Myford plus help
Kevin Bennett13/11/2013 16:03:21
193 forum posts
56 photos
hi guys I was cleaning out my drip tray as I do every week on my Myford and I found a screw, washer and a disc spring washer as the photo I found it behind the motor around the back on the tray it is definitely from the lath as the screw and the heavy washer look the same as the one on the side of the gearbox it looks like it puts tension on the end of a shaft.
I have looked all over the lath with a torch and had no luck finding where it came from as anyone got a parts manual for a Myford 7 plus big bore
thanks Kevin
Kevin Bennett14/11/2013 14:20:23
193 forum posts
56 photos
re post for help
Mike Poole14/11/2013 18:36:00
3676 forum posts
82 photos
Does it retain the clutch operating lever?
Tony Pratt 114/11/2013 21:43:22
2319 forum posts
13 photos
Hi, have you not got an illustrated parts manual, you may be able to spot the parts in there? Or go on Myfords website.
Tony
Robbo14/11/2013 22:10:17
1504 forum posts
142 photos
Kevin,
On older Super7Bs ,there is one of these on the outside end of the gearbox layshaft, next to the leadscrew, as you have noted; the only other one in the headstock is on the backgear cluster, and holds the backgear twin gear onto its shaft on the backgear eccentric. Partially hidden under the bullwheel.
However, in some manuals this is shown as a circlip instead of the screw and washers.
Apart from this, am as baffled as you are.
Phil
TomK14/11/2013 22:37:29
83 forum posts
23 photos
Kevin
Have look at the motor there is a tie bar with a captive nut to lock the motor in position after adjusting the belt
tension . it looks very like  that part
Tom
Edited By TomK on 14/11/2013 22:39:17
Kevin Bennett15/11/2013 14:14:47
193 forum posts
56 photos
hi guys all sorted Mike was correct it retains the clutch operating lever
I got the info from looking at photos of the back of the lathe from **LINK** thanks for the help .
I think I need to get a parts manual book for future reference.
thanks Kevin
