reduce any bending effects on the lathe bed due to is weight. I was thinking about Bob's large diameter tubular test bar and realised that if his tube had unequal wall thickness it would sag different amounts depending on its rotational position. Unfortunately the technique will not work with all makes of lathes (Myford's with the little oil reservoir gadgets on the headstock bearings would be tricky but sealed for life rolling bearings should be OK), Long bed lathes in workshops with limited headroom would be a challenge too, but otherwise all we have to do is change the lathe orientation so that the main spindle rotates in the vertical axis. Who is going to be the first to try it? Ian P
