Simple mill engine
Eric Cox12/10/2013 09:48:51
557 forum posts
38 photos
In the latest instalment, ME 4466 p490
Fig 9 valve rod guide CP7, should the hole be 3mm dia and not 4mm.
Fig 11 piston valve CP9 the M2 thread needs to be deeper as the valve is counter bored to locate the valve rod
CP11 valve chest back cover has not been covered in the articles so far. Is it a press fit or secured by bearing fit
Stewart Hart12/10/2013 13:38:23
674 forum posts
357 photos
The guide should be made to suit the valve rod 3mm ish
The valve will befor the threaded as drawing at minimum you can alway reduce the rod
The cover will be dealt with later it needs leaving off for now
Thanks for the interest
Stew
Thanks for
