Here is a list of all the postings Dave Daniels has made in our forums. Click on a thread name to jump to the thread.
Thread: Why don't we make models of things like this? |
06/03/2017 12:03:27 |
I have a fair interest in this sort of thing: http://www.sparkmuseum.com/MOTORS.HTM One of the stoppers ( ? ) is the difficulty of getting Silicon Iron laminations or Soft Iron. Tried some years ago but got nowhere. One educational supplies site actually listed 3/8" soft iron rods but were actually mild steel when quizzed. Unless someone knows where the stuff can be obtained in smallish quantities. D.
Thread: Polycarbonate sheet |
14/02/2017 14:26:39 |
Doesn't have to penetrate ... I've used it to get adhesive heat shrink off. If you can get an edge it appears to creep in and destroy the bond.
Not a quick job I admit, but it worked.
Relatively cheap to try it. If it doesn't work you still have the can for attacking sticky labels. D.
14/02/2017 14:01:19 |
You might try something like 'Label Off' spray. I get it from Rapid Electronics but no doubt similar stuff is available elsewhere. Fairly benign, I've used to to get the damn sticky labels of plastic stuff many times and it does not seem to affect them. D. https://www.rapidonline.com/kontakt-chemie-208106091230-label-off-50-label-remover-200ml-87-0655
Edited By Dave Daniels on 14/02/2017 14:03:22 |
Thread: Fireproof Overalls |
04/02/2017 15:01:56 |
Posted by Bazyle on 04/02/2017 12:13:03:
I saw a video on cellulose (chopped newspaper) house insulation that was treated with something that made it very non-flammable but can't remember what that was. We have to get our exhibition table covers treated with flame retardant too. There is also a video of various loft insulation being flame tested and a product made from chopped blue jeans (ie cotton) burned nicely. So anyone know what the treatment is? I think it was some quite common chemical sounding a bit like 'borate'.
Sodium Silicate aka Water Glass has some fireproofing effect.
D. |
Thread: VAT criticisms? |
15/12/2016 07:17:49 |
A year or so ago I bought some L297 chips from China, like these: Not that seller IIRC but some £3 for 10, P&P Incl. Duly arrived, Postie demanded some £11 ( I think ) to release As these things are currently some £9 a pop from Farnell I didn't have much confidence but worth a punt for 30p. And they do seem to work fine. I have had other cheapo stuff from China delivered OK. No idea why that delivery went wrong ??
D.
Edited By Dave Daniels on 15/12/2016 07:23:41 |
Thread: Arduinos and Microcontrollers ref: Rotary Table Mew 249 |
13/12/2016 10:04:13 |
As an aside to this 'LCD no werky' thing, if you get an 'X-Temp' or extended temperature range device, the bottom end of the contrast pot. has to go to a negative voltage not to 0V as usual. I don't know if this pertains to ALL X-Temp displays but did to 4 I was given. I've been in that hole, and it ain't at all obvious until a severe shufti at the data sheet reveals the pot. goes to -V ... Can be a -5V derived from the +5V using a ICL7660 chip Just a thought ..
D.
Edited By Dave Daniels on 13/12/2016 10:05:20 Edited By Dave Daniels on 13/12/2016 10:05:38 |
Thread: Swiss Tec - Definitive information please! |
25/11/2016 19:38:37 |
It appears that this Proxxon lathe originates from Luxembourg .. Whether all Proxxon lathes do I don't know, that's the only reference I found. ( Just knew Farnell sold them & they give country of origin for products they sell ). ( Isn't Luxembourg where Junckers orginates ? Maybe not much of a recommendation then eh ?
D.
Edited By Dave Daniels on 25/11/2016 19:39:03 |
Thread: Advice on Schottky Diodes, please |
23/10/2016 21:48:31 |
Should anyone have any interest in the MCR1 etc. and EL Lucas dynamos the BSA service sheets are here: Have to agree with Clive re: the average motor cycle mechanic, in general they just used to faff with them until they sort-of worked .. D.
Thread: Internet Problems |
06/09/2016 21:41:33 |
I had some 6-7 years trouble free Internet with Tiscali .. and then it became Talktalk ... That's when the crap started ... Line dropouts, no broadband, reset router etc. etc. etc. Went on for months off and on ... 'Engineer' came and fitted new router, didn't work so he disappeared for 3 days and having spent 3 lifetimes on their useless phone line another engineer came and fitted another new router which sort of worked, for a day or so, then back to situation normal ie,. no Internet. Problems apparently caused by internal sockets / wiring / filters etc. etc. ie. Any damn thing you like except Talktalk .. So, in Dec. 2013 I dumped the incompetent Goons and went to PlusNet. Ever since then my apparently shaky set-up has worked quite well for some reason ... Dave
Edited By Dave Daniels on 06/09/2016 21:42:56 |
Thread: Moderators powers and duties |
05/08/2016 20:31:58 |
Creed 7B ? Brings back memories to a ex-RAF Telegraph Fitter. And all the rest .. 7BRP, 85R, 7PN3 (?) etc. etc. Some stuff here about replica Enigmas and other stuff if you're interested. Click the pic. I knew the code as Murray Code, maybe it's the same thing? IIRC the sequence was often CR-LF-L/S-L/S to give the delay for the C.Ret. http://cryptomuseum.com/crypto/baudot.htm
Here's one of the other things I worked on: http://cryptomuseum.com/crypto/uk/5uco/index.htm It does intrigue me how you managed to lose a 7B .. not exactly 'loseable' IMHO. D. Edited By Dave Daniels on 05/08/2016 20:33:24 Edited By Dave Daniels on 05/08/2016 20:41:21 Edited By Dave Daniels on 05/08/2016 20:44:33 |
Thread: Electronic ignorance |
30/07/2016 20:27:59 |
One book I have Is pretty good for analogue etc. Not as erudite as A of E ( which I also have ) but much more 'holdy-handy' Gives all the useful info. on op-amps, Schmitt Triggers, comparators etc. etc. but in a more pictorial form than the A of E.
That is the edition I have. I think later ones are available. D. Edited By Dave Daniels on 30/07/2016 20:29:04 Edited By Dave Daniels on 30/07/2016 20:31:22 |
30/07/2016 12:24:11 |
http://sound.westhost.com/beginners.htm
This might help.
Sorry about all the edits .
Edited By Dave Daniels on 30/07/2016 12:25:24 Edited By Dave Daniels on 30/07/2016 12:29:38 Edited By Dave Daniels on 30/07/2016 12:30:51 |
Thread: WM16 Advice |
25/07/2016 08:29:24 |
I have a WM16 and it is somewhat noisy. Not the sort of machine to use in a multi occupancy building. The SX3 is much quieter but weighs in a fair bit above your £1k. This one also does but it may be quieter than a WM16: Looks similar in spec. to a belt drive WM16 on first glance and also may have R8 which would be an asset IMHO, but this option is OOS at the moment. D.
Edited By Dave Daniels on 25/07/2016 08:30:27 Edited By Dave Daniels on 25/07/2016 08:32:00 Edited By Dave Daniels on 25/07/2016 08:32:37 |
Thread: Might be time to change the car blues |
29/06/2016 21:03:42 |
Posted by Ajohnw on 29/06/2016 20:02:05:
John - Edited By Ajohnw on 29/06/2016 20:03:01 I have 2.0D XC , from new on a 15 plate. Just done about 6k now. I have arthritis of the spine and I find it very good indeed to drive. Don't do too many short runs, my MPG is 49.3 at the moment. Working out the miles and diesel put in the car computer wotsit seems to be accurate to pessimistic. I think it does 52.1 ?
Faultless on delivery and still is.
Dave Edited By Dave Daniels on 29/06/2016 21:05:41 |
Thread: Sieg X3 table locking handle source? |
16/06/2016 21:59:13 |
Cromwell Tools have them in various sizes:
D.
Edited By Dave Daniels on 16/06/2016 22:01:15 |
Thread: electric - measuring the kwh for my workshop |
25/04/2016 18:29:07 |
Or this one: Dave
Thread: James May and the telephone |
06/04/2016 09:49:59 |
I have several Quick-Wedge screw starters of various sizes. Last replaced one about 18 months ago from here: Dave.
Thread: Welder wiring |
04/04/2016 17:52:17 |
That looks very much like my long gone Cytringhan Bantam welder. IF it is you can use it on 1 Ph. 240V. I did on a 16A supply but you can't get the full grunt from it. The 415V is obtained between 2 phases, not 3 IIRC. but not certain. You may get some confirmation by searching for Cytringhan Bantam info.
Beware! The oil may have PCB's in it ...
D.
Edited By Dave Daniels on 04/04/2016 17:53:06 |
Thread: holding small screws |
10/03/2016 14:04:42 |
These are what I use: I have used them on small screws but on the smaller UNF/UNC screws. I do know they work on 2-56 UNF but I suppose it depends on the slot width. Never knowingly used them on the BA sizes you mention. Dave
Edited By Dave Daniels on 10/03/2016 14:06:56 |
Thread: Useless light bulbs. |
28/02/2016 19:08:35 |
Light output for a filament lamp is given by Volts ^ 3.4 . So, a 5% reduction in voltage will drop the light output by some 16%. It will obviously rise by 16% for a 5% overvoltage. Not sure but I think light output is directly proportional to filament temperature. D. Edited By Dave Daniels on 28/02/2016 19:14:38 Edited By Dave Daniels on 28/02/2016 19:16:04 |
