Here is a list of all the postings dazz dazz has made in our forums. Click on a thread name to jump to the thread.
Thread: Stellite Tig Welding Rods |
23/11/2012 20:57:57 |
ring around all the local welding suppliers, as some will split packs and sell what you need |
Thread: Suppliers in Gloucester / Bristol Area |
23/11/2012 20:56:38 |
Sorry ian look up feeder road, runs along the feeder canal, close to temple meads station |
Thread: Arc Welding |
23/11/2012 20:07:22 |
Mig or tig But not the cheapy ones sold on the high street, go for a small industrial one as second hand these can be cheap, i got a migtronic 180a mig for less than £200 a few years ago and its been used for everything from car repairs to motorcycle frames. Tig again ex indutrial mine cost £180 , and came with an arc lead as well as the tig torch, absolutely wonderful for arc
for bike tubes i would go with mig as this can be picked up quicker if you havent welded much, but if you have experiance in gas welding then tig is easier to pick up as your hands can already move a torch and feed in a rod if you go mig or tig dont buy the silly little disposable bottles as the cost of welding rised sharply using them, buy a bottle from air liquide expensive for the first one but after that no rental charges just refil, lastly mig spares are dirt cheap for industrial migs and tigs, so theres a big saving over hobby machines |
23/11/2012 19:58:26 |
cromwells on the feeder for tooling (online or pop in and grab a catalogue) gr fasteners (avonmouth and stroud) fred powells metal (on the feeder) sell in full legnth and have a min order of a tenner(this was a couple of years ago) so ring armed with a list of steel you want it's suprisingly cheap durbin metals in yate (all sorts they have offcuts as well) all the above are online |
Thread: Ferris Wheel Electronic Board |
15/11/2012 15:47:23 |
Cheers John i was looking at it and missed that one with the diodes many thanks for the correction Regards Dazz |
15/11/2012 13:27:40 |
Hi Martin email on route
added two photos incorporating John Swift's suggestions For those interested the software i used for the layout can be found here **LINK** its free and constrantly being developed
Regards Dazz |
14/11/2012 19:19:16 |
images are out of order grrrrr Bottom one simply shows component placement Second image is with the connections labled First image is looking at the bottom of the board where you need to cut tracks Third image is as if you were looking through the board from the top This circuit was drawn from the articles doiwnloaded from this site (pdf 12) so may need tweaking if its been updated in a later edition Regards Dazz |
14/11/2012 19:14:58 |
Hi Martin I had a bit of spare time today so i drew the board up for you i moved a few components to tidy the board up and to avoid the clashes with the hole numbering, if the posted images are not clear enough i can email a pdf of the images which is clearer
Regards Dazz
Thread: How Britain Worked |
01/11/2012 18:33:53 |
I like guys show as he seems genuinely enthusiastic, favorite bit so far was his face whilst going down that hill on his pushbike, anyone remember model world with bob symes, and a few years back there was another model type program cant remember the presenter, what i can remember was a dirty gert big warship and the presenter building a model railway in the garden only to rip it up later |
Thread: Love or hate living with a mini lathe |
28/10/2012 17:39:14 |
A few photos please forgive the focus as i cant get at my camera so had to snap these with a webcam View of the top Front panel with space for an lcd Internals everything was pushed as far right as possible to allow later fitment of a pcb, although the pics are awful note i reused the connectors for the line filter, also note the warth lead from the mains inlet at rear to the front outlet and also to the forward/reverse switch Will get some better photos and some photos of the bearings
Regards Inee Edited By dazz dazz on 28/10/2012 17:39:40 |
27/10/2012 23:34:46 |
Found a spare hour yesterday so removed the leadscrew and machinded another 4mm off the front of the leadscrew where it abuts the front bearing block. Then fitted a thrust bearing to the leadscrew , so now both bearing blocks have a needle roller and thrust bearing, reassembled and now i can place a finger on top the chuck and pull it towards me with little effort, whereas before i had to give it a good tug to move it . I can also rotate the chuck by hand with the carrage feed engaged something that no matter how i tried i could not do before. so with that out of the way i fitted the rocker toolpost i bought, it makes setting the tool a breeze. I then fitted the brass gibs i bought and what a difference they make, smoother with no play in the cross slide or the top slide. Next on the list is trying to find a replacement motor end cover as mine is breaking up badly and allowing one brush holder to rotate, for now im going to have to try some superglue in the cracks to hold the brush holder in position. Then find a narrow jubilee clip to fit over the end of the cover to hold the bearing as that bits cracked as well. Was it worh it oh yes the lathe runs smoother,quieter and a cooler. When i can find a bit more time i will take a few pics of the control box.
Stovepipe Dorris is the pup from hell so deserves everytrhing she gets called, i will stick to male dogs in future Regards inee |
Thread: What did you do today? (2013) |
21/10/2012 22:18:04 |
Quoted Posted by Terryd on 21/10/2012 07:33:37: Hi All,
Had some maintainance to do so cut back a rampant Wisteria I am trying to kill off - I had sprayed it with glyphosate 4 weeks ago (and managed to kill off a bit of the lawn as well
Hi Terry Have you tried wedging a few slithers of copper into the main stem, kills off quite a few different plants but takes a while Regards Inee |
Thread: Centre Cam |
21/10/2012 17:05:28 |
Hi Lofty I have just downloaded the demo version of CentreCam and installed it on windows7 ,it works fine. What error is it giving you ?
Regards Inee |
18/10/2012 20:16:07 |
Needle rollers and a thrust came today, so removed leadscrew and popped the far end block into the 4 jaw and bored to a shade under 18mm. I bored right through the block as i will add an extention later for a handwheel or stepper motor maybe both for an extra fine feed. Then I bored the block a further 4mm for the thrust bearing this unfortunantley removes a large part of the face of the block and leaces the thust bearing exposed. If too much grit gets on during use i can always find an oil seal to cover the thrust bearing. Whilst the leadscrew was off I set the front block in the 4 jaw and bored for the needle roller i went just a tad deeper than the length of the bearing, at this point a schoolboy error when i say schollboy error what I really mean is complete stupidity. Somehow I had managed to only order one thrust race but even more stupidly measured both ends of the leadscrew and assumed both bearings would be the same size. The extreeme ends of the leadscrew are the same size but the front bearing surface is bigger, in the end I machined the step out of the leadscrew and made it 3.5mm longer so when i get another thrust race I can remove the block fit the race and pop it back on. After all that did it work yes the leadscrew spins freely wheras before it was very tight. The control box works like a charm as well that live to the left of the lathe and does not catch swarf and oil anymore |
Thread: Self adulation |
18/10/2012 15:06:52 |
Terry i must appologise for the one or two spelling mistakes,but down here we never say earnt or turned even it's always turnt or earnt, the imo was totally my fault as the door knocked and I abreiviated before answering and forgot to change it. Whilst I agree school workshops as we know them are on the decline. Schools today have extensively equipped workshops but the kids can't use the tools as freely as we could. Opertunities to do practical stuff is out there for kids but they have to go and seek them. My data on kids of today comes from my teenage stepchildrens friends and spending a lot of time over the years working around schools and colleges. The only things that were edited in my articles was use or regional dialogue Regards inee (not the best speller in the world) |
18/10/2012 12:48:11 |
Reading this thread has forced me to add my comments |
16/10/2012 23:03:42 |
So onto the case i drilled two holes looking at the case on the far right i have the speed pot, next to it i have the fwd/off/rvs switch, then i have just to the right of the middle an iec chassis plug, this was chosen as i had some laying around gathering dust, above the socket on top the box i have the emergency switch and to the right of that i have the fuse, i put the fuse on the top as its easier to get at should it blow. at the same time i have put the fuse into the live side as per the(mini lathe pcb posts on here). |
16/10/2012 23:03:31 |
16/10/2012 23:02:37 |
My mini lathe recently started to have a hefty dose of ghostly happenings, mainly when applying mains power it would growl and start up on it's own, the first time it happened I chased Doris the puppy out of the shed, and told here she would have to get used to lathe noises if she wanted to come into my shed, she just growled so went back into shed and the lathe was still doing it's own thing turning a 1/8 to 1/4 of a turn growling then stopping.
As I had replaced the headstock bearings with tapered ones a while back and the lathes been standing for a long while, I whipped of the headstock and smeared everything with a light grease, switched it back on and ran it at 1/2 speed for 5 Mins then flat-out for 10, let it cool down and adjusted the spindle lock nuts smooth now with barely a flicker on the dti at the spindle rim, refitted the chuck and had the same reading on the dti on the chuck, so happy and thinking I’d cured it started some cutting, just my luck the slides were all to cock, so tried to adjust it out but no joy loads of tight and loose spots on the carriage, cross and top slides.
I cleaned everything and reassembled it all, another test turning lathe just growled at me and cut just the same as before, so apart it came again, the worst offender was the saddle as at the rear it seems to jump up and down like a Weston donkey, so out with the blue I last saw it 3 years ago, off up the garden to the other shed 2 hours later I found it under the wheel of my industrial mig welder crushed. upon opening it was as dry as boot leather so I managed to dip a wet finger into the pot and managed to get enough to coat all 3 slide-ways, ran all 3 slides up and down and had a look at the slides, there hardly any contact anywhere, as it was dark and cold I took all 3 slides in house and settled down with a fag and a cup of coffee, so looking at the top slide first I smeared the ways with some solvol autosol chrome polish and soon got into a rhythm of sliding the top slide on the cross-slide using my knee-vice to hold the cross slide(I do not recommend using the knee vice to hold loco frames whilst shaping them with an angle grinder ) when the slides felt smooth I cleaned everything off and ran a tiny bit of spit onto the ways and run em up and down a few times, then removed the top slide(used to grind car valves like this the ring of spit shows where there is no contact and the shiny metal shows where there is contact, I had to do this for about an hour till I got a good balance between contact on the ways and non contact to allow oil to do its job, gave it a good clean then set about the cross slide on the saddle same again.
Only this time more exhausting as the knee vice did not like the weight of the saddle and cross slide, as it was now approaching 1am I decided to give it a rest till the following morning, so in the morning more fags and coffee the a good clean and then I ran some oil on the 2 slides and ran em up and down as soon as the oil got black another clean and re-oil till it stayed clean(just to make sure all the polish had been removed), the top slide had a bearing conversion I did years ago but I was not happy with it, so reassembled the top slide, and now its so much better and I can see why I did the bearing conversion. so with that one set and adjusted I set about removing the, top slide and setting the cross slide again so much better once I was happy I replaced the top-slide and removed the cross slide from the saddle, the saddle was just awful it seemed to rock in every direction so rechecked with blue and there was about 2 strips on the back where it contacted the bed and even less on the front, the front of the saddle was a few thou higher than the rear not good, so I found some wet and dry and some duct tape(another hour lost in the top shed).
