Help from those who have made this loco
Ian Horsfield 1 | 07/05/2014 19:57:24 |
6 forum posts | Not long started a Rob roy but need confidence in design of one of the stretchers. The drawing show a semi-circular cut and one of the books shows U cut out. Which is best and I assume the cut out is on the off-side of the engine. Please can you assist? Ian. |
AndyP | 07/05/2014 20:58:01 |
189 forum posts 30 photos | If you mean the cut out in the rear stretcher for the boiler blowdown valve then mine is U shaped about 7/16 deep and 7/8 wide. It is on the left hand side of the engine looking forwards. Whilst thinking about stretchers I had to mill pockets in the underside of the large central stretcher to clear the eccentric straps but that might be my slightly agricultural straps. Andy |
Ian Horsfield 1 | 08/05/2014 08:22:09 |
6 forum posts | Many thanks Andy, that answers my questions and I shall investigate clearance for the eccentrics. Ian |
Ian Horsfield 1 | 07/06/2014 17:09:55 |
6 forum posts | Forgot to ask if the u shaped cut out on the Rob Roy stretcher is on the top edge or bottom edge. The cut out is apparently on the left side looking forward. Can you clarify before I get cutting and fixing. Regards ian h.
Phil H 1 | 08/06/2014 12:57:41 |
128 forum posts 46 photos | Ian, I haven't assembled my frames but I have the Rob Roy book which seems to indicate the top edge for the cut out. If you look at the drawing showing the boiler backhead - you should see the blowdown valve which would clash with the top left hand side of the vertical stretcher as you look forwards. PhilH |
AndyP | 08/06/2014 13:24:56 |
189 forum posts 30 photos | I concur, top edge. Andy |
Ian Horsfield 1 | 08/06/2014 21:10:51 |
6 forum posts | Thanks Phil and Andy. It was well worth checking before assembly. Ian.
