Member postings for Tim Richards
Here is a list of all the postings Tim Richards has made in our forums. Click on a thread name to jump to the thread.
Thread: EN8 steel finish
29/06/2014 12:33:31
I am turning EN8 steel for a cylinder but the finish I'm getting seems a bit rough I have tried a new tip in the tool and played around with the speed, any one any ideas
Thread: What IC engine to make
26/05/2014 08:46:05
Drawings and pic,s are good I will give it a go
25/05/2014 15:19:55
Hi , does any one know of a simple glow engine to make and where I can get some working drawings from. It is my first engine build so that's why it wants to be simple, I have a lathe but no milling machine so milling would have to be done on lathe. Any help would be much appreciated.
Tim
Thread: Nitralloy
20/05/2014 18:00:21
It will be know more than 3.5cc. Diesel or glow
many thanks. Tim
20/05/2014 17:26:02
Hi can any one tell me if there is a alternative metal to use than nitralloy for making a crankshaft for model engine, or can any one let me know where I can buy some
thanks. Tim
Thread: Myford super7 clutch
14/04/2014 16:57:51
I set the adjuster screw and tightened the grub screw it was ok for 10 minutes then slipping again , when I checked the grub screw it was still tight so it looks like I will have to take it apart to see if any thing is broken
thanks all for the advice
Tim
10/04/2014 18:39:57
I have a myford super7 don't know how old it is ( can't find the serial number ) but it has a oil spy glass . The clutch is slipping and every time I ajust the clutch it starts slipping again after about ten minutes.
Has any one had the same problem or know how to fix it.
Many thanks. Tim
