Warco Major MD30B Power cutting out
Stuart Barker 107/03/2014 20:14:18
7 forum posts
Hello,
First off I am a total newbie to the forum and also a novice in the world of engineering as the last time i used a mill was back in school some 10 years ago.
I have recently bought a second hand Warco Major mill/drill MD30B. The problem is power trips out after 2 minutes of use and has to be reset. (reset meaning me opening the back and prodding a little) i have read through the trouble shooting in the manual that came with the mill but I'm not sure what's wrong.
Any help would be greatly appreciated.
Thanks.
Bazyle08/03/2014 21:12:05
6956 forum posts
229 photos
What sort of mains switch does it have? There are some varieties with an overcurrent sensor based on an element that heats up. This might be doing its job or might be just out of setting.
Also what kind of motor is it. Some have a secondary winding that is necessary to start it but once going it is disconnected by a centrifugal switch. This might be stuck so it stays on causing overcurrent or over heating that then trips a themal switch in the body of the motor.
oh yeah, Hi, welcome etc laugh
Edited By Bazyle on 08/03/2014 21:13:17
Bazyle08/03/2014 21:12:41
6956 forum posts
229 photos
oops hit duplicate button
Edited By Bazyle on 08/03/2014 21:13:55
Stuart Barker 109/03/2014 19:16:47
7 forum posts
There is a small red toggle in the electrical compartment that I think is the problem when it's fully wound in then there is no power to the switch. When there is power it's the same as before and trips after 2 minutes.
the motor is a jui Chun 240v, 14amp , single phase , 4 pole. 1.5 kW. 50hz.
Bazyle10/03/2014 17:19:51
6956 forum posts
229 photos
Sounds like some kind of current trip. The Grizzly G0705 seems to be the same but the manual doesn' t show this item.
HasBean11/03/2014 22:41:41
141 forum posts
32 photos
I have a Warco MD30N which sort of fitted in between the economy mill/drill and the major.
After a couple of years this also started to switch off after a few minutes. Turned out that the on/off switches, which were on the front above the depth stop, were getting warm, arcing and causing the over current on the motor to trip.
I ended up fitting an external NVR switch and used the existing cabling to fit a reversing switch, no trouble since.
Paul
Stuart Barker 103/04/2014 12:16:52
7 forum posts
HasBean i think you may be right. worth a try anyway.
