Graham Wharton | 19/10/2013 18:14:49 |
149 forum posts 48 photos | Just trying to work out whether the threads on an old Abwood 4inch milling vice are likely to be UNC or BSW. Its got 1/4, 5/16 and 3/8 threads on it, but UNC and BSW are the same pitch. I've tried winding in both UNC and BSW bolts, and I cant tell any difference. On one hand I'm thinking why bother getting it right if both fit, but then again my nut and bolt OCD will be off the scale if I don't use the right ones. TIA Graham
S.D.L. | 19/10/2013 18:25:25 |
236 forum posts 37 photos | Posted by Graham Wharton on 19/10/2013 18:14:49:
Just trying to work out whether the threads on an old Abwood 4inch milling vice are likely to be UNC or BSW. TIA Graham
A wood is / was British but if from 60s could be either as unified threads were adopted me tween whit worth and metric. My Colchester student Mkll is UNC. steve |
Muzzer | 19/10/2013 18:44:00 |
![]() 2904 forum posts 448 photos | Doesn't sound as if it's critical either way but the UNC has 60 degrees and Whit is 55 degrees so arguably a thread gauge and a magnifying glass might give you the answer. Pity it doesn't have a 1/2" thread as that would give the game away definitively. My milling machine (Taiwanese BP clone) has Whit, UNC and Metric all together, all original. You got away lightly! Merry |
Martin Walsh 1 | 19/10/2013 21:46:25 |
113 forum posts 2 photos | Abwood are still going strong www.abwoodcnc.co.uk
Best Wishes Martin Edited By Martin Walsh 1 on 19/10/2013 21:47:34 |
Lambton | 20/10/2013 11:09:20 |
![]() 694 forum posts 2 photos | Graham, Despite the difference in thread angle UNC and BSW (other than 1/2" The unified system produces rather inelegant fastenings with A/F head sizes that are not a fixed proportion of the thread diameter as in Whitworth thread. Strangely no attempt was made to "unify" BSF thread with the ANF series. Fortunately metrication put a stop to the use of unified threads in this country many years ago. Eric Edited By Lambton on 20/10/2013 11:10:21 |
