Member postings for Grenville Hunt
Here is a list of all the postings Grenville Hunt has made in our forums. Click on a thread name to jump to the thread.
Thread: Mystery Tool.
02/04/2020 14:28:34
I have an identical one for removing the pointers from pressure gauges!
Thread: LPG heater- fumes
28/11/2019 18:43:21
+1 for Rockingdodge,
I use a 3.2kW Webasto night heater in my workshop it uses around 1/4 ltr of diesel per hour at full power, no fumes no water vapour & cosy warm in 15 mins.
Gren.
Thread: "Mystery" Tool
24/11/2019 16:58:43
Looks like a UFO traveling on the A6 toward Matlock!
Thread: Source of Stainless Strip
06/11/2019 16:26:24
What about s/steel banding used by packaging companies for pallets
Gren.
Thread: Morning from the Midlands
11/10/2019 18:08:35
Welcome from an East Midlander and ex rail engineer (retired)
Gren.
Thread: Rusty pitted base - best way to treat ?
15/09/2019 15:25:38
As IanT says make sure it is perfectly dry (I place mine on a radiator for half an hour) then use primer I've done hundreds of parts this way and never had a problem with re-appearing rust.
Thread: Motor wiring
14/09/2019 08:47:21
In a word NO, just make sure you identify the earth wire and connect accordingly.
Thread: O rings.
11/09/2019 14:21:47
Could you not cut one of your kit O rings to size and superglue the ends as you would with a splicing kit?
Thread: Vickers Bl 8 inch Howitzer cannon of 1917
08/09/2019 16:25:32
That is truly amazing work!
Thread: Hi from Derbyshire
05/09/2019 17:13:59
Thank's for the welcome David.
03/09/2019 16:15:50
Hi all my name is Gren Hunt, I have been lurking in the background of this forum for a few years now so I thought it about time to introduce myself, I am a recently retired Electrical Engineer and Geologist (don't ask) my interest are completing a 3 1/2" large boiler "Tich" from my late father in law, designing and building industrial art and engineering in general, I have a large well equipped workshop consisting of warco 250 lathe, wm14 mill and associated tooling.
Gren.
