Here is a list of all the postings gary has made in our forums. Click on a thread name to jump to the thread.
Thread: moderators |
20/02/2021 13:48:42 |
thank you bill. gary |
20/02/2021 13:32:35 |
BR my opening post was not in any way having a go at the moderators who i think do a good job. i am led to believe they do not explain in a short email to culprits why there posts are deleted. you have replied five times without addressing my genuine question, |
19/02/2021 16:08:50 |
another thread closed today and a member left the forum, isnt it time the moderators informed offending members that there thread is about to be closed and the reason why. this might avoid members being offended and leaving with there valuable knowledge |
Thread: Advice and guidance for arthritic folk |
15/02/2021 20:49:31 |
manuka honey and apple cider vinegar worked well for my father. cant remember the mix but it was quarter pint a day heated up |
Thread: crane uprate - where would you add some metal ? |
09/02/2021 11:42:49 |
nigel graham, could you please explain why it is not ok to lift a lathe of that size by its spindle |
Thread: Motorcycle General Discussion |
02/02/2021 06:34:11 |
this is an piece from an old motorcycle book explaining how to climb a frightful hill. a little commonsense and observation will enable many a frightful hill to be climbed by an engine in bad health. such abnormal hills generally owe there difficulty to one or two steep short pitches. when the engine begins to labour, jump off and run alongside for a few yards till the engine picks up freely again. keep a keen lookout from the tail of you eye for any by-roads coming down on to the hill at an angle, up which you may proceed to get a fresh start in emergencies. at worst if you have to push, pile all superfluous clothing on carrier before commencing to shove. it aso tells you how to remove the drive belt to aid pushing, obviously no clutch. the good old days? |
Thread: Washers under nuts |
29/01/2021 15:33:26 |
no. but they stop your paint from damage when tightening up. |
Thread: Bridgeport power feed |
26/01/2021 17:09:33 |
hi, sorted machine tool uk sell the adapters for about £50. they are easy to make i got the drawing off the internet but cant remember where. i just used a yellow transformer for my old unit |
Thread: How not to use a clamp |
23/01/2021 18:30:18 |
keep sharing your info ramon i have picked up a lot of good tips from you over the years the yarn for packing rings being the latest. got it today. |
Thread: What lathe |
23/01/2021 18:05:46 |
interesting info on the air rifles, for what its worth i owned a boxford and a super 7 i would choose the boxford every time. i now have a harrison m250 and would not part with it. |
23/01/2021 11:24:25 |
hi joshua, what is the legal power of an air rifle now, can the canisters be charged at home, how many shots do you get from a fully charged canister, |
21/01/2021 13:53:39 |
hello ian h i remember seeing a good cross section of a 276 carb on you tube. enter cross sectioned amal 276 carb and you might find it. gary |
Thread: piston rings for bronze cylinder |
18/01/2021 19:28:06 |
just my bad luck ramon i ordered a full length this afternoon. gary |
18/01/2021 14:29:25 |
thanks ramon and jason, i intend running it on air to start with but might run it on steam much later, no idea about boilers,feed pumps and lubricators yet. that yarn you use looks a good option ramon and not costly. thanks again gary |
17/01/2021 21:57:43 |
i am well on with my uss monitor engine and would like your opinions on the best material for rings in bronze cylinders gary |
Thread: The cheapest way to make a tailstock Dro |
17/01/2021 07:54:37 |
hi steve, nice video, is that you or the monkey that fills the ashtray. |
Thread: Hacksaw blade orientation - your opinion please |
12/12/2020 02:50:18 |
my rapidor cuts on the push stroke |
Thread: STAR Hit & Miss Engine |
09/12/2020 15:46:57 |
hi brian, cant help with your problem but you have made a superb job of that engine. |
Thread: Three Cylinder Steam Aero Engine |
06/12/2020 04:05:33 |
coming on nicely john. |
Thread: Another engineering masterclass |
25/11/2020 05:05:49 |
allan millyards bikes look fantastic but i wonder how they handle on the twisty roads? |
