Here is a list of all the postings mick70 has made in our forums. Click on a thread name to jump to the thread.
Thread: 5c length |
12/08/2015 05:59:51 |
Finally bit of luck after bad week the 5c collet fits perfectly. |
08/08/2015 12:36:20 |
Bazyle link was very useful. this is sleeve someone made for it at some point.
08/08/2015 11:19:03 |
looks like it should fit, just ordered one to try if it does will get more. will need to make drawbar for it first. |
08/08/2015 08:48:25 |
got what i assume is a collet holder with my clarkson. id matches dia of 5c collet on arc site. but doesn't give length of holder is 3" would that be right for 5c collet? cheers |
Thread: polishing in the lathe |
05/08/2015 16:07:06 |
cheers for link Lambton, will show my 7yr old as he is learning on lathe with me and at club.
Thread: wiring southbend switch |
02/08/2015 14:52:07 |
all i have is short 3 core lead coming out of motor to plug. i got it with drill press from factory that was closing down. |
02/08/2015 13:42:32 |
does anyone know how to wire up the dewhirst type forward/reverse switch that goes on southbend? look on google images and can't find one with 3 connections each side only with 4. have only got 3 wires coming out of motor L N E
cheers Edited By naughtyboy on 02/08/2015 13:44:25 |
Thread: dust extractors |
31/07/2015 14:04:19 |
normally take my sanders outside to do my sanding. but moving soon and will have space for dedicated space for grinding and sanding. looking for recommendations for decent dust extractors pls. be used on clarkson and belt sanders, not prob if i have to swap pipe over as will only be using one at a time. |
Thread: storing grinding wheels |
31/07/2015 13:50:37 |
Posted by David Clark 1 on 31/07/2015 12:52:20:
Grinding wheels should be stored vertically in a purpose made rack. That's what I thought and how we used to store them at my old place. But looking at images on Google see some pictures where they are mounted on pegs on board.
31/07/2015 12:07:28 |
how do people store their grinding wheels? only got couple at moment so sit flat in drawer, but as get more use out of my clarkson can see no rising. |
Thread: Clarkson rests |
27/07/2015 05:57:22 |
My mk 1 Clarkson came with the universal head and brackets with centres. Can I use the toothrests from the later models?
Thread: What did you do today (2015) |
25/07/2015 10:58:09 |
built my boy a tadpole from the atomic zombie plans. one for me with underseat steering is on my list of to dos. planning on second set of cogs halfway along run to large cog which is attached to small cog to get more power to back wheels. also making shorter crank arms for mine. hope link works never had luck putting pics up here, and kids are away so cant help. [URL=http://s1269.photobucket.com/user/steptash/media/aaaa1_zps5hkfns78.jpg.html][IMG]http://i1269.photobucket.com/albums/jj593/steptash/aaaa1_zps5hkfns78.jpg[/IMG][/URL]
link to my build that modded to be my boys. http://forum.atomiczombie.com/showthread.php/9273-street-warrior-build?highlight=naughtyboy Edited By naughtyboy on 25/07/2015 11:01:06 |
Thread: which wheel dresser? |
23/07/2015 14:52:13 |
that's great cheers. Ian buying the clarkson wiped me out this month even though only scrap value. now rewired and working lovely.
23/07/2015 14:00:37 |
sorry another Q about my clarkson tool cutter/grinder.
a lot of i have read suggest a single point dresser for wheels. got choice of .25, .5 or .75 carat. which is best? can only get one this month can get others if need them next month.
cheers |
Thread: clarkson wheels |
23/07/2015 11:47:37 |
cheers for that. will look at the 6" as got loads of new ones from when old place closed down. have done the course for wheel changing at rospa. |
22/07/2015 15:37:37 |
on mk 1 clarkson tool/cutter grinder ibought can i fit 6" wheels? will make new guard for it. just struggling to find wheels for it. |
Thread: using Clarkson for drills |
19/07/2015 19:54:54 |
looks like Ketan is getting all of next months overtime money.
19/07/2015 11:54:15 |
Clarkson sharpener I got hasn't got holders with it. Will the 5c c type holder arc sell be ok to use for holding drill bits to sharpen?
Fair way of using it yet but thinking ahead. |
17/07/2015 17:00:37 |
got my clarkson grinder wired and running. now need to learn how to use it. oh and get some wheels for it ones with were unknown to me in sofar not sure how old etc so want new to be safe |
