Former Member | 14/09/2019 09:44:56 |
1329 forum posts | [This posting has been removed] |
Brian H | 14/09/2019 10:07:28 |
![]() 2312 forum posts 112 photos | I'd make a new one. Brian |
IanT | 14/09/2019 10:18:14 |
2147 forum posts 222 photos | I like using electrolytic de-rusting Bill. It's simple and cheap to do (assuming you already have a battery charger) and it will not damage the part any further than the rust has already done so (e.g. pitting). It will also tend to loosen any paint that is already flaking. A good scrub with a very fine wire wool will usually clean things up nicely. Dry the part and prime it quickly before it re-rusts.... Regards, IanT |
Paul Valente | 14/09/2019 10:33:08 |
![]() 9 forum posts | You could try Oxalic Acid. Available via EBay etc. Soak rinse and repeat as necessary. It’s cheap and quite effective. |
thaiguzzi | 14/09/2019 10:54:32 |
![]() 704 forum posts 131 photos | Put it in some white vinegar and see how you get on. |
Former Member | 14/09/2019 11:16:06 |
old mart | 14/09/2019 21:08:49 |
4655 forum posts 304 photos | Be aware that shot blasting thin sections can cause distortion, the blasted side will end up convex, and even if you blast the other side, it is unlikely to go back flat. |
Mike Poole | 15/09/2019 00:23:46 |
![]() 3676 forum posts 82 photos | Brick cleaner is very good, I saw a can in wickes a few weeks ago which surprised me as I thought corrosive materials like that had been withdrawn from public sale. Mike |
Former Member | 15/09/2019 13:36:21 |
Grenville Hunt | 15/09/2019 15:25:38 |
![]() 31 forum posts | As IanT says make sure it is perfectly dry (I place mine on a radiator for half an hour) then use primer I've done hundreds of parts this way and never had a problem with re-appearing rust. |
Former Member | 16/09/2019 18:21:52 |
Former Member | 16/09/2019 19:23:14 |
