Here is a list of all the postings Cabinet Enforcer has made in our forums. Click on a thread name to jump to the thread.
Thread: Spot Facing With Slot Drill? |
16/05/2020 13:16:46 |
Posted by Dr_GMJN on 16/05/2020 12:12:09:
I did some reading, and I think I'll need to hold it cherry red for 5 minutes, dunk in oil or salt water, then straw yellow and dunk in water (does it have to be oil)? Hopefully our gas poker will be ok. Making tools and heat treatment (apart from annealing photo-etched brass) is completely new to me, so any further comments on either are of course very welcome. Compare your cutter to Jasons on the previous page, yours has a lot more relief, and will cut quite aggressively, I would tone it down a touch. You only really need the tips of the cutter to actually be hard, so I wouldnt worry excessively about soak times, remember that this process can be attempted on the same part as often as needed, if it all goes wrong just heat it up, cool slowly in air and you have a soft part you can reshape if needed, before having another try. |
Thread: Ideal Extruder Temperature for PLA |
07/05/2020 10:07:53 |
My experience has been that PLA is fairly tolerant stuff, and that temperature variation is something to finesse the last few percent of print quality, most of the time. There are way too many other factors which affect issues such as stringing for temperature to solve alone; retraction settings in particular, since many printer maufacturers turn these down, or some of them off to speed prints up. Cura in particular seems to default to turning off the lift Z for travel and associated retractions, and alters the timing and routing of these moves all in favour of speed. At least half the different reels of PLA I have bought have had temperature recommendations on them, which have been satisfactory, though to be honest I find 190degC is good enough most of the time that I only vary it if I have a specific problem. Basically, the temperature question is like a "speeds and feeds?" question where you are still able to vary the diameter of the part, and what type of cutting tool you're using. The ballpark figure should be good enough 99% of the time, and when it isn't there will be part and other specific issues to consider. |
Thread: New hobby lathe for retired engineer? |
05/05/2020 12:25:22 |
Sign up to their email spam letter, and they will send you one periodically. Most stores have one in (or the CL500, same lathe with added milling monstrosity) so at least you can see one in person and judge the (lack of) quality for yourself. |
05/05/2020 11:37:53 |
Posted by Fred Bloggs 3 on 05/05/2020 10:49:26: In a nutshell, I don't expect much at all. FB Well in that case, the Clarke CL430 is right up your street, it can be had in budget if picked up on one of machinemarts many "vat free" promotions and comes the closest to your requirements, bore is 26mm and swing 305mm. I would only recommend one to a person I was intending to put off lathework for life though.
Thread: Puzzle |
25/04/2020 16:16:46 |
While the hidden complexity and the machining of that one is admirable, I do like like the elegant simplicity of this puzzle, and it's simple enough to knock up in an afternoon, making a nice gift. |
Thread: Coronavirus |
15/03/2020 19:30:39 |
Posted by J Hancock on 15/03/2020 14:13:59: A right load of old chuff Snopes says you may be a credulous idiot. https://www.snopes.com/fact-check/taiwan-experts-self-check/
Edited By Cabinet Enforcer on 15/03/2020 19:31:31 |
Thread: Warco WM280V-F Gearbox |
14/03/2020 15:42:06 |
Posted by Barry Chamberlain 1 on 11/03/2020 20:40:09:
Wondering if anyone has any tips on replacing gears on the WM280V-F Be nice to get some ideas on how to replace broken gears. Original problem was stiff gear change levers which I now know was to down to badly worn/broken gear teeth. I have the front cover plate off. Any help welcomed. Is there some reason Warco cannot provide spare parts? Given they are plain gears running in oil they should last practically forever, there will be a reason for the failure and you need to work out what it is before fitting new gears.
Thread: What would I use a Plasma Cutter For |
10/02/2020 09:53:06 |
Just posting to point out that the one in Lidl this Thursday is a 30A model not the 40A model that Lidl have offered previously in other parts of Europe, and which is reviewed in the link above. |
Thread: Electric welder at Lidl |
09/02/2020 01:19:45 |
Just as a follow up, Lidl now list the plasma cutter as for sale on the 13th Feb for 80squids. I think this is the first time that one of these cheap Chinese plasmas has been retailed in the UK. |
Thread: Making Rings |
21/01/2020 01:58:38 |
There are quite a few .999 silver 1 ounce coin designs issued by the royal mint which could make nice rings. Also the silver £20 coin issued for the queen's 90th birthday with a crown and 9 roses in a circle really suits being made into a ring. If you want matched reeding on the edges then you'll probably have to make your own knurl to match, or remove the reeded edge and re-do it with a bought knurl. A shop made knurl wouldn't need to be all that hard if only used for forming silver. |
Thread: The blind leading the blind |
10/01/2020 10:40:46 |
Danny, I don't really understand why you are complaining to the TAFE, they will obviously ignore you, why not make a complaint to your local H+S regulator, who might even have the actual power to do something???
Or alternatively, Australian ad standards might also have some teeth they could use.
https://adstandards.com.au/lodge-complaint
Edited By Cabinet Enforcer on 10/01/2020 10:56:31 |
Thread: Looking to buy a better toolpost |
06/01/2020 11:07:35 |
There isn't much meat on the topslide to be cutting off, to reduce stack height it is much better to reduce the height of the boss which the topslide bolts to. That's what I did to be able to use the 16 and 20mm toolholders on my boxford size Dickson toolpost. |
05/01/2020 19:05:29 |
Posted by petro1head on 05/01/2020 18:52:28:
Posted by Neil Wyatt on 05/01/2020 18:44:56:
From the original post it looks like the toolholders are moving, not the toolpost. I've found the Arc ones very good but check 'dimension H' suits your machine. Neil Been reading up on here and watching youtube vids and they seem to be highly regarded and better than piston types expensive but worth it in my opinion Edited By petro1head on 05/01/2020 18:52:59 That may well be true, but you already have a Dickson type toolpost which is also a well regarded design, it would seem easier to sort out the problem than splash the cash on a new one.
How well do the holders fit the post, and do they clamp when just slightly "over center"? |
05/01/2020 18:27:42 |
I also have a Dickson toolpost on a wm280, and there was a lack of sufficient clamping force onto the topslide, I fitted a needle roller thrust bearing and suitable washers which helped. Should I find a round tuit, then I will be fitting a larger diameter post to the topslide, as it is too spindly IMO, I think this will cure the problem.
I don't think changing the toolpost type will help much, it would only assist if it reduces overhang, and sometimes, eg boring, the overhang will be much the same anyway and the problem will resurface. Edited By Cabinet Enforcer on 05/01/2020 18:28:23 |
Thread: Yet another 'which mill shall I buy' |
12/11/2019 00:06:19 |
I have an AMAT45V, I'm fairly sure they aren't 1500quid though, only the geared head ones with the six speed box were ever near that cheap?
I put mine on a (temporaryish) stand made from 100mm fencing posts, it's easily strong enough, but you description of your bench sounds like it would provide differing support across the bottom, I could imagine issues with vibration when cutting, 300kg is a lot and having it all bearing straight down over seems sensible, you do not want anything that big starting to jump about. Forgetting the stand for a moment, you said it's to go in a shed, is it on a concrete slab? Also, even breaking it down into parts leaves you with bits that still really need lifting equipment, and a normal sized doorway will present challenges. The amount of space needed shouldn't be underestimated, table length plus movement plus handles plus a bit of room adds up to quite a lot. I have a DRO as supplied, and couldn't imagine trying to do any sensible work without it, big tables mean an awful lot of cranking handles, this is much more manageable when you don't have to worry about counting turns, the ability to easily do PCDs is also worth the price alone.
I do like the machine, it has a lot of capability for the money, but my machining experience is pretty limited so I'm not too qualified to give an opinion. |
Thread: WM 280V lathe with inverter drive advice |
23/10/2019 16:03:17 |
Posted by JasonB on 23/10/2019 12:26:55:
I have a Myford size Dickson on mine as that is what was on my previous lathe an dI had plenty of tool holders. If starting from scratch then the "boxford" size would be better I have a boxford sized Dickson qctp on my 280, I agree that it is probably the "right" size, but the standard centre height range of that model is too high for the lathe, I had to machine a replacement part for the topslide adjustment stack and shorten the t-bolts.
When I get a round tuit, I am going to change to a "4 bolt clamp" and change parts to lower it further so that the extended 20mm holders can be fully utilized. |
Thread: Question from a customer |
08/10/2019 15:38:17 |
Posted by Robert Atkinson 2 on 07/10/2019 12:54:22:
Great Post SOD Re "Ought to be emphasised that the size of the boiler is all important. It limits their capacity to store energy. " So true, this is where the 250 Bar/Litre "rule comes from. If the product of pressure and volume is less than 250 many of the regulations don't apply. 250l tank at 1 bar is same energy as a 1l at 250 bar. Robert G8RPI It's not Bar/litre if it's the product, also said disapplication specifically says it cannot be used if steam is the relevant fluid. |
Thread: Equity release! |
31/08/2019 06:20:39 |
I'm afraid I have no constructive input, but when I saw the title I was expecting a thread on selling a shaper |
Thread: Upgrading to fibre optic broadband |
31/07/2019 17:06:24 |
Robin, I notice no-one has directly answered your questions and most have just started moaning, seems standard on here at the moment, must be the heat.
If you get 20Mb/s on ADSL, then assuming openreach can connect you to FTTC you should get more, either near 40 or near 80 depending on how much you pay. You can find out directly what you will get from this bt page:**LINK** If you are talktalk you may need to use the address check version linked to on that page. It's not a guarantee, as sometimes you can be connected to a different box, but it gives a good idea.
ETA, I had to go to FTTC just to get up to 20, you lucky blighter. Edited By Cabinet Enforcer on 31/07/2019 17:08:12 |
Thread: Engineers blue alternatives |
19/07/2019 11:52:21 |
Posted by Douglas Johnston on 16/07/2019 11:04:46:
I have been trying out some scraping lately and saw on youtube that some people use a roller on the surface plate to spread the blue indicator over the surface. I was thinking about trying that but can't find any reference for the type of roller needed. There seem to be hard rubber rollers and soft rubber ones and probably ones in between. Is there a scraping mastermind out there that can recommend a suitable type of roller? Doug I think you probably should have started a new thread Doug...
Try looking for the term "brayer" as that's the proper name for an ink roller, as the "ink" is quite thick and the surfaces hard, you will need a pretty firm roller to ensure an even spread. |
