Here is a list of all the postings Captain Biggles has made in our forums. Click on a thread name to jump to the thread.
Thread: Pro Machine Tools website |
19/02/2021 09:06:27 |
Hi Terry, I've been trying to get on their website too and been having the same problems. I'm wondering if they've gone out of business, so if you have got hold of them on the phone please let me know. Thanks, Joel |
Thread: Sieg Mill from ArcEurotrade |
02/10/2020 16:04:29 |
Thanks Ketan. Definitely in the market for one, guess I can just use an adaptor so I can keep all my existing 3MT tooling |
02/10/2020 15:39:53 |
Posted by Ketan Swali on 13/03/2020 14:32:47:
A member of my team drew my attention to this thread. Thank you Jon for your order, and thank you others for your kind comments. In response to Jason, Dave and potential customers who have called to enquire about SIEG machines which are out of stock, this is the current situation: We ran out of stock of the following machines as indicated: SX3.5DZP a few months ago. SC3 stock ran out on 5th March 2020 SX2P stock ran out yesterday 12th March 2020 Following machines we expect to run out of stock within the next 20 to 30 days, provided there are people out there wanting to buy in the current climate, and provided we and/or the logistics companies are able to deliver.: SC2-300, SX1LP, SX2.7L, SX3 We have enough stocks of the following machines to keep us going for a while: SC4-510 and SX2.7 Initially we were expecting deliveries of new stock by mid April. This was then extended to mid-May (for those who saw the mid-May date on our website, and were guided accordingly during your phone calls to us), but now this have been extended to 1st June 2020. As Dave said, it is zigzag or see-saw. We have potential customers for items we don't have in stock at present. We don't know if there will be any trading activity taking place in the U.K., when the machines arrive, and/or if the potential customers who want the machines now will be prepared to wait until the new goods arrive. Based on the response from an emergency meeting held at the factory this morning, we are estimating shipment for some of the goods we have ordered to take place between 15th to 30th April, subject to the factory getting some of the components required to finish off making some of the larger machines. Some of these component supplier factories still remain closed. Also, about 18 machine assemblers are still stuck in locked down areas. So these shipment dates remain as indicative. Having discussed this with other importers, it is my understanding that they too are in a similar position to us for items which are out of stock. Ketan at ARC.
This post (and the ones above it) have convinced me to make my next mill purchase from Arc. Now, all I need is the SX3.5 with a 3MT spindle and no DRO. Even better would be a tilting head. What are my chances for the next batch to arrive back in stock with that specification??? Joel Edited By Captain Biggles on 02/10/2020 15:42:23 |
Thread: Warco VMC Vario |
30/09/2020 16:59:19 |
Thanks both. I'm after a VFD controlled motor of at least 1kW, with 3MT spindle and a table bigger than 500 x 150mm and feeds on at least the longitudinal travel. It should be c. 1000mm width footprint. The closest machine I've found that meets these criteria is the Wabeco F1410 but that is significantly out of my price range, sadly. As far as I can tell from what you've written, and looking at Warco's website, the primary difference between the VMC and Super Major is that the Major is bigger and has a back gear rather than belt drive. Anything else I've missed?
30/09/2020 13:36:46 |
-- BUMP -- I'm curious about the VMC Vario and people's experiences with it. It seems an ideal size for my workshop although I'd rather an 3MT spindle if this was possible as I have a lot of tooling already. The Super Major Vario is a jump in price and size, is it worth it? Thanks, Joel |
Thread: VFD for M300 |
03/09/2020 16:13:37 |
Posted by Andrew Johnston on 03/09/2020 15:02:06:
Posted by Captain Biggles on 03/09/2020 14:45:49:
.....have suggested an VFD but I'd also need to change the motor as the one on there currently isn't dual-voltage, apparently. Do you know that, or did someone tell you? In my manual the spindle motor part number is the same on both 415V (UK) and 220V/380V (European) schematics.
Thanks Andrew, I am in contact with Transwave who said that unless it says 415/240 it's not suitable. It only says 415 and it's wound in a star (see photos, with apologies for previous owner's paintwork) However if I can wire it into a delta configuration then presumably it'll be ok at 240? Thanks, Joel |
03/09/2020 14:45:49 |
Following a most enlightening and entertaining post about hand wheel dials yesterday (**LINK**) I did say I'd be back with more questions soon. So... My M300 is a 3-phase machine and I've only got domestic single-phase in the garage. Transwave have suggested an VFD but I'd also need to change the motor as the one on there currently isn't dual-voltage, apparently. But surely if I'm going to the trouble of replacing the motor I may as well just fit a single-phase one and not bother with the VFD, saving £500? Or am I missing something? Thanks, Joel |
Thread: Harrison M300 - am I going crazy? |
02/09/2020 13:50:45 |
Thank you for the info all - most enlightening. I have to confess I've only ever used more recent lathes with a dial, with or without a DRO, so it never occurred to me there may have been another way. Speaking of which, the link to the Harold Hall article on his website referenced by DC31k above is here: **LINK** I've contacted a supplier of spare parts for the M300 as I thought I'd seen a drawing with the dial assembly in the manual and I was right, there was an option to specify this when purchasing the lathe from new. Most didn't bother however, which explains why I'd struggled to find any photographic evidence. I've asked for a quote, out of curiosity mostly as I still plan to fit a DRO. You can also purchase stops directly from Colchester for the M300, for about £250 with or without micrometer adjustment here: **LINK** and a multi-position bed stop here: **LINK** Cheers, Joel |
02/09/2020 11:12:47 |
Please help! I've just bought a second-hand Harrison M300 and am trying to get familiar with it (so expect more questions). The first thing I've noticed is that the handle for the longitudinal (transverse) feed has no dial on it - to tell how far the apron has traveled. Unless I'm going crazy, this means that unless you're using the dial on the compound slide, you've no idea how far towards the chuck you've moved. I've studied photo after photo and video after video and not seen any concrete evidence of there being a dial on anyone else's machine, so was this standard? I'll fit a DRO so it's not the end of the world, but can anyone put my mind at ease? What am I missing? Thanks all, Joel |
Thread: Stuart Turner "Progress" OH1 |
25/01/2018 08:47:12 |
Anyone built the Stuart Turner "Progress" OH1 and care to share their thoughts & tips? Just about to start mine, am thinking I may make a few of the parts differently to how they're drawn... Thanks, Joel |
Thread: Lathe Tool Inserts |
25/02/2014 16:43:40 |
No offence is taken, and yes, I'm sure I will get around to buying a linisher/grinder at some point. But I have to say there is definitely an air of moral superiority dished out by those who grind their own over those who made the decision at the outset to postpone the purchase of yet another piece of equipment when an out-of-the-box alternative solution exists which enables the beginner to hone (ha ha) their skills in other areas of this fascinating hobby. |
25/02/2014 08:46:54 |
Speaking with all the clarity of a beginner... Having bought a lathe/mill, vices, collets, mounting blocks, bolts, milling bits etc, the beginner is then faced with a simple decision. Either buy some square bits of HSS and yet more equipment in the form of a grinding wheel & work out the hard way how to grind a bit (often with only books / internet to advise) or buy some tipped tools where all that work has been done for them. It is hardly surprising therefore that a beginner would pick the tipped tools is it? Sure, if I was doing an apprenticeship and an old hand could show me how to grind then I'd be all ears, but left to your own devices when there are so many other skills to learn I don't think a beginner should be chastised for picking those other skills to learn first. Joel - Romford MEC Newcomer of the Year 2014! |
Thread: Rechargeable 24 v drill |
21/03/2013 12:32:09 |
+1 for Makita. Got the 18v drill & impact driver set & they're brutal. |
Thread: Fitting a DRO to Chester 3-in-1 |
05/03/2013 13:43:01 |
Who says design by committee is a bad thing? Cheers all! |
05/03/2013 09:57:47 |
Comme ca?
Michael, you're a genius... Cheers! |
04/03/2013 19:39:29 |
I'm after some advice - has anyone fitted a DRO to a Chester Centurion 3-in-1? Alternatively, can anyone comment on my cunning plan... The sketch below shows the scale (in a extrusion) freely running behind two clamps that are bolted to the body of my machine. The encoder is mounted on L-bracket between the two. The bottom of the scale is attached to another bracket, and it's here I need some advice. Somehow this bottom bracket needs to attach to the quill, I'm not sure whether bolting it would be a suitable option, and I'm considering some kind of jubilee clip type solution. Can anyone comment? (The sketch below is simplified, showing just part of the body of the machine and the quill. Spindle ommitted for clarity) |
Thread: J B Tooling, Indexing Tips |
05/02/2013 13:25:18 |
I've been trying to get hold of them post-Alexandra Palace too, keep getting answer phone. I've not actually left a message admittedly, but I've posted something to them and will let you all know if I get anything back in the post! |
Thread: Offline copies |
30/01/2013 08:14:40 |
David, You are still missing the point. This is not a debate about the "value" of the current deal (we'd do well to remind ourselves of the difference in "value" and "cost" anyway) but my original point still stands. I pay £40.50 for an annual subscription to Railway Modeller and get access to all the back-issues they've got around to digitising. I CAN read them all, online or offline, wherever I am in the world. I pay £55 for an annual subscription to Model Engineerand and get access to all the back-issues they've got around to digitising. I CAN'T even read the current issue unless I have internet access, let alone the back-issues. Why? It is not about copying, or distributing, or what a good deal we get already, it's about having access to what's been paid for, wherever I want it. Joel |
Thread: Alexandra Palace show |
18/01/2013 13:36:51 |
Coming tomorrow from Essex - first time. Excited. Edited By David Clark 1 on 18/01/2013 15:43:38 |
11/12/2012 14:12:18 |
Thanks for all the suggestions guys. What I was really hoping for is perhaps David to suggest a reason why other magazines I subscribe to allow me to read them offline but ME does not. Otherwise I'll just resort to reading these other mags when I'm on the road. It's nothing to do with me wanting to make copies or backups or share them or to get around a pay-wall. I just want to read them on the plane as easily as the other mags I subscribe to digitally. Incidentally, going back to what Robin said above about making copies, I cannot see any way of making a copy of Railway Modeller, for instance, and nor would I wish to. But I can read it on the plane!!!! |
