Member postings for mick70
Here is a list of all the postings mick70 has made in our forums. Click on a thread name to jump to the thread.
Thread: Digital copies of MEW on disc
22/10/2016 13:41:40
+ another for dvd.
and if the ME one got done as well.
Thread: revolving chucks
22/10/2016 10:30:21
that simple?
was overthinking it, thought it was going to be more complicated.
are they worth having?
Edited By naughtyboy on 22/10/2016 10:30:49
22/10/2016 10:00:17
just looking through arc catalogue and seen some revolving chucks and backplates.
they are on mt2 to fit talstock.
what are they used for?
Thread: radial arm drill.
21/10/2016 13:56:55
been offered a radial arm drill that was designed for woodworking with dead motor.
guy says to fast for metal working is going to get me speeds later.
i have a spare drill press motor from metal working one.
am thinking if pulleys are same i can just put motor on it.
if not will get speed controlled motor for it.
other than speeds is there any reason i can't use it for metal working?
Thread: what do you use when designing?
21/10/2016 07:49:36
Just been reading on another forum about what people use when designing stuff.
was quite surprised how many people still do it by hand.
i admit i do it on drawing board by hand as don't get on with electronic gizmos.
even carry small pad to put ideas on or make notes for if i see something i like idea off, wish i did as would love to have go at 3d printing.
so what does everyone else use?
Thread: morse taper
20/10/2016 14:32:36
did at club i belong to but was very gentle was only 24mm hole.
i was prob over cautios but bid build up to it in sizes.
Thread: Wanted
15/10/2016 16:18:42
dunno if it will work for what you need.
but once scored odd shaped lump of ali.
went in from each end with hole saw and ended up with pce of rd for job i needed just needed cleaning up.
might work with your rd stock and you will kave smaller dia pce of rd stock after.
Thread: Newbie from Herts
13/10/2016 19:47:40
hi, i build cycles from scratch for kids and myself.
got plans somewhere for a frame building jig if any good?
this is one my boy did lot of work on inc welding.
Thread: freebies = project
13/10/2016 14:01:19
had to call in at metal supermarket for pce of 8"x6"x3/8" plate for project.
spotted some 3/8 thick i-beam offcuts in scrap pile asked how much got told take them.
one is 10" long other 12".
plan is cut along center of upright and then shape ends of cross pces to make formers for some meatalwork projects bit like anvils.
Edited By naughtyboy on 13/10/2016 14:12:41
Thread: Insurance companies
11/10/2016 20:28:24
they tried bumping mine up for car by 350 last time.
went to broker and ended up with 125 less than i had paid year before.
Thread: broaching
11/10/2016 10:28:40
thanks for advice.
prob have go ay jasons way.
not critical if slightly out as will drill top pce once base pce slotted and filled then i know holes will be in line with lathe.
10/10/2016 14:52:02
thank you Nigel sent email.
10/10/2016 14:32:21
if broaching out of q what is a good way to get it made?
as looks like i will have to go down route of getting them made.
10/10/2016 14:19:30
10/10/2016 14:11:36
its 60mm across and 15mm thick if that helps?
overall thickness is 22mm.
its just the base piece.
give me 5 mins and will try to strip it and get better pic.
Edited By naughtyboy on 10/10/2016 14:12:58
Edited By naughtyboy on 10/10/2016 14:15:06
Edited By naughtyboy on 10/10/2016 14:20:45
10/10/2016 13:25:33
i want to make several capstans for my ml6 lathe so i can just swap complete units over and leave them set up for certain jobs.
need to make the bit in pic someone at club suggested broaching it.
never seen it done so wondered if one of the wsp series of books cover it?
and where i could get one made as can only see normal keyway ones.
or is there a better way?
i don't have a milling machine.
thanks
Thread: drilling balls
10/10/2016 11:38:51
all i know is she is an artist/sculptor.
she never tells boss what she is working on until it's finished.
had me drill and tap some brass rods that she will bend to shape.
so we know it's gold and silver colored and that's it.
thanks for the info will just wait till he gets them to know exactly what they are made off.
09/10/2016 21:14:32
need to drill some ball bearings of different sizes.
what is best way need to be drilled carefull
they are different sizes and for bosses wife but she won't say what they are for so can't give more info.
Thread: photo copying books
06/10/2016 10:14:35
Posted by Mike on 06/10/2016 08:36:11:
From some of the contributions above, anyone would think authors are either some sort of charity, or wrote books for fun. It may surprise some people, but professional writers write for a living. I am sure no-one who contributes to this forum would steal another man's pay packet, yet copying a book, in my mind, is just about as immoral. No, if you need the information contained in a book, then either buy it or borrow it from a library. Grumpy old man's rant over!
the book is mine bought it specificaly for the grinding rest plans.
Thread: grinding rest milling
06/10/2016 07:54:11
hoping to be building the advanced grinding rest.
can i do all the milling for it on my lathe?
miller at club is out of action for a while and would like to get it made ta
