Member postings for Sam Longley 1
Here is a list of all the postings Sam Longley 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: What Did You Do Today (2016)
13/09/2016 16:04:05
You lot of sick'os remind me of a poem I had to recite at a charity event one night.
Took me ages to learn but once learned I have never forgotten it
Won't bore you with it all but some may remember the great Stanley Holloway:-
I've been very poorly, but now I feel fine.
I went out yesterday for the very first time.
I felt like a lad as i strode down the road.
Then up came old Jones & he said " Well I am blowed"
"My word you do look queer, My word you do look queer"
I said " Don't say that , Its true I've been ill"
He said " I glad you are better but still, I wish there was a thousand for me in your will"
My word you do look queer. My word you do look queer"
Edited By Sam Longley 1 on 13/09/2016 16:06:49
13/09/2016 15:36:25
Posted by Robbo on 13/09/2016 09:16:44:
Sam
"Spent the last couple of days emailing and telephoning Macc models "
Ok. I made the comment because many people just send an email & then complain of no reply. My experience of emails is that they often get lost in the wash & a simple phone call often solves the problem. Clearly, in this case, that did not work either
13/09/2016 07:15:42
Posted by Mad muppet on 13/09/2016 04:44:12:
Spent the last couple of days emailing and telephoning Macc models about two out standing orders. One from six weeks ago. But no joy. Has any one else having similar problems.
Mad Muppet ft
Have you tried picking the phone up & calling them ??
10/09/2016 19:17:43
Just sailed the boat back from a 34 day holiday in belgium including an 8 day cruise into Holland to Middleburgh, Veere, Zerikzee & Breskens.
Whilst model engineering one often gets a minor burn from hot metal, solder etc. I had a slightly different burn. Whilst sailing in the Veersemere we hoisted the cruising chute which is 64 M2 ( enough to carpet a small single bed flat !!!). A Gust of wind hit us & my crew was helming. He should have turned down wind to make the boat more stable but being inexperienced he did not we took the wind broadside & the decks went awash so I had to let the sheets off a bit sharpish as he started to panic. Unfortunately I slipped & having no lifejacket & not being clipped on i found it difficult to let go of the rope quick enough. In the split second it ran through my hand I had a rope burn & the picture shows the result. I have been sailing for years & have always managed to avoid this. Not this time. They have started to heal fairly quickly & this photo is taken 7 days after the event
The trip back started Ok with a lovely 7kt reach in warm sunshine but the forecast 5-10 kts winds from the Longsand head along the Gunfleet windfarm turned into 20-30kts on the nose & we had 2metre swell & breaking seas for 9 hours. We arrived at Bradwell creek in the pitch black at 03-00 hours after 17 hours totally knackered. They view of the stars at night was great & we did see a few shooting stars.
Overall a great holiday & the end to 11 weeks of cruising for me which has included the Channel islands Normandy & as far as Treguier
So now I am back to my workshop & a bit of model making. Will it hurt if I get swarf in the cuts???????
Edited By Sam Longley 1 on 10/09/2016 19:26:23
Thread: Amadeal Lathe
30/08/2016 21:38:53
Posted by Neil Wyatt on 30/08/2016 18:21:57:
Posted by Sam Longley 1 on 30/08/2016 07:48:34:
Applogies for going off thread here but it is being suggested that running slow puts a higher load on a variable speed motor- is that correct?
No its fine to do that, its continued running at low speeds under load that causes overheating because the fan barely works at low speeds.
Thread: Tidal power getting going in the UK
30/08/2016 08:02:00
Hydro electric usually runs on fresh water so the turbine blades have a different marine growth to deal with & i believe that they run quite fast thus throwing anything off before it can fasten itself to the blade
What will be a problem with tidal systems is the gradual build up of marine growth. These turbines run fairly slow so will not shed the slime etc once weed gets a foot hold it will greatly affect performance. This will happen mostly during neap tides.
There are no antifoulling systems currently invented that are safe for the environment that can be used & whilst the designers may have considered this i am sure it will be a major problem
30/08/2016 07:48:34
I ask because on my warco 250mv i usually start on slow speed, build up to speed i want then start the cut.
It would seem from the comments above that may not be a good thing on variable speed lathes and that having selected a speed i should stay with it & not keep going back to slow speed and back up again every time i stop
Edited By Sam Longley 1 on 30/08/2016 07:51:18
Thread: What would you ban and why? (Definitely tearoom!)
23/08/2016 20:56:06
Posted by Mike on 23/08/2016 16:19:08:
Sam, I was taught by my former employer's IT chief that writing e-mails in upper case was rude. Mind you, as a deaf old git myself, 72 point lower case might be handy...
I always thought it was meant to indicate shouting!!
But clearly the joke has fallen on deaf ears
23/08/2016 15:44:10
SHOULD WE TYPE ALL REPLIES IN UPPER CASE FOR ALL THE POOR OLD DUFFERS WITH HEARING PROBLEMS?
I will get my coat
Edited By Sam Longley 1 on 23/08/2016 15:44:45
Thread: Why did you do that ?
22/08/2016 13:12:03
& i suppose you are one of those poor sad old fells that RTFM before buggering it up.
It is what being a bloke is all about----- especially if the wife is watching!!
Definitely lacking in testosterone
Edited By Sam Longley 1 on 22/08/2016 13:14:33
Edited By Sam Longley 1 on 22/08/2016 13:16:10
22/08/2016 11:48:46
Posted by Ajohnw on 22/08/2016 10:00:33:
Something that should be banned - large HGV's running on their speed limiter and overtaking others doing the same on dual carriage ways and motor ways. We would all get there a lot quicker if they stopped this and use less fuel. It seems that they should drive to a 10 second rule - if overtaking takes longer don't.
devilMake every one else overtake in 10 secs or lees too.
Can you imagine the carnage as they all drove aroung holding their iphones up in front of their faces with the latest app showing a 10 second stop watch as they overtook & videoing it on facebook/twitter as they did it to tell their friends that they had just scored 14889 points in an overtaking manover
Edited By Sam Longley 1 on 22/08/2016 11:49:35
22/08/2016 07:56:49
Posted by Bill Dawes on 21/08/2016 21:13:22:
I am fully aware that many of the energy forms I quoted are not 'green' but the point I was making was that there is widespread 'support' of green energy (and we all need energy) but there appears to be equal oppostion to any form of energy production.
I was saying to my son the other day I wish I had some of the mentality I had when I was a teenager, the bit that enables you to sail through life without being irritated by:- loud music, garden fires, barking dogs, people who can't drive, 'sophisticated' people who are extremely stupid...........
Bill D.
Now you are just being b..y sensible. Have to stop that at once
Edited By Sam Longley 1 on 22/08/2016 07:59:26
22/08/2016 07:48:47
Posted by Cyril Bonnett on 21/08/2016 20:23:42:
Ban HGV's between 1 am and 11pm.
How would they deliver your 12 mm milling cutter with their 40 ft artic down your street other than between 11pm &. 1 am when all the cars are parked in it? Then knock you up at midnight to sign for it . Then knock you up to collect it when you find they have sent half inch not 12mm
Edited By Sam Longley 1 on 22/08/2016 07:58:11
21/08/2016 20:23:35
Posted by fizzy on 21/08/2016 20:12:35:
I want to impose a ten thousand pine fine for any cyclists riding two abreast on the public higfhway and a twent thousand pound fine for horse riders doing the same. They might currently have the right to do so (sadly both do) but that doesnt mean thats its a safe thing to do.
Have you considered the practice perfectly safe but that it might just be the moronic drivers who are not safe.
Mind you i do sometimes wonder why horse riders cannot just go & gallop round a field instead
Edited By Sam Longley 1 on 21/08/2016 20:25:15
21/08/2016 17:06:05
Posted by Ajohnw on 21/08/2016 16:39:34:
Posted by John Stevenson on 21/08/2016 15:40:16:
Why would that help Plod ?
Make more law abiding citizens stay in so the dossers can go out thieving in the dark ?
Yer, I'll vote for that. -- NOT
They could do a SAS on everybody they saw out and about without a light and if all law abiding people stopped in they would know that any one who was out and about could be up to no good.John
Edited By Ajohnw on 21/08/2016 16:59:46
That is a good idea --- a curfew--- nothing like a good old fashioned police state mr Putin,
If we had this police state would we still be allowed this forum or would the moderators chop our hands off first & ban women from looking at computers
21/08/2016 14:56:09
Seems the most toxic things might be other people rather than chemicals!!
21/08/2016 13:11:54
Posted by Nicholas Wheeler 1 on 21/08/2016 13:01:04:
Posted by John Stevenson on 21/08/2016 12:44:27:
Posted by Michael Walters on 21/08/2016 12:31:18:
"On a side note i would ban Rap/Dance music and computer gameslaugh"
"I've found a witch, may we burn her?"
Michael W
.no need to - already been done in Monty Pythons Search for The Holy Grail. She owned up in the end. Turned out she weighed more than a duck
Only if you put the video up on Youtube but don't stretch it out.
And ensure you don't use any dangerous chemicals to start the fire.
21/08/2016 13:05:52
I would like to ban people who oppose proper free speach as in what you really think rather than what is politically correct or what might upset some liberal t..t
21/08/2016 07:45:46
Having had a joinery business for 25 years i used most of the many machines myself but the one i hated was the spindle moulder. These can be bought as part of universal woodworker machines or even stand alone ones for hobby use & unless training is given they are extremely dangerous. I saw my fathers foreman loose 3 fingers & it was horendous. I employed several machinists who had lost digits in saws & spindle moulders
Spindle moulders should not be sold without evidence of training
Edited By Sam Longley 1 on 21/08/2016 07:48:50
Thread: Pickling with Sulphuric
20/08/2016 16:42:04
Years ago my father won a contract for the bata shoe factory in tilbury to renew the steel supporting the asbestos roof over their chromadising plant. The steel purlins had corroded due to acid fumes & had to be replaced so contract was to replace the steel. They thought he would also replace the roof but he saved money ( & made a tidy profit) by raising the roof & sliding the steel out bit by bit & replacing. Then lowering the roof onto the steel & re fixing the hook bolts.
All done by me and a gang over a holiday. So we worked over an asbestos roof over some 2ft deep tanks that had some 9mm ply sheets over them supported randomly by 3x2 timbers. We were 25 ft above on the asbestos a couple of hammers had dropped through & disappeared into the baths between the gaps in the unfixed plywood
After the job was done & the management were inspecting they started to have the covering removed. I asked what was in the tanks. "Oh they are the acid baths for dipping prior to chromadising"
So much for H & S 45 years ago
Edited By Sam Longley 1 on 20/08/2016 16:43:13
