Harry Wilkes | 17/06/2014 15:44:24 |
![]() 1613 forum posts 72 photos | I have some steel which I intend to use to make a pair of riser blocks, looking at the photos in this "link" would I be right in thinking the hex adjusting screws would be something like M16 with 10mm hole ? Looking at the photos seems a straight forward job but would appreciate any tips/advice on said job. Thanks H |
NJH | 17/06/2014 16:16:14 |
![]() 2314 forum posts 139 photos | Hmm Harry I can soon check that I thought so I whizzed out to the workshop - not so easy I fear! Firstly I very much doubt that the Myford version is metric - nothing else on the machine seems to be. Trying to measure the o.d. of the adjusting screws is also problematic but I did manage to squeeze a little pair of spring calipers into the gap and the o.d. looks like 9/16" to me . Regards Norman |
John Baguley | 17/06/2014 19:07:53 |
![]() 517 forum posts 57 photos | Hi Harry, The adjusting screws are threaded 5/16" BSF internally for the holding down studs ( I had to make longer ones to suit a stand that I built) so the outside may be BSF as well. The hex heads of the adjusting screws are about 0.6" AF so Norman's 9/16" dia. for the threaded portion is probably spot on. John |
Brian Wood | 18/06/2014 08:53:43 |
2742 forum posts 39 photos | Hello Harry
