Raymond Fairfield | 11/07/2014 05:38:37 |
3 forum posts | Anyone have a source for KYOCERA TKN 1.6 parting-off inserts ? Or if you are using them, be willing to part with a couple? Or be interested to share in buying a box of ten? At my age I'd have lots left for my heirs! Anyone interested in easy parting-off, I can show how to make a cheap back toolpost, the cost of the blade is reasonable, but tips are about $150 a box of ten& my source will no longer break a box. They work beautifully in small lathe, unless you let stainless work-harden as I did! |
Oompa Lumpa | 11/07/2014 05:51:05 |
888 forum posts 36 photos | This company: http://www.shop-apt.co.uk/carbide-inserts.html?gclid=CKS19L26vL8CFQrJtAodnncADA will break boxes sometimes and is worth asking. IIf you need someone to buy you a couple over here and ship them over to you drop me a line. I am always interested in seeing an idea for tooling. graham. |
Raymond Fairfield | 11/07/2014 10:42:02 |
3 forum posts | Thanks for that, but unfortunately their inserts start at 2.1 mm and I have the blade for 1,6 mm. Damn! The back toolpost I use steals an idea from L.C. Mason. a solid block is held down by a through bolt which also clamps a plate to hold the blade down on two eccentric discs which have a slight taper to hold the blade towards the block, and adjust it to centre height. No need for angles, they are all in the insert. Cutting fluid helps, but can generally be done without. Keeping a constant feed is important if cutting material that work hardens, As I've found out! |
