How to cut wedges from round bar
Chris Hunter | 14/01/2014 12:08:32 |
10 forum posts | Hi, first post so I hope this is in the right section and you will offer some advice even though this isn't strictly Model Engineering. I want to make some sets of Plug and Feathers for splitting rock - I want these to fit a 12mm hole, for the plug (wedge) I was planning on grinding down some cheap 12mm cold chisels but I am unsure as to how to make the feathers? The few ideas I've had are
Are any of these ideas practical? Is there a better way?
John McNamara | 14/01/2014 14:35:44 |
![]() 1377 forum posts 133 photos | Hello Chris Welcome to the forum. You may be on the right track grinding down some cheap? chisels for the wedge assuming they are made from a tougher grade of steel than mild steel. It would appear from the videos that they are worked pretty hard being struck with a heavy hammer I do not think plain mild steel would hold up. That leaves the feathers.....They are a bit less than half round on the back with a wedge taper that exactly matches the wedge that bears against them that is struck. Mild steel here also may lack the toughness required. I guess you could cut and grind one set up with the materials to hand and give it a try. This link is a brief list of steel types and their uses. **LINK** You would may need to heat treat the pieces after you have made them. I guess a medium to high carbon steel that you can harden and temper in your own workshop would be what to look for. I did find a lot of references to feathers and wedges on the net and a few videos. **LINK** Regards
Jeff Dayman | 14/01/2014 14:36:55 |
2356 forum posts 47 photos | Don't overcomplicate it. Feathers and wedge is a simple rock splitting tool made for hundreds if not thousands of years by every backwoods smith there ever was. Just make the feathers from hot rolled rectangular strip. If you can heat them to red, just round the outer corners of the lower part and bend them. They do not need to be tapered, although they will work better if they are. The central wedge bar can be of any tool steel, made flat and smooth in the forge. Do chamfer the top end so it has less tendency to mushroom. Good luck, JD |
Chris Hunter | 14/01/2014 15:12:00 |
10 forum posts | Thanks for the replies. Jeff - I think you have hit the nail on the head (excuse the pun), I was over-complicating it, I guess if I heat and hammer some flat stock along it's width it will get "fatter", providing a basic taper. I'm fairly confident that I can make a jig to run the resulting bar across the bench grinder to improve the taper. |
Brian Wood | 14/01/2014 16:12:20 |
2742 forum posts 39 photos | Hello Chris, I am also a dry stone waller and what Jeff describes is all that is needed. The feathers will deform readily to fit whatever hole you put them into and will become expendable, so don't waste a lot of effort on them. The wedge will drive more easily with a little grease on the taper face. You will be surprised how many sets you need to split a big rock. Regards Brian Edited By Brian Wood on 14/01/2014 16:12:53 Edited By Brian Wood on 14/01/2014 16:13:23 |
Chris Hunter | 14/01/2014 18:55:42 |
10 forum posts | Thanks Brian, always good to get the view of someone with experience. |
Stub Mandrel | 14/01/2014 21:21:11 |
![]() 4318 forum posts 291 photos 1 articles | My understanding is that the pyramids were made using these tools -but made of bronze. Neil |
dcosta | 14/01/2014 22:48:08 |
496 forum posts 207 photos | Hello Chris, good evening. |
Bazyle | 14/01/2014 23:28:17 |
![]() 6956 forum posts 229 photos | Wow, my one time local village industry of cutting granite had moved to steel tools in tthe late 18th century. A few rocks up on the moor still show evidence of the larger holes used for the wooden wedge system. |
